       2       3       4       end
Z6III Firmware 2.00 now available
kwalsh
p.1 #1 · Z6III Firmware 2.00 now available
It has a whole host of changes, many of which are catch-up features to match releases for other cameras:
https://downloadcenter.nikonimglib.com/en/download/fw/571.html
Probably easier to read the changes at the link above, but copy and paste here as well:
■ Still Photography
• Added [Birds] to [AF/MF subject detection options] in the photo shooting menu.
• The maximum shooting display zoom ratio is now 400%.
• Added [Auto capture] to the photo shooting menu. Users can select capture criteria from [Motion] (the direction the subject is moving), [Distance] (how far the subject is from the camera), and [Subject detection] (whether or not a subject of a given type is detected), and the camera will take photographs automatically while it detects subjects that meet the selected criteria. Note that [Distance] is available with NIKKOR Z lenses and may not function as expected when used with other lenses. The [FX (36Χ24)] and [DX (24Χ16)] image areas are available with auto capture.
• Added a [C15] high-speed frame capture + release mode option.
• The image quality for high-speed frame capture + can now be set separately from other release modes.
• [Options] has been added under [Focus shift shooting] in the [PHOTO SHOOTING MENU] to allow [Pixel shift shooting] to be used together with focus shift shooting.
• [Options] has been added under [Pixel shift shooting] in the [PHOTO SHOOTING MENU] to allow [AE bracketing] to be used together with pixel shift shooting. [Starting storage folder] has also been added.
• [Pixel shift shooting] options can now be set when the self-timer mode is selected.
• The Profoto A10’s continuous LED light can now be used as an AF-assist illuminator.
Note: The firmware update is needed for Profoto A10. See Profoto’s corporate website for details.
■ Video Recording
• Added [Birds] to [AF/MF subject detection options] > [Subject detection] in the video recording menu.
• Added [Auto capture] to the video recording menu. Users can select capture criteria from [Motion] (the direction the subject is moving), [Distance] (how far the subject is from the camera), and [Subject detection] (whether or not a subject of a given type is detected), and the camera will record video automatically while it detects subjects that meet the selected criteria. Note that [Distance] is available with NIKKOR Z lenses and may not function as expected when used with other lenses. The [FX] and [DX] image areas are available with auto capture.
• The color of the in-focus AF-area brackets shown on the shooting display when Hi-Res Zoom is enabled has been changed.
• Hi-Res Zoom operations can now be performed using the sub-selector.
• Selecting [ON] for [Hi-Res Zoom] in the [VIDEO RECORDING MENU] now displays a focus point on the detected subject in the shooting display.
• Added a function to include file names used in the camera when recording videos to an external recorder that supports file name transmission via HDMI. The following Atomos external recorders support this function (as of August 2025).
- Ninja V *
- Ninja V+ *
- Ninja (2023 models)
- Ninja Ultra
- Shogun (2023 models)
- Shogun Ultra
- Shogun Connect *
* Some recorders may require an ATOMOS OS upgrade or paid activation of the recorder. Contact ATOMOS for details.
■ Playback
• Added [Loop playback] in the playback “i” menu.
• Added [Playback speed] in the video playback “i” menu.
• Added [Record camera orientation] in the playback menu.
• Added [Auto series playback options] to [Series playback] in the playback menu.
• Made changes to the [Select for upload to computer] and [Select for upload (FTP)] items in the playback “i” menu and added [Select for priority upload to computer] and [Select for priority upload (FTP)].
• Added [Date] to [Filtered playback criteria] in playback menu and playback “i” menu.
• Added [Customize retouch options] to [Retouch] in the playback “i” menu.
• Added [Auto-rotate during playback] to the playback menu.
■ Controls
• Added support for the Nikon Authenticity Service.
* The Nikon Authenticity Service enhances content credibility by using provenance information and other data in accordance with the C2PA standards.
* You must register with Nikon Imaging Cloud and apply for use of the service.
* The Nikon Authenticity Service may not be available in some countries and regions.
• Added [Focus point border width] to a10 [Focus point display] in the [CUSTOM SETTINGS MENU].
• Added a [Maximum aperture Lv] item to the [CUSTOM SETTINGS MENU] in position of a13.
• Added a [Focus limiter setting] item to the [CUSTOM SETTINGS MENU] in position of a15.
• Added a [Minimum] option to Custom Setting c2 [Self-timer] > [Interval between shots] in the [CUSTOM SETTINGS MENU].
• Added [Half-press to cancel zoom (MF)] item to the [CUSTOM SETTINGS MENU] in positions d19 and g18.
• Added [Auto capture] to the roles assignable to the “i” menu via [CUSTOM SETTINGS MENU] > f1 and g1 [Customize <i> menu].
• Added assignable custom controls and roles to the following items in the [CUSTOM SETTINGS MENU]. Also, the options for [Zoom on/off] have changed.
- f2[Custom controls (shooting)]
- f3[Custom controls (playback)]
- g2[Custom controls]
Choose [Prefer focus point] or [Prefer focus point (face priority)] for f3 [Custom controls (playback)] > [Main command dial] or [Sub-command dial] > [Frame advance zoom position].
The settings for f3 [Custom controls (playback)] > [Main command dial] or [Sub-command dial] > [Frame advance] can now be applied during playback zoom.
• Added assignable custom controls and roles (for example, [Jump to the source image] and [Trim]) to [CUSTOM SETTINGS MENU] > f3 [Custom controls (playback)].
• Made changes to the f4 [Touch Fn] > [Move focus point] item in the [CUSTOM SETTINGS MENU].
• Changes have been made to how a full format is performed with [Format memory card] in the [SETUP MENU].
• Made updates to [Non-CPU lens data] in the [SETUP MENU].
• Added [Automatic monitor display switch] to the [SETUP MENU].
■ Network
• Added [USB streaming (UVC/UAC)] to [USB] in the [NETWORK MENU].
• A warning now appears when the connection to an ATOMOS AirGlu BT accessory is unstable or disrupted.
• Changed some messages and the default values related to Nikon Imaging Cloud.
• A new method for adding Picture Controls from Nikon Imaging Cloud is now available.
• ATOMOS AirGlu BT accessories and MC-N10 remote grips can now be used together.
• Made changes and additions to the [Connect to FTP server] item in the [NETWORK MENU].
• Changed the procedure used when configuring the camera for synchronized release, increasing to twenty the number of groups that can be created, while the number of cameras in each group that can be controlled from the master camera has been increased to sixteen.
• Added [Group settings] and [Overwrite copyright info] to [Connect to other cameras] in the [NETWORK MENU].
■ Other Changes
• Changed the specifications for uninterrupted video output to HDMI devices such as external monitors when recording ended.
• The headphone volume level can now be adjusted in the “i” menu during video recording.
• Direct measurement of white balance is now available also for still photography via applications, such as NX Tether.
• Voice memo recording is now available with external microphones.
• The tonal characteristics have been changed when [ON] is selected for Custom Setting g13 [View assist] in the [CUSTOM SETTINGS MENU].
• The camera now records company and model names in the video metadata recorded with [ProRes 422 HQ 10-bit (MOV)] selected for [Video file type] in the [VIDEO RECORDING MENU].
• Added support for “NX Field*”, a remote shooting system for corporate users.
* Visit the “NPS” website for overview and user’s manual of NX Field.
Nikon Professional Services (NPS) (English)
Note: “NX Field” app for smart devices may not be available in some countries and regions.
• Automatically obtained IP address will be maintained after automatic IP addressing disabled.
Aug 26, 2025 at 10:59 PM
Todd Warnke
p.1 #2 · Z6III Firmware 2.00 now available
C2PA ... that's huge.
Aug 26, 2025 at 11:07 PM
MikeEvangelist
p.1 #3 · Z6III Firmware 2.00 now available
Update applied with no issues. Yay for bird detection mode!
Aug 26, 2025 at 11:12 PM
PIOK
p.1 #4 · Z6III Firmware 2.00 now available
Aug 26, 2025 at 11:20 PM
Jman13
p.1 #5 · Z6III Firmware 2.00 now available
Oh thank god. Honestly, while I’m so glad to have bird AF, detailed adapted lens info, and all the other improvements, the biggest quality of life upgrade is the thicker focus box. I’ve been dying for this update to finally bring it to the Z6 III.
Aug 26, 2025 at 11:55 PM
RoamingScott
p.1 #6 · Z6III Firmware 2.00 now available
It’s about damn time!
Aug 26, 2025 at 11:56 PM
bernardl
p.1 #7 · Z6III Firmware 2.00 now available
Busy summer for Nikon's engineers!
Who will be the first to complain about the lack of Z9 firmware update?
Cheers,
Bernard
Aug 27, 2025 at 12:48 AM
snapsy
p.1 #8 · Z6III Firmware 2.00 now available
It's not in the firmware 2.0 change list but Recall Shooting Functions was added as well. See page 54-55 of the firmware 2.0 supplement manual:
https://download.nikonimglib.com/archive7/IwQ9S00GTXTH07DygKL32LUmx019/Z6III_FU_addendum_(En)04.pdf
Aug 27, 2025 at 01:25 AM
jlafferty
p.1 #9 · Z6III Firmware 2.00 now available
Insane. This was for my uses the only thing missing from the shooting experience, and I’d accepted they were probably not going to address it, possibly ever. Hot damn.
Aug 27, 2025 at 02:52 AM
JeffMD
p.1 #10 · Z6III Firmware 2.00 now available
I don’t see it on the list but “Cycle AF Mode” was apparently added to the custom button options. My Z8 does it and I miss it on the Z6III.
I have a wedding to shoot Friday so I’m probably not going to update until after that.
I do wish they would add the ability to cycle subject detection on and off via a custom button. That’s one of the few things that would improve my event shooting days.
Aug 27, 2025 at 06:48 AM
RoamingScott
p.1 #11 · Z6III Firmware 2.00 now available
Didn’t they just add recall? Should be able to do it now via that.
Aug 27, 2025 at 07:14 AM
EeyoreSadFace
p.1 #12 · Z6III Firmware 2.00 now available
Welp I know what I'll be doing when I get home from work. Bird AF is super appreciated but some of these other additions will be nice quality of life changes as well.
Aug 27, 2025 at 07:46 AM
indusphoto
p.1 #13 · Z6III Firmware 2.00 now available
You can, but since there is only one of the recall settings, you have to make a judicious choice how to use that. (or did nikon implement one recall setting for each U setting? if so that would be great and beat the Z8/Z9)
A dedicated subject detection toggle and subject type cycle should be on Nikon's next priority to implement across the lineup. They are the only one of big three to not have these features.
Edited on Aug 27, 2025 at 11:11 AM · View previous versions
Aug 27, 2025 at 07:51 AM
snapsy
p.1 #14 · Z6III Firmware 2.00 now available
A dedicated subject detection toggle and subject type cycle should be on Nikon's next priority to implement across the lineup. They are the ony one of big three to not have these features.
Just checked and they implemented unique recall settings for each U position. Fantastic!
Aug 27, 2025 at 08:06 AM
RoamingScott
p.1 #15 · Z6III Firmware 2.00 now available
Overall I agree with you. I personally have little interest in most of the recall settings for my day-to-day shooting, so burning a custom function just for subject detection on and off would be a win for me.
JeffMD
p.1 #16 · Z6III Firmware 2.00 now available
I 100% would burn a button for subject detection toggling.
Aug 27, 2025 at 08:28 AM
rick-reno
p.1 #17 · Z6III Firmware 2.00 now available
C2PA! Maybe this will show up in other Z bodies.
Aug 27, 2025 at 08:37 AM
Jman13
p.1 #18 · Z6III Firmware 2.00 now available
Has anyone gotten the C2PA to actually show credentials in image?
I registered the camera, downloaded the certificate and credentials are on. But if upload an image taken after this is enabled to the C2PA verify tool it shows no credential on the image.
Aug 27, 2025 at 08:40 AM
snapsy
p.1 #19 · Z6III Firmware 2.00 now available
I tested it and it doesn't seem to be working. I was able to request and install a certificate and turn on the feature. When I take a photo it shows an icon during playback that the photo has credentials. But when I upload the photo to CAI's verify tool it reports no credentials found.
Wezre
p.1 #20 · Z6III Firmware 2.00 now available
Cheers,
Bernard
The Z9 users who rightfully should be the first to have the latest features on their flagship cameras. And yet...
Aug 27, 2025 at 08:49 AM
       2       3       4       end
       2       3       4       end
