       2       3       …       13       14       end
Archive 2020 · R5 overheating is horrible ....
J.Marcus Photo
p.1 #1 · R5 overheating is horrible ....
I did a test today. From a cold start , Delkin 512 card. 4k 120 , 14 minutes total , as expected. 6 hours later , only 5 more minutes I can record!! Unacceptable!
On my photo shoot 2 days ago I shot 45 minutes or so photos inside at 68 degrees. Camera was turned off in between set ups.
Went to shoot some 4k 120 and I had 4 minutes on the clock.
Totally not going to fly
Hopefully the tilta fan will work if canon can’t fix this to make it an acceptable feature.
1080 120 must be added as well!
The footage was incredible, I’m just not going to buy multiple bodies to use it.
Aug 08, 2020 at 03:14 PM
EB-1
p.1 #2 · R5 overheating is horrible ....
Who is using 120 commercially? Is that for slow-mo?
Aug 08, 2020 at 03:26 PM
J.Marcus Photo
p.1 #3 · R5 overheating is horrible ....
Wedding videography, music videos , YouTube... there really is a huge market.
The thing is, no matter what mode you want that overheats, once you take a few photos in the coolest scenarios , it will cut that time in half, or much more than half in my case. And it won’t recover for hours...
It wasn’t I who marketed this as the video king....
it can’t even do 1080 120..... somebody is not thinking at all.
1dx mkiii makes far more sense as a video camera at this point.
Aug 08, 2020 at 03:45 PM
Frank Kearney
p.1 #4 · R5 overheating is horrible ....
Someone posted on YouTube that the overheating issue was eliminated by removing the cards and recording externally -
https://youtu.be/PnG00Fhu5pI
Aug 08, 2020 at 03:52 PM
J.Marcus Photo
p.1 #5 · R5 overheating is horrible ....
Yes! But 120fps can’t be sent over HDMI in this camera
Aug 08, 2020 at 03:55 PM
cameron12x
p.1 #6 · R5 overheating is horrible ....
Didn't the original marketing say that it could do 1080 at 120fps? I seem to distinctly remember that.
Some have said that the shutdown is not related to heat at all. If you were to change the date/time after each video segment, could you fool the firmware to allow more time recording video?
Aug 08, 2020 at 04:02 PM
J.Marcus Photo
p.1 #7 · R5 overheating is horrible ....
A few people said canon were going to add it in a firmware update.
I might try to change the date and time but I will say the cfexpress card gets incredibly hot....
But there is no way it takes 8 hours to cool down internally.
Canon is limiting something internally.
Aug 08, 2020 at 04:09 PM
scalesusa
p.1 #8 · R5 overheating is horrible ....
...Show more →
Delkin warns you to switch out cards and to check them periodically since they heat up drastically using super high data rates.
https://www.delkindevices.com/learning_lab/pci-express-pcie-explained/
Aug 08, 2020 at 04:22 PM
J.Marcus Photo
p.1 #9 · R5 overheating is horrible ....
I wonder if switching cards out would help? Probably not since 6 hours later with no cards in camera it’s still “too hot”
Aug 08, 2020 at 04:25 PM
guyharrison
p.1 #10 · R5 overheating is horrible ....
This an unbelievable flaw. I use a camera in an underwater housing and regularly went back and forth between photo and video. So if I shoot photos while diving I will be cut to a few minutes of video. as the camera is "always on" in the housing. Then, if I shoot "too much" video all image making is done for the remainder of the dive. And, worst of all, I don't know when the shutdown will happen if I am back in stills mode?
Lots of similar scenarios could happen in nature/wildlife photography. I don't even want to imagine what folks like wedding and event photogs must be thinking.
I am a canon shooter and was really, really looking forward to this camera, but it is still the case that their entire FF mirrorless camera line so far is an epic fail.
Aug 08, 2020 at 04:30 PM
cameron12x
p.1 #11 · R5 overheating is horrible ....
I too was wondering if that would help.
Press the hidden "reset" button, wherever it is.
Aug 08, 2020 at 04:36 PM
J.Marcus Photo
p.1 #12 · R5 overheating is horrible ....
Yes! Unless you shoot 4k 30 not hq mode, your scenario would be a total nightmare at this stage.
The only thing that brings me any hope is that it is so incredibly bad it’s a total joke to the point that no company could leave it in this state.
...Show more →
Aug 08, 2020 at 04:46 PM
orlandoom
p.1 #13 · R5 overheating is horrible ....
Seems like it would be better to return the R5 and put that money toward a dedicated video camera.
Aug 08, 2020 at 05:03 PM
EB-1
p.1 #14 · R5 overheating is horrible ....
The heat is real based on the EXIF data. Changing the clock that may be fooling the system and potentially causing more damage.
Aug 08, 2020 at 05:11 PM
J.Marcus Photo
p.1 #15 · R5 overheating is horrible ....
Well the 1dx ii was fine , 1dxiii is fine... I do believe they can fix it. They just need a public outcry, they have to know leaving it like this will impact them financially
Aug 08, 2020 at 05:13 PM
EB-1
p.1 #16 · R5 overheating is horrible ....
...Show more →
I have heatsinks and a large fan on my computer's NVMe M.2 SSDs. Without a heatsink they would throttle under full load. Is there anything to help dissipate heat from the PCe cards to the surroundings?
Aug 08, 2020 at 05:17 PM
J.Marcus Photo
p.1 #17 · R5 overheating is horrible ....
I’m not sure, the camera shuts off if you open the card door while in use.
https://tilta.com/2020/07/tiltaing-camera-cage-for-canon-r5/
I know very little about the science behind all of this.
Could this potentially work?
Aug 08, 2020 at 05:25 PM
mdvaden
p.1 #18 · R5 overheating is horrible ....
If Canon didn't have higher end video cameras, your comment could be easier to entertain. Meanwhile, there's a myriad of reviews out from the past few weeks, so folks can use it or leave it.
I'm guessing that folks more serious about video will implement techniques to work with the camera's present capabilities.
Aug 08, 2020 at 05:49 PM
J.Marcus Photo
p.1 #19 · R5 overheating is horrible ....
I wouldn’t be so sure, considering the marketing, and expectations. How many hybrid shooters do you think would have purchased if canon would have said... “oh yea, if you take a few still photos , you can shoot 1-3 minutes of 4k...
It’s going to have to be fixed.
Sony, other canon bodies like the 1dx series and even nikons all can shoot without overheating for long periods.
Even when I had my Sony, it was the one that overheated a lot, but 2 minute cool down and I’m back to shooting.
It’s not going to go over well for them if they don’t fix it.
Give lower bit rate options in 4k 120.... offer a 1080 120 as well.
I actually think if they fix this , it will be my favorite camera possibly ever. Photography side is incredible. Video files are incredible, just unusable.
Aug 08, 2020 at 06:07 PM
Doug Vann
p.1 #20 · R5 overheating is horrible ....
I was a potential purchaser of the R5. However one of the reasons the price is steep is the video feature. This feature appears to not be working as intended so until this is resolved so purchasers are getting what they are paying for - I am out of the "purchase" group...... It is disappointing to see Canon come out with a camera that seems to be a fail in the area that was it's selling feature.
Aug 08, 2020 at 06:21 PM
       2       3       …       13       14       end
       2       3       …       13       14       end
