RalphTomaccio Offline Upload & Sell: Off
p.1 #1 · FS: Filters & Stuff - Reduced! | |
Filters:
Nikkor 52mm B12 (Blue) Filter w/plastic case 10.00
Tiffen 4 Point Star Filter, Series 8 10.00
Samigon Spot-Soft 67mm (Clear Center, Soft Outer area) w/plastic case 10.00
Harrison Series 8 Light Yellowish Green (GR4) Glass 10.00
Harrison Series 8 Medium Yellow (K2) Glass 10.00
Harrison Series 8 Deep Yellow (G) Glass 10.00
Harrison Series 8 Medium Red (25A) Glass 10.00
Adapter Rings:
2 - Tiffen 52mm Series 8 5.00
1 - Tiffen 57 Bay Series 8 10.00
2 - Tiffen 60 Bay Series 8 10.00
1 - 58mm Series 8 5.00 SOLD
1 - 67mm Series 8 5.00 SOLD
Tiffen Metal Lens Hood, 67mm 5.00
Shipping not included in the above.
For all you photographers who don't know what "Series" filters and adapter rings are:
They are "Step-Up" adapter rings that take you from the first size listed, which is your lens size, to the second size, which is your filter size.
"Series" filters have no threads. They are meant to be used with Adapter Rings. You buy the filter that fits the largest lens diameter you own and then different adapter rings for each lens to hold the filter. This way, you only have to buy one filter of each type instead of one filter of each type for every lens.
Most likely you have lenses of varying diameters, 52mm, 62mm, 67mm, 72mm, etc. Instead of buying, say, a polarizer filter for each, you buy one polarizer in the Series filter that fits the largest lens you own. It may be a Series 8, or it may be something else. You then buy one adapter ring that fits each lens, such as a 52mm adapter that holds the Series 8 filter. This saves a ton of money as adapter rings are a lot cheaper than good filters.
Usually a Series 8 filter will cover most lens, unless you have a really large diameter lens like a 400mm telephoto or something like that. That's why in my post I have so many adapter rings for sale and mostly series 8 filters.
Here's an article I found that may explain it better:
http://www.songofsnow.com/Articles.asp?ID=121
CC & LB 3”sq. Resin Filters:
Red, Green, Blue, Yellow, Magenta & Cyan, each: 025, 05, 10, 20, 40
80A, 80B, 80C, 80D, 82, 82A, 82B, 82C, 81A, 81B, 81C, 81EF, 85, 85B, 85C
Complete set was $350.00, then $300.00, NOW $200.00
Plus, two Vinyl Filter Holder Books at no additional charge!
Shipping IS included (lower 48 contiguous states only) when the CC & LB filters are purchased as a complete set.
