Sony A7C II Leaked images
p.1 #1Sony A7C II Leaked images
Rumored images and specifications of the upcoming Sony a7C II camera have surfaced online:
33MP sensor (same as the Sony a7 IV)
Bionz XR, AI processor
5 stops IBIS
10fps
100-51,200 ISO
10 bit 4k60p, S-Cinetone
2,36 million dot EVF
3-inch LCD screen
759 AF points
Lens breathing compensation
Rumored announcement date: August 29th
Source: Photorumors.com
Aug 09, 2023 at 10:29 AM
Admin
Details
p.1 #2Sony A7C II Leaked images
If these images are legit, Sony added a front dial, an extra custom button next to "Menu", still no joystick and the EVF seems very similar to its predecessor.
Aug 09, 2023 at 10:33 AM
dieterson
Details
p.1 #3Sony A7C II Leaked images
Four wheels for free configuration is nice, the EVF and the missing joystick pitty, but if the weight is the same...
Aug 09, 2023 at 10:44 AM
genjy
Details
p.1 #4Sony A7C II Leaked images
Great specs but no AF joystick is unfortunate.
Edited on Aug 09, 2023 at 11:07 AM · View previous versions
Aug 09, 2023 at 10:51 AM
GMPhotography
Details
p.1 #5Sony A7C II Leaked images
Honestly it looks like a 6700 and either the same feature sets and same missing things. Now maybe Type A cards and 2 of them but go look at a 6700 same EVF same AF AI stuff. Honest glad I went 6700 as backup.
Aug 09, 2023 at 10:57 AM
Sharif Abdou
Details
p.1 #6Sony A7C II Leaked images
Also added the stacked mode dial similar to the A7.4 and A6700. That's one of the reasons I moved from the A7c to the A7.4. Quickly going back and forth between photo and video was a pain. Exposure compensation dial is now unlabeled, so it's customizable. I set that to white balance. Pity about the EVF. A proper eye cup like the A6700 would have been nice. Overall seems like a nice update.
Aug 09, 2023 at 11:22 AM
chiron
Details
p.1 #7Sony A7C II Leaked images
To my eye, the EVF projection looks a mite larger than on the A7C. Have to wait to see what the actual spec is. Eyepiece could look similar with different internals.
But, same as the a6700 seems very likely, for lots of reasons.
Aug 09, 2023 at 12:05 PM
GMPhotography
Details
p.1 #8Sony A7C II Leaked images
same as the 6700
3-inch LCD screen
759 AF points
got to look up the IBIS
If the EVF looks to be the same as the 6700 then I have zero advantage to get the A7CII over it. I want the crop sensor as the same as my A7RV cropped at 26mpx
Yea I would like 2 card slots
Aug 09, 2023 at 12:19 PM
Sharif Abdou
Details
p.1 #9Sony A7C II Leaked images
For some reason the A6700 doesn't have Dynamic Active stabilization, despite having the latest Bionz XR and AI chip. Hopefully the A7c has Dynamic Active, the IBIS is one of the few weaknesses of that camera.
Aug 09, 2023 at 12:58 PM
GMPhotography
Details
p.1 #10Sony A7C II Leaked images
I see this on BH for the 6700. I personally don't need it im a rock on handheld.
Image Stabilization
The camera's pixel-level 5-axis optical image stabilization system, which compensates for five different types of camera shake encountered during handheld shooting of stills and video, is algorithmically optimized for precision detection and control down to a single pixel. The AI Processing Unit also improves communication between the body and the lens, providing more stable framing before shooting. This allows users to confidently use any lens, even adapted lenses, for critical imaging without encountering blur from camera shake.
Aug 09, 2023 at 01:14 PM
GMPhotography
Details
p.1 #11Sony A7C II Leaked images
On F stoppers . Ill post link but check this out
One thing worth mentioning is that I found a small bug when trying to use active stabilization while in S&Q. If you record 4K 60p in regular movie mode, active stabilization works. But if you have your S&Q set to record 4K 60p, it gives you an error that you can't use active stabilization when recording at 120p. My guess is that this error was set up for all S&Q recordings even though it should really only be set up for when recording 120p. But I am also using a pre-release camera, so hopefully, this gets addressed before actual units begin to ship.
https://fstoppers.com/reviews/our-first-look-sony-a6700-636440
Aug 09, 2023 at 01:18 PM
phinix
Details
p.1 #12Sony A7C II Leaked images
No no no nooo... same old grip!
Aug 09, 2023 at 03:35 PM
tzhang4284
Details
p.1 #13Sony A7C II Leaked images
From the pictures, it looks like Sony is also going the route of continuing to widen the body over time - looks like the camera got a bit fatter as they did to the A7R series over the time. I wish they made the bodies a bit taller to help with grip and aesthetics too rather than keep widening it.
Aug 09, 2023 at 04:03 PM
Ghostinz
Details
p.1 #14Sony A7C II Leaked images
I am disappointed too.. say it isn't so!
I want this camera for landscape photography, so it checks all the boxes. I will wait just to make sure, but I was hoping it would have the same grip as my 6700. If it doesn't, I dont think it gives to much over just buying the revision 1, outside of the front command dial. Not sure that is worth what is probably going to be a $1k price difference.
Aug 09, 2023 at 04:06 PM
RomanMF
Details
p.1 #15Sony A7C II Leaked images
It seems a bit thicker, but not necessarily wider, which is disappointing to me. The grip, particularly the gap between the lens mount and the grip, still seems a bit rough. We'll see!
A7CR next!
Aug 09, 2023 at 04:36 PM
swldstn
Details
p.1 #16Sony A7C II Leaked images
As already noted on YouTube and verified personally the current A7C and new A6700 are basically the same size and weight. I wonder if this has put on any weight and besides full frame sensor has it got any better functionality or is going to have the same as the A6700? If the grip isn't as good that's a problem.
I do like the 33 Mpixel sensor if it got that. I would think that would make it $500-$700 more than the APS-C version. Would have me selling my A7C, A7IV, and A6700 I think.
Aug 09, 2023 at 05:26 PM
Admin
Details
p.1 #17Sony A7C II Leaked images
I just wish Sony was able to increase the EVF magnification!
Aug 09, 2023 at 06:08 PM
freaklikeme
Details
p.1 #18Sony A7C II Leaked images
It's deeper. There's no way they could fit their new, larger shutter release button on the old 7c grip. If that photo's accurate, the grip will be roughly the same size as the one on the 6700, which is nicely comfortable given the size of the camera.
Aug 09, 2023 at 06:09 PM
GMPhotography
Details
p.1 #19Sony A7C II Leaked images
That alone would push me. Not sure what they have been thinking.
Aug 09, 2023 at 06:19 PM
Admin
Details
p.1 #20Sony A7C II Leaked images
GMPhotography wrote:
Fred Miranda wroteI just wish Sony was able to increase the EVF magnification!
The RX1R II's pop-up EVF has higher magnification (0.74x vs 0.59x), so I think Sony can do it!
Aug 09, 2023 at 06:38 PM
Switch to mobile view
