sb700 off camera triggering
irlfan82
p.1 #1 · sb700 off camera triggering
So i have Nikon D7000 and a SB700 flash, i would like to be able to trigger the flash with out using the pop up flash. Id like to be able to use the ittl because i have no experience with the flash let alone using it in manaul mode..thanks
Dec 22, 2012 at 01:02 AM
fsiagian
p.1 #2 · sb700 off camera triggering
You need to use the pop-up flash to trigger the sb700 remotely.
Dec 22, 2012 at 01:09 AM
irlfan82
p.1 #3 · sb700 off camera triggering
dont they make something to go into the hot shoe to trigger the flash in ittl mode
Dec 22, 2012 at 01:24 AM
BrianO
p.1 #4 · sb700 off camera triggering
irlfan82 wrote: dont they make something to go into the hot shoe to trigger the flash in ittl mode
Yes, you can get a Pocket Wizard MiniTT1 transmitter or Flex TT5 transceiver to mount in the hot shoe, and use a Flex TT5 as a receiver onto which you would mount the SB-700. The PW's ControlTL functions are iTTL-compatible.
May I ask, though, why you don't want to use the pop-up, which is "free," as the commander?
(BTW, are you in Onalaska, WA; Onalaska, WI; Onalaska, Tx; or some Onalaska that I'm not familiar with?)
Dec 22, 2012 at 04:03 AM
fsiagian
p.1 #5 · sb700 off camera triggering
+1
Dec 22, 2012 at 04:11 AM
Bruce Sawle
p.1 #6 · sb700 off camera triggering
SU-800 goes on hot show and will trigger the flash.
Dec 22, 2012 at 04:17 AM
BrianO
p.1 #7 · sb700 off camera triggering
Bruce Sawle wrote: SU-800 goes on hot [shoe,] and will trigger the flash.
Canon's ST-E2 is so underwelming (IMO) that I keep forgetting about Nikon's far superior (also IMO) SU-800.
It has the same line-of-sight limitations as using the pop-up would, but it has more power and it's infra-red rather than visible-light; and it's a lot less expensive than the Pocket Wizard iTTL options.
Dec 22, 2012 at 04:40 AM
pacman642
p.1 #8 · sb700 off camera triggering
I have both the SU-800 and the the Pocket Wizard Flex system. I prefer the pocket wizard, for a couple of reasons, outdoor use can interfere with infrared on the SU-800 and the ability to Hyper sync the pocket wizard.
Dec 22, 2012 at 03:09 PM
irlfan82
p.1 #9 · sb700 off camera triggering
Onalaska WI.
.im just thinking that if i want to light up something on just the sides or back i dont have to use or block the pop up flash..
Dec 22, 2012 at 06:34 PM
fsiagian
p.1 #10 · sb700 off camera triggering
Why not, it's free Use it first. If you have reached the limit, than you can get the Pocket Wizard.
Dec 22, 2012 at 06:37 PM
BrianO
p.1 #11 · sb700 off camera triggering
irlfan82 wrote: Onalaska WI.
Well, I won't be dropping by to say hello, then. (I used to work near Onalaska, WA, and still get down there from time to time. Wisconsin? Not so much.)
irlfan82 wrote: ...im just thinking that if i want to light up something on just the sides or back i dont have to use or block the pop up flash..
If the Nikon system is like the Canon system (and I'm pretty sure it is, in this respect) you can set the pop-up not to fire for exposure, but only the command-and-control preflashes. If you're shooting close up or have a reflective background, the last command pulse may be slightly visible, but you can shield it from the subject with this:
http://www.bhphotovideo.com/c/product/410445-REG/Nikon_4905_SG_3IR_IR_Panel_for.html
For $12.00 it's worth experimenting, in my opinion, before deciding if you really need to shell out the bigger bucks for an SU-800 or Pocket Wizards.
Dec 22, 2012 at 07:25 PM
irlfan82
p.1 #12 · sb700 off camera triggering
yea i looked up the su 800 and didnt realize it was that much. i think i will give the ir panel a shot seeing its only $12.
Dec 23, 2012 at 02:01 AM
rdl65
p.1 #13 · sb700 off camera triggering
You can use your pop up flash on the D7000 to trigger the SB700 but also not have the pop up fire. Check out this youtube video.
http://www.youtube.com/watch?v=NRP2jSTax9A
Dec 23, 2012 at 02:08 PM
ozpall
p.1 #14 · sb700 off camera triggering
Set the pop up power to -- that's it.
Dec 24, 2012 at 04:18 AM
BrianO
p.1 #15 · sb700 off camera triggering
rdl65 wrote: You can use your pop up flash on the D7000 to trigger the SB700 but also not have the pop up fire.
ozpall wrote: Set the pop up power to -- that's it.
The pop-up's light may still be visible, even when set not to fire -- if there's a reflective object in the scene, or if the camera is very close to the subject. (The final command pulse obviously has to fire after the shutter opens.) That's why Nikon offers the IR Filter for the pop-up.
Dec 24, 2012 at 04:30 AM
Brody LeBlanc
p.1 #16 · sb700 off camera triggering
On the flip side, I know what you mean that all the settings on the Sb700 are kind of intimidating. I remember when I first bought one, the menu looked like a maze in comparison to the (somewhat lacking) menu set up on the Sb-700. If you stick to using manual mode while shooting for a couple hours, you'll catch on really quickly. I usually have better luck in manual mode when shooting off camera, but I suppose it depends on what you're shooting.
This is what I usually do when doing a quick on-location lighting set up: Figure out the best setting for the ambient light with the flash(es) turned off, then turn them on set to the lowest power and move up the power on the flash unit up until you like what you're seeing. Then check out your histogram while reviewing the shots.
After doing this a few times, you'll get better at estimating what to set your flash too.
I shoot a venue where I almost always set my flash to 1/16, my camera's shutter speed to 1/60th, my aperture to f2.8 and my iso to 2500, but I got to these setting by doing what I recommended first.
Jan 02, 2013 at 06:56 PM
