I bought Canon 1DXII, it comes with Sandisk 128 CFast card + Reader, which I notice:
1. It heats up or warm up to around 100F after plug in computer (PC & MAC) very quick;
2. Some of the RAW file & JPG are corrupted (at the lower right corner):
- Some Raw file shows corrupted in the CFast card.
- Some Raw file shows OK with Bridge & DPP4 in the CFast card and copy to MAC ok. But after awhile (hrs or days) when I re-read some same good file in the card at the beginning show corrupted in the CFast card late on .
3. Canon has replaced a card and a reader, but problem still there.
4. Canon mentioned Japan has noticed this issue, and most likely in caused by the card & reader. They are trying to figure out the solution.
5. I noticed that computer load the CFast card as external drive. MAC writes some hidden files to the CFast whenever plugged in the reader. Win10 writes 2 hidden folders to the card.
6. There are some discussion of this in Dpreview.com & photography-on-the.net .
No issues here with the Sandisk CFast card and reader that came with the 1dx2. I did notice that the reader does get a little warm but nowhere near as warm as described.
I plug the reader into a USB 3.0 port on my pc and I don't transfer files from the camera directly to Lr or Ps. I always copy files to a folder on the pc and then import from that folder into Lr. I've read posts where using the ADD or MOVE command can cause corrupt files.
I don't edit direct from the card.
I copy files to HD then edit there.
I don't delete film off the card right the way.
Have you tried shooting to both cards simultaneously? CFast + CF? If so, does the problems persist?
I'm also having an issue with corrupted files but on CFast card only. Same files are OK on a CF card. But my files aren't recognized by a computer and cannot be copied. When viewing in the camera, I'm getting a black screen with a question mark...
CF card files are OK.
Same the Original CFAst came with the 1DXII has some files can't be open, show yellow question mark.
The new CFast cards, don't have the yellow question mark file yet.
Yes, with my 1DX2. I wouldn't expect to hear much from Sandisk, I'm guessing their cards are conforming to the spec. I also don't think it has anything to do with the reader...more likely a firmware bug with the 1DX2, which will hopefully be fixed soon. Teething problems.
SanDisk won't reply my email Yes, with my 1DX2. I wouldn't expect to hear much from Sandisk, I'm guessing their cards are conforming to the spec. I also don't think it has anything to do with the reader...more likely a firmware bug with the 1DX2, which will hopefully be fixed soon. Teething problems.
If not the Card or Reader issue, then why some files open OK and copied OK from CFast card to computer but corrupted inside the CFast card couple hours or days later.
Fingers crossed, hope is not the hardware in the camera.
Don't want the local dealer open up the camera
But a lot of owners don't have this problem at all.
No problems with CFast so far (CFast and reader coupled with the B&H deal at launch). 3000+ images with no questions marks or corruption.
I make a folder on desktop, copy files over, remove from reader, insert back into the 1DXii then format.
I do the same steps but did not format the CFast after copy.
Humm:
- Mac or PC?
- Raw file?
- Please try not to format and keep files in the CFast card and see what's will happen in couple days?
I'm around 15,000 images using 64 gig cfast. The reader does get quite warm. Out of curiosity, do you leave the card and reader plugged in and then notice the corruption the next day? I'm wondering if the card is staying hot the whole time and causing the corruption?
Do you do a lot of review and delete in camera? I used to do that on other cameras and I would get the odd corrupt files.
I haven't had any issues so far.
Also, have you tried different programs to open the corrupt files?
Why did some come with 128 gb cfast and others 64? Mine came with 64.
While I haven't had any problems thus far and hope you get that worked out, I did have corrupted files on a Lexar 64gb card in the past with my 1Dx. My solution? I stepped on the foot pedal of my garbage can and dumped the card right in it. No way I was going to take that chance again.
No, I don't leave my card in the reader.
No, I don't review files in camera, pro. don't do this, hahahahahah
Yes, I tried Br, PS, DPP4 same same.
Now, I have 3 CFast readers:
- Sandisk raises card temp quick fast.
- Transcend is a bit cooler with card in it.
- Lexar is warm without card in.
In HK, Canon only come with 128GB.
64GB has a much slower writing speed.
Now, I have 3 CFast cards, all in 128GB:
1. Replacement 128 Sandisk from Canon, more corrupt files.
2. I bought another 128 Sandisk on the street, so far only 1 corrupt file, in my memory.
3. I bought 3600X 128 Lexar from B&H, arrived this afternoon, so far so good only 105 files. Will try to open them again tmr.
