fredmiranda.com Login
This topic is in the 2018 archive. You can read it and like its posts here. It is read only.
Archive 2018Sigma Art FE-mount discussion/tests/etc.
Samuli Vahonen
Details
p.9 #1Sigma Art FE-mount discussion/tests/etc.
fadeslayer wrote:
Samuli Vahonen wroteI'm more bothered by "hot spot" in middle of frame @ f/1.4 more than boke quality
It looks like a related problem of this https://www.fredmiranda.com/forum/topic/1591975, maybe it is some sort of limitation bounded to diameter of bayonet?
I doubt it's same issue, the 100-400 issue has quite defined edge and is 15-20mm in diameter, where the f/1.4 hotspot is very soft edged and <5mm in diameter. Would be nice to have Canon body to compare as I assume this same behavior would happen in Canon as well, but sold last of those few years ago.
If it would not be SLR-lens, it could be diameter of bajonet issue as well. However same lens design is used in Nikon SLRs, so obviously from mount diameter and distance point of view, Nikon SLR has been the most limiting factor on Sigma Art SLR lens designs. On short flange distance lenses wide open also rays coming in angle to center of image contribute considerably exposure - due to this lens like Leica Summilux-M 50mm Asph. sucks badly wide open in A7 cameras with super hyper thick sensor cover glass, center sharpness&contrast takes gigantic hit compared real digital M-camera.
Samuli
Apr 21, 2019 at 04:11 AM
fadeslayer
Details
p.9 #2Sigma Art FE-mount discussion/tests/etc.
I saw that at f/6.3 it's quite a bit less defined and more "shaded" than at f/8, so maybe at f/4 or wider the edges soften more and more... But these are only suggestions, I don't have any means to verify these claims.
(sorry for my bad english)
Apr 21, 2019 at 06:39 AM
wind30
Details
p.9 #3Sigma Art FE-mount discussion/tests/etc.
I took a closer look at Sam's raw file and found that the double lining is there too. I think it occurs at the transition zone. I should just stop pixel peeping. Let me use it on my next trip in May and hopefully the bokeh will turn out nice.
http://www.keehian.com/test/double.jpg
Apr 22, 2019 at 05:01 AM
