fredmiranda.com Login
This topic is in the 2019 archive. You can read it and like its posts here. It is read only.
Archive 2019Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
eyal
p.1 #1Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
I've been shooting with the 100-400 for a little over a year now and found it to be a good lens but had noticed I was never able to stitch panoramas at 400mm as the sky would have varying levels of brightness making the stitching very obvious. Didn't make much of that but continued to use it for shooting my son's sports and moonrises/moonsets.
I was out shooting the full moon setting recently and decided to do a quick check of the sensor on the blue sky to make sure it had no dust spots. I ran it from f/5.6-40 and, on getting home, found there was on obvious vignetting (or more accurately bright center circle) even at f/8. The effect is not obvious at f/5.6 and the vignette gets smaller/center circle bigger at f/11 then disappears after. It is present at 300mm, less so at 200mm and even less at 100mm.
I shot the sequence again on a another bright blue day. This time I made sure to stand in the full shade of my house with lens hood on. No teleconverter. I could still see this vignetting. I tested against my Canon 200 (on the MC-11) as it is the only other long focal length I have.
I have lens compensation flagged on (Auto) in camera and LR had the Enable Profile Correction checked with both distortion and vignetting at 100.
Decided to reach out to Sony Pro Support and sent them raw files which got passed to a senior engineer and got this response. Curious if this is an issue found on all of the 100-400s (and I'm making too much of it - though it did affect panorama stitching), if it is a failure of their correction, or if there is something weird about mine. From the response below, it sounds like I need to just live with it...
'I've heard back from the engineers and was provided with the below response:
"The symptom in the photo pointed out is caused by the "decrease in peripheral light quantities & correction characteristic". It is not a quality problem, but a lens's ability. (within a specification) As a workaround, adjust the brightness and contrast so that the symptom is hard to see."
I understand this may not be a fully satisfactory answer as you may wish to continue shooting panoramic images without this issue but there is a work around it just requires a bit of post processing editing.'
Here is 400mm f/8 iso 100 with quick edit to monochrome and playing levels to show the effect:
https://photos.smugmug.com/Forum/i-GC3kxtk/0/e951657b/M/A7R-034829-M.jpg
Here is the same but untouched 400mm f/8 iso 100 image with just Enable Profile Correction on. It's subtle but once you know where to look from the above, it is obvious:
https://photos.smugmug.com/Forum/i-JfRT99t/0/86c215c6/M/A7R-034829-2-M.jpg
Link to raw file: https://www.dropbox.com/s/ygrtqo4wlboplv2/A7R-034829.ARW?dl=0
Apr 13, 2019 at 05:00 AM
fadeslayer
Details
p.1 #2Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
I have ecountered such a behaviour, shooting dawn pictures from the top of a mountain near home, I can see a brighter circle in the middle of the image, such that I threw away many pictures I had underexposed a bit.
I hve not reached Sony Customer Service yet, but I think I will.
Apr 17, 2019 at 08:14 AM
eyal
Details
p.1 #3Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
Thanks for commenting and glad (but not really) that yours does the same. It's frustratingly subtle but I can see it very clearly when going through images quickly and the effect has ruined a number of shots. I'm not crazy about Sony's answer to essentially 'fix it in post' but not sure there is an answer otherwise.
Apr 17, 2019 at 08:26 AM
fadeslayer
Details
p.1 #4Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
eyal wrote:
fadeslayer wroteI have ecountered such a behaviour, shooting dawn pictures from the top of a mountain near home, I can see a brighter circle in the middle of the image, such that I threw away many pictures I had underexposed a bit.
This friday I will meet with a friend, he let me try A9 and A7RIII because I must decide which one to change my A7RII with... because for BIF and nature photography (but sports, too, and action photography in general) I find limited by poor AF (especially in finding focus and then in keeping it). I find AWB very bad in many many situations...
This friend has 100-400 GM too, and 16-35 GM, so I hope I can double-check my 100-400 for such a strange behaviour. I hope it's not a widely-renowned problem but a solvable one...
Apr 17, 2019 at 10:59 AM
aae991
Details
p.1 #5Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
I just got my 100-400 GM and at 400mm on a blue sky I have the same thing. When bringing the raw file into DXO (which for me personally is my favorite raw editor) there is a vignetting module that has nice controls. It appears to be relatively easy to remove any visual evidence of the vignetting, but it's too early to be sure I can control it. I'll try and do some more work on it in the coming days as I further test out this lens. My first task is comparing its performance (sharpness and contrast) to my Canon 100-400 mkII adapted for use on the A7R3 with an MC-11. That combo has served me fairly well for relatively slow moving objects but for faster action I felt it necessary to switch over to the 100-400 GM. I hope I made the right decision...
Apr 17, 2019 at 04:55 PM
realVivek
Details
p.1 #6Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
It looks like a lens hotspot to me.
Apr 17, 2019 at 05:17 PM
aae991
Details
p.1 #7Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
Quick update and non-scientific, but in a comparison with the Canon and Sony 100-400, the Sony seems noticeably sharper at 100% in PS and more detail in general vs. the Canon. These were 300dpi tiff files imported from DXO into PS. My Canon is a really good copy too and has taken some wonderful BIF and aircraft shots paired with my 80D. I had read the Sony outperforms the Canon in terms of sharpness and I'm seeing my own evidence of this. Sorry to head off topic... I'll be sad to see my Canon gear go, but it's served me well... I can't justify keeping the L glass when I've switched over to Sony. There's certainly no perfect system, but I've been mostly pleased with the Sony A7R3 and also just picked up an A6400 to see how it performs with BIF.
Apr 17, 2019 at 05:29 PM
eyal
Details
p.1 #8Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
Hmmm...I think you're right. But thought this was only an issue with IR photography.
Apr 17, 2019 at 06:39 PM
realVivek
Details
p.1 #9Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
Although more often encountered (as it is easier to detect) in Infrared, hotspotting does occur with certain lenses in the visible region.
Examples:
Coastal optics 60/4 at close focus distances
Fuji X 60mm Macro at certain distances
The origin could be at the lens design and/or the coating interactions of the lens/sensor cover. Sony should investigate and remedy this if they can.
Thank you for posting about this with a clear example.
eyal wrote:
realVivek wroteIt looks like a lens hotspot to me.
Apr 18, 2019 at 03:04 AM
Jochenb
Details
p.1 #10Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
I noticed the same thing on my 100-400 GM.
Apr 18, 2019 at 04:37 AM
fadeslayer
Details
p.1 #11Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
A quick and dirty example, the quality of image is bad but I had it shared via WhatsApp with a friend (I can't reach my HD now)
https://i.imgur.com/nCs8sOE.jpg
Apr 18, 2019 at 05:06 AM
-rce-
Details
p.1 #12Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
I was about to pull the trigger on getting a 100-400, but you guys have me a bit worried.
Does this happen ONLY at or near 400mm?
What part does aperture play in this?
I've seen superb images from this lens that are not recent and wonder if this is related to a certain manufacturing lot.
I don't need the lens immediately and could wait to see if there's a "fix".
Apr 18, 2019 at 08:14 AM
eyal
Details
p.1 #13Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
It's most prevalent at 300-400mm but I have seen it rarely at 100-200mm
Worse at f/8 - improves at f/11 and f/16
If you have a busier composition, you won't notice it. It is most evident with clear skies. And more so if you shoot multiple frames and adjust the aperture and then scroll through quickly in LR - that's how I noticed it in shots that bugged me.
The biggest issue for me was in trying to stitch a vertical panorama using the 100-400 and finding that there were issues at the seams and the final image showed variations in exposure.
Real-world it has only affected a very few images and it remains a very sharp lens. I've gotten plenty of 'keepers' with it. This one aspect has nagged me a bit in that I could not figure it out and only happened upon it when shooting the blue sky to check my sensor and finding this 'hot spot'.
Also, doubt it's a batch issue. I reached out to Sony Support as a Pro member as noted above and it took 2-3 weeks for a reply that was attributed to a Senior Engineer. Guessing the lens just has this hot spot but happy to be proven wrong.
Apr 18, 2019 at 08:24 AM
fadeslayer
Details
p.1 #14Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
I admit I have found this behaviour in this situation only (low light at dawn, 1-2 EV underexposition), I have not checked again for this strange behaviour, I have shot many daylight pictures without issues, I don't know if fog / humidity is a factor...
Apr 18, 2019 at 08:36 AM
fadeslayer
Details
p.1 #15Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
No check with mu friend today but I took a thousand of pictures this morning in a marsh near home.
I found that in a specific sequence, with a GBH in the clear sunny (but quite hazy) sky, the hotspot starts to break through
Image shot at f/8
https://i.imgur.com/l5drQHm.jpg
Original, direct export from Camera Raw, resize 3000px
https://i.imgur.com/1LlDSds.jpg
here Dehaze +60 in ACR to enhance effect, resize 3000px
I have not noticed it in other situations or sequences or pictures with this strength. I tried in another picture (f/6.3)
https://i.imgur.com/0PvhyY5.jpg
to view if with Dehaze +60 the effect is visible, and it is, but to a different extent,
https://i.imgur.com/EDmbPUS.jpg
(quite an artistic image...)
so it looks like a "problem" with plain background, maybe haze? (with trees or foliage no hot spot visible whatsoever, even Dehazing to +100)
Apr 19, 2019 at 12:04 PM
71sbeetle
Details
p.1 #16Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
It's a lens issue, Sony pro support had my lens a few times engineers said it's normal. If you simply import the picture into Photoshop and use the equalize function you will see the pattern, you can change the brightness and contrast if you want to see it even more. Sadly because of the weird patterns that sometimes appear it's not an easy fix in post. I texted out to Lens Rentals to see if they'd be willing to test and find out more details but have not heard back so I'm guessing they're not interested in testing it lol. Other than that it is an awesome lens.
Apr 19, 2019 at 05:48 PM
rattlebonez
Details
p.1 #17Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
Are you getting double vignetting correction?
— Camera correcting using lens profile
— RAW converter correcting vignetting
Apr 20, 2019 at 06:27 PM
fadeslayer
Details
p.1 #18Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
I will inspect for double correction.
Sure is that shooting at f/5.6 that friend of mine never encountered the problem (he is a fine art printer), but he told me he would check for this behaviour.
Happy Easter to you all!
Apr 21, 2019 at 12:09 AM
71sbeetle
Details
p.1 #19Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
It's not double correction, you can put zero correction and you will see it
See this post:
https://www.fredmiranda.com/forum/topic/1535862/15#14808722
Apr 21, 2019 at 01:37 AM
fadeslayer
Details
p.1 #20Sony FE 100-400/4.5-5.6 Vignetting/Bright Center at f/8 (no TC)
That's what I did above to show my results, apart the brightness adjustment, I hold used Dehaze slider, it just was enough to show the effect (and the many dust spots, I removed for decency 😂
Apr 21, 2019 at 02:06 AM
