fredmiranda.com Login
This topic is in the 2019 archive. You can read it and like its posts here. It is read only.
Archive 2019Leica SL 2 announced
maxx9photo
p.1 #1Leica SL 2 announced
Full spec,
https://leicarumors.com/2019/11/05/here-is-the-full-set-of-leica-sl2-camera-specifications.aspx/
Camera Type
Mirrorless full-frame system camera
Buffer Memory
4 GB: DNG: 78 recordings / JPG: > 100 recordings
Storage Medium
UHS-II (recommended), UHS-I, SD/SDHC/SDXC memory card
Material
Full-metal housing made of aluminum and magnesium, leatherette, cover, splash-water protected in compliance with IEC standard 60529 (protection type IP54).
Lens Mount
Leica L bayonet with contact strip for communication between lens and camera
Operating Conditions
14 to 104 Degree F (-10 to +40 Degree C)
Interfaces
ISO accessory shoe with additional control contacts, HDMI jack 2.0b Type A, USB 3.1 Gen1 Type C, Audio-Out 3.5 mm/Audio-In 3.5 mm, communication interface in the base cover for multifunction hand grip
Tripod Thread
A 1/4 DIN 4503 (1/4") with stainless steel in the base
Sensor Size
CMOS sensor, pixel pitch: 4.3 microm / Fullframe (47.3 MP): 8368 x 5584 pixels / APS-C (20.2 MP): 5504 x 3664 pixels
Filter
RGB color filter, UV/IR filter, no low-pass filter
Processor
Leica Maestro series (Maestro III)
File Formats
Photo: DNG (raw data), DNG + JPG, JPG (DCF, Exif 2.31) Video: MP4: H.264/MPEG-4 AVC (Audio Format: 2ch 48 kHz/16 bit, AAC), MOV: H.264/MPEG-4 AVC (Audio Format: 2ch 48 kHz/16 bit, AC-3)
Picture Resolution
DNG: 8368 x 5584 pixels (46.7 MP) JPG: 8368 x 5584 pixels (46.7 MP), 6000 x 4000 pixels (24 MP), 4272 x 2848 pixels (12 MP)
Color Depth
DNG: 14 bit, JPG: 8 bit
Color Space
Picture: sRGB, ECI-RGB v2.0, Adobe RGB Video: Rec. 709/Rec. 2020 (HLG)/L-Log
File Size
DNG: 84.4 MB JPG: depending on resolution and image content Video: max. length: 29 min, max. file size: 96 GB
Recording Mode Video
Video mode: P - A - S - M / Cine mode: M
Video Resolution/Frame Rate
MOV 5K: 29.97 fps, 25 fps, 23.98 fps / MOV C4K: 59.94 fps, 50 fps, 29.97 fps, 25 fps, 24 fps / MOV 4K: 59.94 fps, 50 fps, 29.97 fps, 25 fps, 23.98 fps / MOV FHD: 180 fps, 150 fps, 120 fps, 100 fps, 59.94 fps, 50 fps, 29.97 fps, 25 fps, 23.98 fps / MP4 4 K: 59.94 fps, 50 fps, 29.97 fps, 25 fps, 23.98 fps / MP4 FHD: 180 fps, 150 fps, 120 fps, 100 fps, 59.94 fps, 50 fps, 29.97 fps, 25 fps, 23.98 fps
Bit Rate
8/10 bit for recordings on SD card, 10 bit via HDMI output
Video Gamma
Rec. 709, L-Log Rec. 2020, HLG Rec. 2020
Viewfinder (EVF)
Resolution: 5,760,000 dots, 120 fps, magnification: 0.78x, aspect ratio: 4:3, frame coverage: 100%, exit pupil position: 21 mm, setting range +2/-4 diopters, with eye sensor for automatic switchover between viewfinder and LCD panel, time delay 0.005 s
LCD Panel
3.2" (backlight LED) with anti-fingerprint and anti-scratch coating, 2,100,000 pixels (dots), format 3:2, touch control available
Top Display
1.28" highly reflective trans-reflective monochrome LCD, 128 x 128 pixels, viewing angle 120 Degree ; anti-fingerprint coating
Shutter Type
Electronically controlled focal plane shutter/electronic shutter
Shutter Speeds
Mech. shutter: 30 min to 1/8000 s / Electr. shutter function: 1 s to 1/40000 s / Flash Synch: up to 1/250 s
Shutter Button
Two-stage (1st stage: Activation of the camera electronics including autofocus and exposure metering, 2nd stage: Taking the picture)
Self-Timer
Delay time: 2 s or 12 s
Picture Series
Single Continuous Low Speed (3 fps), Continuous Medium Speed (6 fps), Continuous High Speed (10 fps without AFc/AE/WB), Continuous Super Speed (20 fps with electr. shutter function without AFc/AE/WB), Interval Shooting, Exposure Bracketing, Multishot
Multishot
Generates 2 DNGs: 1x 47 MP, 1x 187 MP (8 pictures are combined into one high-res image)
Working Range
30cm to infinity, With macro setting: from 17 cm
Focus Mode
Automatic (Autofocus in modes iAF/AFs/AFc/Touch AF) or manual. With manual setting: Auto Magnification and Focus Peaking optionally available as focus aids
Autofocus System
Based on contrast metering and depth mapping
Autofocus Modes
Smart AF (autonomously selects AFs and AFc), AFs (picture taken only after successful focusing), AFc (picture can be taken at any time), AF setting can be saved
Autofocus Metering Methods
Spot (can be shifted), Field (can be shifted), Multi-Field, Zone, Face detection, object Tracking, optional Touch AF
Autofocus Metering Fields 225
Exposure Metering
TTL (Through The Lens' exposure metering)
Exposure Metering Methods
Spot, Center-Weighted, Multi-Field
Exposure Modes
Automatic program (P), Aperture priority (A): manual aperture setting, Shutter priority mode (S): manual shutter speed setting Manual (M): manual setting for shutter speed and aperture
Exposure Compensation
+/-3 EV in 1/3 EV increments or 1/2 EV increments
Automatic Bracketing
3 or 5 exposures, up to +/-3 EV, in 1/3 EV increments Shift function: up to +/-3 EV, additional LPG-HDR
ISO Sensitivity Range
Auto ISO: ISO 100 to ISO 50000, Manual: ISO 50 to ISO 50000
White Balance
Automatic (Auto), Daylight 5200 K, Cloudy 6000 K, Shadow 7000 K, Tungsten 3200 K, HMI 5600 K, Fluorescent Warm 4000 K, Fluorescent Cold 4500 K, Flash 5400 K, Gray Card Live View, Gray Card, Color Temperature 2000 K to 11500 K
Flash Unit Connector
About the accessory shoe
Flash Sync Time
1/2 50 s, slower shutter speeds available, automatic changeover to TTL linear flash mode with HSS-compatible Leica flash units if sync time is undercut
Flash Exposure Metering
Using center-weighted TTL pre-flash metering with Leica flash units (SF 26, 40, 40MkII, 58, 60, 64) or with system compatible flash units, flash remote control SF C1
Flash Exposure Compensation
SF 40: +/-2 EV in 1/2 EV increments, SF 60: +/-2 EV in 1/3 EV increments
Microphone
Stereo internal + microphone input 3.5 mm stereo jack
Speaker
Mono internal + headphones output 3.5 mm stereo jack
WLAN
The Leica FOTOS app is required to use the WLAN function. The Leica app is available from the Apple App Store or the Google Play Store. Compliant with Wi-Fi IEEE802.11b/g/n, 2.4 GHz, channel 1-11 (2412-2462 MHz) and Wi-Fi IEEE802.11ac, 2.4 GHz & 5 GHz, channel 39-48 (5180-5240 MHz), channel 52-64 (5260-5320 MHz), channel 100-140 (5500-5700 MHz) (standard WLAN protocol), encryption method: WLAN-compatible WPA/WPA2
Bluetooth
Bluetooth v4.2 (Bluetooth Low Energy (BLE)), 2402 to 2480 MHz
GPS
Via Leica FOTOS app
Menu Languages
English, German, French, Italian, Spanish, Russian, Japanese, Simplified Chinese, Traditional Chinese, Korean
Rechargeable Battery (Leica BP-SCL4)
Lithium-ion rechargeable battery, rated voltage: 7.2 V (DC); capacity: 1860 mAh (min.), approx. 370 recordings (based on CIPA standard, without EVF); charging time: approx. 140 min (after deep discharge); manufacturer: Panasonic Energy (Wuxi) Co. Ltd., Made in China
USB Power Supply
USB charger function in standby mode or when switched off, USB power supply when switched on
Charger (Leica BC-SCL4)
Input: AC 100-240 V, 50/60 Hz, 0.25 A, automatic switchover; Output: DC 8.4 V 0.85 A; Manufacturer: Salom Electric (Xiamen) Co., Ltd., Made in China
Dimensions (W x H x D) 146 x 107 x 42mm
Weight
Approx. 835g (without battery)
Read more: https://leicarumors.com/2019/11/05/here-is-the-full-set-of-leica-sl2-camera-specifications.aspx/#ixzz64VIIWopA
Nov 06, 2019 at 07:26 AM
retrofocus
Details
p.1 #2Leica SL 2 announced
Price?
Nov 06, 2019 at 07:54 AM
rscheffler
Details
p.1 #3Leica SL 2 announced
US $5995.
S1R in Leica clothing...
Edited on Nov 06, 2019 at 08:41 AM · View previous versions
Nov 06, 2019 at 08:36 AM
snapsy
Details
p.1 #4Leica SL 2 announced
S1R at 2x the price but with a different logo (recent $3k sale price of S1R).
Timkr
Details
p.1 #5Leica SL 2 announced
This shows that they are so dependent on Panasonic at this point. Its a Lumix S1r with a red dot. They are going to have to innovate soon to be relevant.
Nov 06, 2019 at 08:42 AM
rscheffler
Details
p.1 #6Leica SL 2 announced
SL vs. SL2 comparison specs listed at Red Dot Forum.
Gordon will be happy: LENR can be disabled (apparently).
Nov 06, 2019 at 08:43 AM
pmeheut
Details
p.1 #7Leica SL 2 announced
I know this is an S1R in Leica clothing and I'm not sure I will buy one but I would just to get less buttons (and the same as my M10).
Yes, there is a huge price difference but once you are in the Leica world, you tend to buy what you like as long as you can afford it.
Nov 06, 2019 at 09:02 AM
MAubrey
Details
p.1 #8Leica SL 2 announced
rscheffler wrote:
US $5995.
Well, that Leica clothing includes micro lenses designed for rangefinder lenses. So there's that.
Nov 06, 2019 at 09:11 AM
retrofocus
Details
p.1 #9Leica SL 2 announced
MAubrey wrote:
rscheffler wroteUS $5995.
That's a minor benefit IMO for > $3K difference. For this money I can easily have any MLC other than from Leica converted with KolariVision to make them work very well with rangefinder lenses and will still have lots of money left to purchase other stuff.
To be now competitive with other companies, Leica needs to rethink their pricing strategy or suffer the consequences.
Nov 06, 2019 at 09:33 AM
Desmolicious
Details
p.1 #10Leica SL 2 announced
It's actually a major benefit as Leica will also have in-body profiles for those M lenses. For someone who has a few (or many) M lenses that is a big deal.
Nov 06, 2019 at 09:39 AM
pmeheut
Details
p.1 #11Leica SL 2 announced
Leica business is booming in a very difficult market.
It seems they do not need your advice.
Nov 06, 2019 at 09:52 AM
Steve Spencer
Details
p.1 #12Leica SL 2 announced
I hope in addition to micro lenses, it also has thinner sensor cover glass. The micro lenses, thinner sensor cover glass, and built-in corrections could make this camera clearly the best non-rangefinder for Leica M glass and that would be important to a number of people. In addition, it would then be the camera that works the best with Leica M glass and also works with L mount glass like the new Leica SL summicron lenses. One could imagine a kit for this camera that included the Leica M 21 SEM (or the WATE if you wanted wider), the Leica SL 35 f/2 APO, the Leica SL 50 f/2 APO, and the Leica SL 90 f/2 APO. That is a ridiculously expensive, but pretty stellar kit and quite reasonable in size. If you needed a fast wide lens you could add the a Leica M summilux 21, 24, or 28. If you needed longer focal lengths you could add L glass. I can see this as a very versatile camera that can take a lot of different and interesting lenses some of which other cameras could not use or not use well.
Now if you need top drawer AF, then this camera probably won't be for you, but I think it will have a following and for those people it will bring some things that other cameras cannot.
Nov 06, 2019 at 10:39 AM
retrofocus
Details
p.1 #13Leica SL 2 announced
Not sure if this is a big benefit - other opinions might differ, but I never even used them when they existed for my old Canon DSLR.
Nov 06, 2019 at 10:45 AM
retrofocus
Details
p.1 #14Leica SL 2 announced
pmeheut wrote:
retrofocus wroteTo be now competitive with other companies, Leica needs to rethink their pricing strategy or suffer the consequences.
That's exactly what FM forum participants told me in 2013 when I criticized Canon's path to move forward by not competing in the sensor field with other brands like Nikon and later Sony. That was at the most profitable time for Canon camera division. See where they are now.
Nov 06, 2019 at 10:53 AM
hsiunghsiung
Details
p.1 #15Leica SL 2 announced
I wonder if it does line skipping too for 4k 60p in full frame mode. with no 1.09 crop like s1r too
Just looking for 4k 60p full frame with no crop (which no camera does well yet that I know of. Not sure how s1r's 4k 60p FF is)
Nov 06, 2019 at 10:54 AM
zhangyue
Details
p.1 #16Leica SL 2 announced
Actually, it offers more than I thought. It is also cheaper at 45M compare to more expensive 24M SL at introduction. High resolution mode will be available, IBIS and Leica ergo and assume it play M lens better are all good selling point. And take S glass.
I expect it will sell well at Leica standard.
Nov 06, 2019 at 11:04 AM
maxx9photo
Details
p.1 #17Leica SL 2 announced
LENR can be turned off too
Nov 06, 2019 at 11:10 AM
alundeb
Details
p.1 #18Leica SL 2 announced
https://petapixel.com/2019/07/08/canon-increased-market-share-in-2018-but-camera-market-continues-to-bleed/
Nov 06, 2019 at 01:50 PM
freaklikeme
Details
p.1 #19Leica SL 2 announced
It may just be an S1R in Leica clothing, but it's the most competitive camera Leica's marketed in ages.
Nov 06, 2019 at 05:27 PM
retrofocus
Details
p.1 #20Leica SL 2 announced
alundeb wrote:
retrofocus wroteThat's exactly what FM forum participants told me in 2013 when I criticized Canon's path to move forward by not competing in the sensor field with other brands like Nikon and later Sony. That was at the most profitable time for Canon camera division. See where they are now.
Yeah, and they are cutting and cutting jobs in their camera sector and closing facilities. Far behind in sensor tech versus the competition since 2012. Increased market share still due to entry level camera sales which will soon be no longer available with increasing cellphone camera technology. Nothing else really good in the pipeline even they at least now tried with FF MLC 1st gen. Not really a great market disruptor either.
Nov 06, 2019 at 06:26 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
