fredmiranda.com Login
This topic is in the 2008 archive. You can read it and like its posts here. It is read only.
Archive 2008Hard time with D3 focus ...
Brooke Clyde
p.1 #1Hard time with D3 focus ...
I know, this is either sacrilege or I'm an idiot. Or both.
Even with the 24-70 and 70-200 VR (it's worse with the 105 DC), I'm having trouble getting focus lock in medium to low light. Lots of hunting, often a couple of times back/forth, with multiple re-trys at the AF button. I'm using a single AF point (+9 in Dynamic mode) in both modes other than Auto. Sorry, don't have the lingo down (or my manual handy).
I'm waiting for the D'oh moment, when my obvious mistake reveals itself, but it won't come. I'm used to the Canon scheme, but I don't believe that in general the Nikons are so different that my Canon technique could be the problem, but
Jan 23, 2008 at 06:24 PM
icapture.it
Details
p.1 #2Hard time with D3 focus ...
I'm having the same problem. Been told by others that I'm nuts. It might be true but as for the focus issues, I think they are really happening. I can reproduce it anywhere anytime and I never had the problem with my D200 at all so I am sure it is not my technique.
Jan 23, 2008 at 06:31 PM
HerbChong
Details
p.1 #3Hard time with D3 focus ...
take the camera and one of your lenses to a shop and try their D3 on your lenses and vice versa. i bet the body is defective.
Herb...
Jan 23, 2008 at 06:50 PM
Brooke Clyde
Details
p.1 #4Hard time with D3 focus ...
Friggin' great ... That's why I left Canon ...
I was kind of hoping that someone would have something simple that I was missing or doing wrong ...
Jan 23, 2008 at 07:03 PM
Joseph R Herr
Details
p.1 #5Hard time with D3 focus ...
Difference is, you just got a bad camera in a bad batch... ALL of the Canons come out that way
Jan 23, 2008 at 07:37 PM
spdntrxi
Details
p.1 #6Hard time with D3 focus ...
you are not nuts.. low light yes..medium light it should be ok.. there are known issues with 105DC and 200 F/2. Focus lock is on the slow side, but very accurate once it locks.
Jan 23, 2008 at 07:38 PM
James R
Details
p.1 #7Hard time with D3 focus ...
...Show more →
I have not had that problem in medium to low light (including 24-70 and 70-200), of course what each of us consider low light can leave some room for interpretation. My D3 is set on AF 21 pts., focus mode: S, and AF-area mode: single-point AF (dynamic is also fine). This seems to work for me. Make sure you are not in Continuous servo-AF. It is easy to accidentally move the selector from S to C.
Edited on Jan 23, 2008 at 07:58 PM
Jan 23, 2008 at 07:57 PM
Danya Plontz
Details
p.1 #8Hard time with D3 focus ...
Are you putting the focus sensor on a defined edge? if you aim it at all white spot or all black spot in low light, it will hunt.
It sounds like an obvious thing, but i thought i would chime in, hope you get it resolved soon.
Jan 23, 2008 at 08:02 PM
bcaslis
Details
p.1 #9Hard time with D3 focus ...
I have seen this to some extent. I think one of the issues is that the D3 is trying to get lock with a single tiny AF point (51 points). Unlike the Canon 1D, for example, the expansion points are not used to acquire focus, only to maintain focus on something once locked. So with the little itty bitty AF point, it's somewhat easy to point it at something with not enough contrast under that one AF point. If I make really really sure the AF point is on something with contrast, it locks right away, but if the point doesn't have enough contrast in low light it sometimes hunts or fails to get focus.
But I'll take that issue instead of my 1D3 telling me it had focus and getting soft or blurry picture any day.
Jan 23, 2008 at 08:04 PM
bcaslis
Details
p.1 #10Hard time with D3 focus ...
Slow focus on the 200 f2.0 on a D3? I must be very lucky because this combo for me is the fastest focusing think I've ever seen.
Jan 23, 2008 at 08:05 PM
Brooke Clyde
Details
p.1 #11Hard time with D3 focus ...
Usually I'm AFing on an eye ... Kind of low contrast, I guess ...
Jan 23, 2008 at 08:20 PM
HerbChong
Details
p.1 #12Hard time with D3 focus ...
an eye is fine. i AF on birds eyes from a long way away with my 600/4. you probably have a defective camera, but to be sure. you need to test a different body.
Herb...
Jan 23, 2008 at 08:32 PM
Dan Bellyk
Details
p.1 #13Hard time with D3 focus ...
Brooke has it been doing it from the start?
Did you try doing a reset on everything?
With or without flash?
Best of luck
Jan 23, 2008 at 08:37 PM
jharwell
Details
p.1 #14Hard time with D3 focus ...
Brooke,
Dial in + 20 in the custom menu (front back focus adjustment) for the 105dc and it should fix it. I had the same problem.
Jan 23, 2008 at 09:20 PM
Brooke Clyde
Details
p.1 #15Hard time with D3 focus ...
Hey, I'll try anything, but why would this work? It's not that the AF is inaccurate when it locks, just that it hunts.
Tomorrow I'll reproduce it and post the level of light I'm talking about ...
Thanks all.
Jan 23, 2008 at 09:38 PM
Brooke Clyde
Details
p.1 #16Hard time with D3 focus ...
Hey! This is interesting ...
On a lark I tried a test in my darkened hallway. Light level: 1/25, f/2, ISO 6400. Subject is an original Peanuts Sunday comic strip. I figured the thin black frame would be something great for the AF to find, but it hunted as described earlier. However, when I tried the text, it locked fast and true. Smaller, finer detail ...
Below is a pic of the subject (this is taken with a flash). I do note some front focusing -- the AF was on Snoopy in the center frame. BTW, if you can't read it, the last frame has Snoopy thinking: "I can't believe it took me three years to think of that."
Edited on Jan 23, 2008 at 09:57 PM
Jan 23, 2008 at 09:52 PM
rffffffff
Details
p.1 #17Hard time with D3 focus ...
I too think the sensors are a little too small, lending itself to this problem...
On the other hand, my D2X seems to love backgrounds more than people lately, so at least when the D3 focuses you are 100% sure of what its on.
I have not shot sports with it yet, and I have not tried a whole lof of af-c, but I can't tell you that I think its going to be super accurate at tracking large monotone subjects, perhaps like a dog, or a solid color t shirt on a kid.
We'll see as the weather warms a little, but for now I'm a little more 'detail' oriented in the approach it forces me to take.
Jan 23, 2008 at 10:47 PM
Osai
Details
p.1 #18Hard time with D3 focus ...
Very true.
Jan 23, 2008 at 11:18 PM
Danya Plontz
Details
p.1 #19Hard time with D3 focus ...
Brooke...have you tried the 21 point, or i think its 7 point AF setting?
I am inclined to think that the lower the number for this setting, the bigger the focus point will be, allowing you to focus in those hard to get low light compositions. I might be wrong, i only have borrowed a D300 twice for a half day at a time but i found much better AF using the 7 point ( i think ) setting.
At least try that in low light and see if it makes a difference, if it does i am willing to bet you dont have a defective camera, rather you just have a small and very finicky focus point in the 51 point array.
Whenever i get a hunting sensor on my D2X i look for high contrast edges to make sure its not the camera, as soon as i find one...ZIP.... it tightens on the subject like lightning.
As good as these cameras are, they still cant perform miracles in every situation, you just gotta figure out how to work with what you have
good luck.
Jan 24, 2008 at 12:28 AM
Brooke Clyde
Details
p.1 #20Hard time with D3 focus ...
I usually use the fewest points I can -- so now I'm on 9 -- because I shoot a lot of sports and the more you load up the CPU, the slower the AF. I'm still experimenting, but after the Snoopy test, I'm feeling better ... :-)
Edited on Jan 24, 2008 at 12:47 AM
FM ForumsNikon ForumJoin Upload & Sell
