       2       3       4       5       end
Leica Screw Dot: Replace the Red Dot
Admin
p.1 #1 · Leica Screw Dot: Replace the Red Dot
I discovered a company on Instagram that has created a screw dot, similar to what Leica uses for their “P” versions, machined from brass. Many Leica users tape over their cameras’ red dots to make them less conspicuous, especially when traveling. However, over time, tape adhesive can leave a messy residue on the red dot and camera paint.
Leicascrew.com has solved this problem by machining a screw dot that matches the camera's paint. Not only does it look great, but it also makes it much easier to remove for vertical rangefinder alignment. I've posted some images showing my Leica M11 with the regular red dot and with the screw dot replacement.
I think it looks fantastic and stays flush to the camera body.
Removing the red dot to use the screw dot might seem daunting, but the process is quick and easy. Here’s what I did:
Materials Needed
  1. Hair dryer or heat gun
  2. Two toothpicks or similar small sticks (I used very thin Q-Tips)
  3. Pure isopropyl alcohol
  4. Microfiber cloth
Steps
  1. Apply Isopropyl Alcohol:
    Use a cotton swab to apply a small amount of isopropyl alcohol around the edges of the red dot. The alcohol will help break down the adhesive. Let it sit for about 2-3 minutes to allow it to penetrate the adhesive.
  2. Heat the Red Dot:
    Use a hair dryer or heat gun on a low setting to gently warm the red dot. Hold the dryer about 6-8 inches away and move it in a circular motion for about 1-2 minutes. The heat will further soften the adhesive.
  3. Prepare the Sticks:
    Take two toothpicks or similar small sticks that are sturdy enough to apply a bit of pressure but gentle enough not to scratch the surface.
  4. Position the Sticks:
    Place the tips of the sticks on opposite sides of the Leica logo on the red dot. Ensure they are positioned securely.
  5. Turn the Red Dot:
    Apply gentle, steady pressure to the sticks, turning them in opposite directions. This should help break the adhesive bond and rotate the red dot slightly.
After rotating the dot a few turns, it comes off without any damage to either the dot or the camera.
The screw dot comes with three self-adhesive pads, which can be used to secure the new dot to the camera.
The entire process took me about 5 minutes from start to finish. Very easy. LeicaScrew mentioned that he developed black, silver, and "pure brass" screw dots to match any Leica M model, whether digital or film. It even works for the Q series.
I had considered doing this myself in the past, and I'm glad it's now being done professionally. I highly recommend these screw dots.
You can find them on LeicaScrew's website: https://www.leicascrew.com/
Leica M11 with original red dot
Leica M11 with black screw dot
Oct 11, 2024 at 01:42 PM
hncc.photo
p.1 #2 · Leica Screw Dot: Replace the Red Dot
Ags.supply offers these for $37, and I already found that ridiculously expensive.
Oct 11, 2024 at 01:56 PM
Admin
p.1 #3 · Leica Screw Dot: Replace the Red Dot
Thanks for the info. I wasn't aware of Ags.supply. It looks like they currently sell a black screw dot, but not silver or pure brass.
Oct 11, 2024 at 02:05 PM
Adamwilbert
p.1 #4 · Leica Screw Dot: Replace the Red Dot
Looks like the ags.supply one is an adhesive based solution, whereas Leica Screw is an actual screw replacement?
Oct 11, 2024 at 02:18 PM
Desmolicious
p.1 #5 · Leica Screw Dot: Replace the Red Dot
$68 for a screw? Ok that joke almost writes itself.
Edited on Oct 11, 2024 at 02:33 PM · View previous versions
Oct 11, 2024 at 02:30 PM
Desmolicious
p.1 #6 · Leica Screw Dot: Replace the Red Dot
From ags' website:
All dots come with adhesive pre-applied to the back.
Oct 11, 2024 at 02:32 PM
Adamwilbert
p.1 #7 · Leica Screw Dot: Replace the Red Dot
Yes my question was about the Leica screw not the ags solution, but reading more it sounds like they’re both adhesive stick on things. The price does seem quite high, though I admit, I prefer the look.
Desmolicious wrote:
From ags' website:
Oct 11, 2024 at 02:50 PM
Lee Paul
p.1 #8 · Leica Screw Dot: Replace the Red Dot
Id actually like an M11-P with the red dot. Unfortunately a standard one from the M11 won’t fit as I’m told the hole is machined differently.
Be great if they could offer a proper red dot logo to fit rhe M11-P.
Oct 11, 2024 at 03:04 PM
Admin
p.1 #9 · Leica Screw Dot: Replace the Red Dot
The Leica screw I tried is made of brass and attaches to the Leica M using a double-sided adhesive, just like the Leica red dot.
Oct 11, 2024 at 03:10 PM
pmeheut
p.1 #10 · Leica Screw Dot: Replace the Red Dot
Yep. I'm gonna stick with black tape.
Oct 11, 2024 at 03:13 PM
Adamwilbert
p.1 #11 · Leica Screw Dot: Replace the Red Dot
Thanks for the info, Fred. It looks nice!
Oct 11, 2024 at 03:17 PM
Admin
p.1 #12 · Leica Screw Dot: Replace the Red Dot
Yes, I liked it too, and it’s good to know there are two sources now. I don’t think Leica can stop this type of product since it doesn’t have the Leica logo on it.
From what I’ve been told, the LeicaScrew site’s painting process is quite complex, involving sandblasting, Cerakote, and a clear coat, all baked at 350 degrees, which may increase the paint’s longevity. I’m not sure about the other site’s paint process.
Oct 11, 2024 at 04:19 PM
Desmolicious
p.1 #13 · Leica Screw Dot: Replace the Red Dot
So it’s a $68 10mm round sticker? Egads man!
Hey can I have your no longer needed tacky red dot? I need it for my latest medium format camera - which cost 60% less than your sticker
Oct 11, 2024 at 04:32 PM
happ
p.1 #14 · Leica Screw Dot: Replace the Red Dot
You've paid less for a screw?
Oct 11, 2024 at 04:59 PM
Desmolicious
p.1 #15 · Leica Screw Dot: Replace the Red Dot
Depends on your standards.
Oct 11, 2024 at 05:16 PM
chez
p.1 #16 · Leica Screw Dot: Replace the Red Dot
I really don’t understand this concept of hiding the make of the camera when one is traveling. If someone leaves their camera out of their sight at any touristy location, it will be gone period whether it has a red dot or not. Thieves are opportunists and will grab anything they can.
Now if it’s the look you are after…then I have not much to say about that. 🙁
Oct 11, 2024 at 07:06 PM
Desmolicious
p.1 #17 · Leica Screw Dot: Replace the Red Dot
Apparently with the ongoing crime spree in the city of Wetzlar, Leica is considering taping up the dot so the building does not go missing.
Oct 11, 2024 at 07:32 PM
retrofocus
p.1 #18 · Leica Screw Dot: Replace the Red Dot
I don't fully agree here from own experience in this matter: several years ago when taking photos with my Leica M6 in Europe, I was approached twice at different locations. The photography-interested bystanders recognized my camera as a Leica due to its red dot. Even both times I had friendly conversations, I felt a bit uncomfortable in this situation where I normally try to blend in and avoid conversations to focus on taking photos instead. I have since taped my red Leica dots with gaffer tape and fully avoided these kind of situations. Without red Leica dot - I also taped the Leica brand name -, the camera looks more like a standard Fuji MLC. To add to this experience, my Leica M 246 monochrome without any red dot nor Leica name has so far never attracted any attention either.
Regarding thievery, it is very dependent on the location. In areas with many tourists, specialized thieves likely know well about differences in camera size and shapes to quickly determine the value. The red dot for sure will be a magnet in this kind of scenario.
Oct 11, 2024 at 08:01 PM
retrofocus
p.1 #19 · Leica Screw Dot: Replace the Red Dot
Piggy-backing on the Leica luxury brand name. Falls almost price-wise in line with getting a nicely crafted hot shoe plate and shutter button instead.
Oct 11, 2024 at 08:10 PM
raizans
p.1 #20 · Leica Screw Dot: Replace the Red Dot
That’s a lot of money for a very big, fake screw. I’m no fan of the red dot, but I’d stick with it over this. To each their own, of course.
Oct 11, 2024 at 08:20 PM
       2       3       4       5       end
       2       3       4       5       end
