       2       3       4       5       end
Archive 2021 · Should I Replace My 1Dxll and 5Ds w/The R5?
JohnSil
p.1 #1 · Should I Replace My 1Dxll and 5Ds w/The R5?
I want to be able to post in the R5 images thread!!! LoL
No, just kidding!
Some background...., I saw no need to replace my current cameras with a ML any time soon.
But when shooting sports, mostly bicycle racing with the 1D probably 20% of the time the camera locks focus on the jersey and the face/eyes are soft. If its a really critical shot like a finish line I pre-focus and turn off the AF to be sure I get the shot and use high fps.
A couple of weeks ago I did an outdoor model shoot with the 5s and had my model up against a vertical dirt wall with lots of roots and rocks which were very contrasty. Again, I lost some really nice shots to softness because the camera locked over her shoulder on the tree roots.
With both cameras the focus point was exactly where I had put it, meaning right on the eye.
Also when using some of my fast lenses wide open even in the studio I'll get soft eyes because of the razor thin DOF.
I Micro Adjust my main lenses a couple times a year and even in that process I get variations during that process which means that the lenses are varying a bit in actual use.
My thinking is that all of those issues would resolve themselves!?
The only drawback I see is a lack of weather sealing in the R5 vs the 1D. The R5 would need a raincoat!!
And a question, does the R5 spot meter follow the focus point as in the 1Dx?
I would use my existing EF lenses on a converter for a while and them maybe replace my most used lenses to RF down the road.
So are there any reasons why I should NOT replace those two cameras with one R5?
Thanks so much...., John
Oct 23, 2021 at 03:05 AM
John_TX
p.1 #2 · Should I Replace My 1Dxll and 5Ds w/The R5?
The eye and animal autofocus was a game changer for me. I’ve only had the R5 about two months, and shot with my 5D4 a couple weeks back and even after that short period with the R5, transitioning back to the 5D4 was painful and it felt like each shot required much more though and tinkering with the autofocus points and camera to get right. I only use the mechanical shutter as 12 FPS is more than enough for me. I’m sure there are others who have used the R5 much more extensively than me that will shortly chime in, but that’s been my experiences!
Edited on Oct 25, 2021 at 05:49 AM · View previous versions
Oct 23, 2021 at 06:43 AM
dmahar
p.1 #3 · Should I Replace My 1Dxll and 5Ds w/The R5?
R5 spot metering does not follow focus point - only 1D series cameras have had that to date. R5 is weather sealed to at least the same level as earlier 5 series cameras (i.e. at least as well sealed as your 5Ds). With that said, I have always used a rain hood on both my 5 and 1 series cameras when shooting in very inclement condition as extra insurance. Focus hit rate is better than any previous canon camera I have owned (including 1Dx - can't comment on 1DxII).
Oct 23, 2021 at 07:22 AM
lighthound
p.1 #4 · Should I Replace My 1Dxll and 5Ds w/The R5?
I strongly suggest you try the R5 out for a couple shoots. You will quickly realize that you should have made the switch 15 months ago and you'll never look back.
Oct 23, 2021 at 08:08 AM
TeamSpeed
p.1 #5 · Should I Replace My 1Dxll and 5Ds w/The R5?
Why not consider trading out the 1DX2 for the R6? You get the same resolution, AF is very good with eye AF, etc. The only differences between the R5 and R6 are resolution, some features and video, and changes in controls/ergos (top display, etc).
Keep your 5DS for resolution needs, use the R6 for eye AF, 20fps in ES, and so. I have been using the R6 for action/sports with very good success too, but for portraiture with eye AF and following while I compose is very, very nice.
Oct 23, 2021 at 08:18 AM
jedibrain
p.1 #6 · Should I Replace My 1Dxll and 5Ds w/The R5?
I don't think the meter follows the focus point on the R5. I'm not even sure it does that on the R3. It has traditionally been a 1 series only feature. R5 is not quite as fast as the 1 series...12 vs 16fps. Electronic shutter can do 20 but you'll get rolling shutter effects.
Battery life is shorter, so grab a few extras. It's not too bad though.
Do you need a second body as a backup? That would be the only reason I could think to keep what you have. The mirror less systems are just so much better.
Brian
Oct 23, 2021 at 08:26 AM
RobAmy
p.1 #7 · Should I Replace My 1Dxll and 5Ds w/The R5?
^ This ^
Oct 23, 2021 at 09:17 AM
gdanmitchell
p.1 #8 · Should I Replace My 1Dxll and 5Ds w/The R5?
No, just kidding!
An aside about shooting bicycle racing... I've done a bit of it myself though admittedly not recently. The problem isn't really the camera so much as the nature of the typical framing of a cyclist. Let's say the rider is passing from left to right. You most likely will position the riders head/face above and to the right of the center of the frame, at least if you hope to include his/her body and bike in the frame, too.
So, ideally, you would move the AF area pretty far to the upper right to accomplish this. Indeed, if you leave the AF area more or less in the center of the frame, you will end up focusing on the jersey (or the riders closest arm) or possibly the bike.
There are a few possible solutions, and each has its pluses and minuses... and I think the situation will be similar with either your current camera or a newer mirrorless model:
1. Use a smaller aperture so that precise focus isn't quite as critical. If this means raising the ISO quite a bit, do it. (It is often OK to accept a bit of motion blur in cycling photographs — in fact, done right, they. can contribute to a sense of speed.) One downside is that your background may not be as out of focus as you would like, so try to position yourself so that the background won't be too distracting. (Here, too, a shutter speed slow enough to allow some blur can help — if you pan with the riders the motion will blur and deemphasize details in the background.)
2. Move the AF point to the upper right (in my example, or wherever it needs to be) so that the camera is more likely to AF on the riders' faces. Even just moving it up and keeping it in the center can help. To make this work, you'll need to become adept at quickly moving the AF point around... and keep track of where you have put it.
3. Don't frame the riders quite so tightly, be careful to put the center-positioned AF point on their faces (or something at the same distance), and be prepared to crop out extraneous stuff in post. (You'll likely end up cropping out stuff above the riders' heads and occasionally missing their lower legs/feet.) The minus of this approach is obvious, but the plus is that with fast-moving action you may not need to frame quite so accurately.
4. Try different ways of composing. If framing that includes the cyclist and bike puts the necessary focus point too high in the frame, then shoot even tighter and focus on the riders' faces using a longer focal length.
Obviously, as you know if you have shot bicycle racing, things move fast and you need to practice a LOT at tracking riders at speed and keeping them under the AF point. That won't be any easier with mirrorless... and the slight display latency of mirrorless systems may make that a big more difficult.
The pre-focus method can work, in particular if you hope to catch a rider coming straight at you at speed. Basically pick the spot, then burst a sequence as the rider approaches.
Finally, having a functional camera with decent capabilities helps, but as is so often the case a lot of what makes this work is more about technique than about gear.
Good luck.
http://gallery.gdanmitchell.com/gallery/var/albums/HumanWorld/Sports/album_002/ArmstrongTimeTrial20090214.jpg
Edited on Oct 23, 2021 at 12:48 PM · View previous versions
Oct 23, 2021 at 09:20 AM
JohnSil
p.1 #9 · Should I Replace My 1Dxll and 5Ds w/The R5?
Lighthound, no doubt this would likely be the case! The amount of mirrorless tech packed into that camera is amazing!
John
Oct 23, 2021 at 09:57 AM
JohnSil
p.1 #10 · Should I Replace My 1Dxll and 5Ds w/The R5?
Yes that was wishful thinking. If I had to have it I can always keep my 1Dxmkl and sell the mkll.
I got the mkll for whatever benefits it could provide over the mkl but mainly for the video which I don't use much but the R5 has an even better video.
John
Oct 23, 2021 at 10:04 AM
JohnSil
p.1 #11 · Should I Replace My 1Dxll and 5Ds w/The R5?
Thanks Speed. The 5s is the one I'd want to trade out the most to make portraits a lot easier and more accurate in the focus dept. Since the R5 is only 5mp less I doubt I'd miss those 5mp at all and to shoot sports at high mp would be very cool. I could still shoot the second card at lower Jpeg for when I have same day deadline delivery needs.
John
Oct 23, 2021 at 10:11 AM
JohnSil
p.1 #12 · Should I Replace My 1Dxll and 5Ds w/The R5?
Dan thanks for the detailed suggestions to use for cycling!
No doubt there would be a new learning curve to get the camera to give the best results for all of the aspects that I shoot.
But like most not all of my shooting is specialized with a mix of travel, landscape and just everyday shooting.
I would just need to set up a very convenient button to handle +/- EV to help the exposures along a bit.
And sadly as you probably know my favorite event, the Tour of California is no more, I loved shooting those finish lines!!!
Thanks Dan
John
Oct 23, 2021 at 10:21 AM
JohnSil
p.1 #13 · Should I Replace My 1Dxll and 5Ds w/The R5?
Thanks to all that have replied so far.
I'm just glad there are so many early risers in the group!
If it wasn't for work, I sleep in till NOON everyday!!! LoL
John
Oct 23, 2021 at 10:23 AM
lighthound
p.1 #14 · Should I Replace My 1Dxll and 5Ds w/The R5?
John, another thing to keep in mind as you are considering this upgrade is this "rolling shutter" garbage you keep hearing about out there on the web. Yes the R5 can in some very niche shooting scenarios show this phenomenon while shooting in ES @ 20fps, but it's very rare and doesn't exist in MS.
So unless you plan on shooting humming birds or barn swallows in flight against a busy BG for a living, there is no need to worry much about it. For cycling events, if you need 20fps, you might see some leaning trees in the BG as you pan with the cyclist flying past you at 90 degrees from your position if there are things such as trees directly behind them somewhat in focus.
I have also seen some sports photogs report that the R5 is useless for sports and then they show a single frame showing a distorted ball as a bat or foot hits it. What is always missing is the other 10 frames (5 before and 5 after) that they fired off surrounding the frame they show. My guess would be they are cherry picking the worst frame to prove their point against using the R5 for sports. This is just a guess as I'm not a sports shooter, but I'd love to see these claims posted with ALL the frames surrounding this moment in time. And at the actual frame size they would be using, not zoomed in on the ball.
Pick-up an R5 and give it a try. There is a learning curve to become proficient with it due to all the various settings so you'll need a little time with it. When I received mine last year at the end of July, I had less then 2 weeks to figure it out before our Alaska trip. I came home with the best wildlife images I've ever captured.
If it doesn't work for you just return it within 30 days for a full refund.
But just a warning, you wont be returning it.
Oct 23, 2021 at 11:04 AM
Sy Sez
p.1 #15 · Should I Replace My 1Dxll and 5Ds w/The R5?
My take:
Model #'s aside, the primary choice is SLR VS Mirrorless.
The EOS R5 is one of the most sophisticated, all-around, state of the art Cameras available; but that doesn't mean that you won't encounter any tradeoffs, or at times encounter some functions that seemed to work better on your DSLR's.
For me the PRO's outweigh the CON's, and I have no regrets of switching to R5 / RF system, but like any "new" technology", there's always a "Learning Curve" which some find acceptably challenging---Other's a royal PITA
Oct 23, 2021 at 11:34 AM
JohnSil
p.1 #16 · Should I Replace My 1Dxll and 5Ds w/The R5?
Currently i rarely use a high burst rate. I prefer around 7 fps. I don't see even using ES other than it being silent which at times could help. Maybe I'll reconsider when I shoot hummingbirds!!!
Thanks, John
Oct 23, 2021 at 11:53 AM
Bernie_King
p.1 #17 · Should I Replace My 1Dxll and 5Ds w/The R5?
Had a 1DX and a 1DX Mark II. Replaced them with an R6 and an R5 and never missed them once. With that being said, you may like the R3 better since it is designed more toward the shooting that you do. I know that once my R3 comes, the R6 will be sold. No rolling shutter or blackout, vehicle tracking, and the build you're used to.
Oct 23, 2021 at 02:09 PM
stanj
p.1 #18 · Should I Replace My 1Dxll and 5Ds w/The R5?
I got rid of my 1DX2 and 5DSR in favor of two R5 and haven't looked back once. So much better in every regard, maybe modulo war and water proofing, but I don't have to handle either.
Oct 23, 2021 at 03:01 PM
mdvaden
p.1 #19 · Should I Replace My 1Dxll and 5Ds w/The R5?
So reading your post, reminds me where I felt shots from my 5DS locked focus behind the subject. Those times were each with a Tamron 70-200mm at a distance. At 25 feet and closer I'd get most everything sharply focused. I sold my 5DS couple months ago to get an R6. So happened, I missed the 50mp and wondered whether to add more cash for an R5 but it would mean going with 2 bodies. I enjoy having 3 bodies. Two for weddings, with a 3rd spare to always ensure I can strap two bodies with two lenses. So I recently added a 5DS R
For the cost of an R5, you could have an R6 plus the 5DS / 5DSR
Oct 23, 2021 at 05:17 PM
JohnSil
p.1 #20 · Should I Replace My 1Dxll and 5Ds w/The R5?
Where kinda in the same boat. One high mp camera and one low mp camera.
Currently the 1D does so much that the 5Ds can't do, as it should be, it's a pro body!
But the R5 is nipping at it's heels in almost every dept, except weather sealing!
I need the high mp of the 5s and that's something the r# can't even come close to. With the R3, as good as IT is I would still need 2 cameras, one to handle the high mp.
From everything I've read and herd in the past year the R5 has few shortcomings, it's just how the new wave of cameras are going to be.
I'm not at all unhappy with the 1D, it's the focus shortfalls of the 5s that are pushing me to the R5 and the fact that other than sealing it's a close second to the 1D.
I might pick up a dirt cheap 7Dll as a back-up in the very rare event of a failure. I usually shoot sports with two bodies, a wide angle and a tele.
Thanks
John
Oct 23, 2021 at 07:51 PM
       2       3       4       5       end
       2       3       4       5       end
