fredmiranda.com Login
This topic is in the 2022 archive. You can read it and like its posts here. It is read only.
Archive 2022What’s the latest opinions on protective lens filters?
Younjulius
p.1 #1What’s the latest opinions on protective lens filters?
With the lens price often exceed $2k nowadays, lenses are very expensive investments for most of us. UV filters used to double it’s function as a protective filter, but I’ve heard in the era of mirrorless camera sensors, UV filter is no longer needed.
So, that leaves clear filters for the job of protecting the front element of lenses. Supposedly expensive filters shouldn’t decrease the quality of photos. Having said all these, does it make sense to use protective filters in 2022, or you’re wasting your money? I understand there’s no correct answer to this, and I’m just curious of the latest opinions with today’s lenses with sophisticated coatings.
Jul 17, 2022 at 09:34 PM
LiveShots
Details
p.1 #2What’s the latest opinions on protective lens filters?
If I’m shooting in a dusty or hazardous environment, then I will use a clear glass filter from a reputable company. Otherwise, I do not use one.
I always use a lens hood.
Jul 17, 2022 at 09:41 PM
EdwardDye
Details
p.1 #3What’s the latest opinions on protective lens filters?
It really depends on what you shoot, I shoot events, so filters is a must for protection(I'm not rich enough), the price of replace a front element is very high to me.
Jul 17, 2022 at 09:49 PM
ruthenium
Details
p.1 #4What’s the latest opinions on protective lens filters?
Some filters are useful on their own, e.g. I keep a CPL filter on the Tamron 35-150 most times except in very poor light. Others, such as a B+W 95mm UV Haze clear filter on my Sony 200-600, usefully facilitate cleaning by collecting the dust and other debris, as well as protecting the front glass from accidental scratches in the bush.
Good quality filters do no harm, except that they can be expensive-to-very expensive; however, filters can be expected to have a long life time. Thus, an expense of say $150 - 200 per filter is not unreasonable in the overall scheme of things.
Jul 17, 2022 at 10:04 PM
RoamingScott
[X]
Details
p.1 #5What’s the latest opinions on protective lens filters?
Dusty or near the ocean, sure. Otherwise, never.
I’ve seen WAY too many posts on FM of strange anomalies that wound up being caused by a UV filter.
Jul 17, 2022 at 10:14 PM
Donzo98
Details
p.1 #6What’s the latest opinions on protective lens filters?
I always use them.
Jul 17, 2022 at 10:41 PM
ftllens
Details
p.1 #7What’s the latest opinions on protective lens filters?
If your lens doesn't flare, the UV filter will add that in. Cheap multi-coated AGC/Schott filters from China that costs $10-20 are same IQ as the B/W, Breakthrough X4. Only benefit for pricier ones are brass and form factor.
There are some situations where UV filter is useful like mentioned, and if you don't shoot high specular or flare inducing scenes, then it doesn't matter on or off. Whatever makes you feel better lol
That being said I never use them since I shoot in situations where filter can increase degrading IQ.
Jul 17, 2022 at 10:43 PM
NJPhotographer
Details
p.1 #8What’s the latest opinions on protective lens filters?
If you look at used lenses, you can usually tell which have been protected by a filter and which have not.
Jul 17, 2022 at 11:08 PM
jeffbuzz
Details
p.1 #9What’s the latest opinions on protective lens filters?
Clear protective filters are a form of insurance. Everyone has their own risk tolerance. So everyone has their own perfectly legitimate reasons to use or not use them.
Continuing supply chain disruptions make repair parts more difficult to get than completely assembled goods. Manufacturers allocate what parts they have to fill completely finished goods orders. There are fewer surplus parts available to fill spare / repair inventory. This is effecting many industries, not just photographic equipment.
Most replacement lenses elements, if you can even get them, are only sold in groups. So you often cannot replace only the front element. You have to buy the assembly of elements that includes the front glass. This makes any repair more expensive because parts often can only be sourced in these more expensive units.
Jul 17, 2022 at 11:48 PM
Imagemaster
Details
p.1 #10What’s the latest opinions on protective lens filters?
Never used a UV or protective filter in over 50 years of shooting and never had a front element scratched or damaged. Have always used lens hoods.
But them some of us are more careful than others.
Jul 18, 2022 at 12:25 AM
A.Y.
Details
p.1 #11What’s the latest opinions on protective lens filters?
Always test your lenses with and without an UV filter to see for yourself. I tested all of my lenses and not one showed image degradation with an UV filter; therefore, I always use them! YMMV of course because no two lenses are the same!
Jul 18, 2022 at 02:18 AM
jaybr
Details
p.1 #12What’s the latest opinions on protective lens filters?
...Show more →
I use B+W clear protective filters on all my lenses, except lenses that noticeably lose contrast when flaring. I then use B+W UV filters which tend to slightly minimise the loss of contrast.
J
Jul 18, 2022 at 02:27 AM
jjjwolf7722
Details
p.1 #13What’s the latest opinions on protective lens filters?
Have generally always used them pending the quality of the lens. When I purchase an expensive or like new lens I always put some type of filter on. If the lens is cheap or already has scratches I then tend to go without a filter.
In general I like the protection aspect of lens filters. Busy family means often I use lenses running around at parks, vacation, zoo or other outdoor activities we get into.
Jul 18, 2022 at 03:50 AM
schlotz
Details
p.1 #14What’s the latest opinions on protective lens filters?
Only in high dust/sand and around the ocean otherwise no.
Jul 18, 2022 at 04:11 AM
telyt
Details
p.1 #15What’s the latest opinions on protective lens filters?
I don't use them. Can't use one on my most expensive lens (WAY more than US$2,000).
Jul 18, 2022 at 04:45 AM
InFocus2014
Details
p.1 #16What’s the latest opinions on protective lens filters?
Roger Cicala at Lens Rentals performed tests on filters some time ago:
https://www.lensrentals.com/blog/2017/06/the-comprehensive-ranking-of-the-major-uv-filters-on-the-market/
One of the charts from his article (I would avoid Tiffen filters):
LensRentals Table of Filters
Jul 18, 2022 at 06:33 AM
Cliff L.
Details
p.1 #17What’s the latest opinions on protective lens filters?
Nothing has really changed - "protective" filters are still the highest profit-margin items camera retailers sell, they still degrade image quality, and newbies still love to waste money on them. YMMV...
Jul 18, 2022 at 08:05 AM
tsdevine
Details
p.1 #18What’s the latest opinions on protective lens filters?
I hadn't used them, but once I realized that L41 UV filters could address magenta shading on my CV lenses, I've adopted them on most of my lenses.
Edited on Jul 18, 2022 at 08:32 AM · View previous versions
Jul 18, 2022 at 08:15 AM
mudlake
Details
p.1 #19What’s the latest opinions on protective lens filters?
I never use them. 40 years shooting and haven’t had a problem. I always use a lens hood.
Jul 18, 2022 at 08:27 AM
InFocus2014
Details
p.1 #20What’s the latest opinions on protective lens filters?
I'm with you on this... many, many dozens of lenses shot since 1964 with no problems or damage. I always use lens hoods. I keep some clear B+W filters in the drawer in case I am going to shoot something like a motocross, with flying mud and sand, but those occasions are rare, for me. I did go through a very short time where I used clear filters, but stopped using them when I shot a sunset one evening where the filter was producing excess flaring (admittedly newer filters have better coatings to mitigate such) and came to the realization I simply didn't need them.
As a note, I never dry-wipe lenses (as I see so many photographers do - even professionals!) and generally will not attempt to clean lenses in the field - preferring to wet-clean at home or at the hotel, on the very RARE occasions where I need to do so. A bulb blower works wonders. As a result, I've virtually never had a mark, scratch or any signs of wear on my lenses.
Jul 18, 2022 at 09:09 AM
