Archive 2010 · FS: Darkroom Stuff
RalphTomaccio
p.1 #1 · FS: Darkroom Stuff
28 - Kodak 4x5 Film Stainless Steel Processing Hangers - $5.00 each
2 - Kodak 8x10 Film Stainless Steel Processing Hangers - $10.00 each
Ilford Ilfospeed Multigrade II B&W Filter Set $15.00 NOW $10.00
Kodak Polycontrast Filter Set $15.00 NOW $10.00
Kodak Yellow Chemical Stirrers, New, ea $1.00
128oz., 64oz., 32oz. Stainless Steel Measuring Containers, respectively $50.00, $25.00, $20.00
Shipping not included.
Jul 11, 2010 at 09:11 AM
Zer0s0phT
p.1 #2 · FS: Darkroom Stuff
Hi,
Sorry if this is a dumb question but are the filters 3"x3"? I have an Omega C-700 I am setting up and am looking for a filter set. Also is there any recommendation on which one is "better". Thank you for your help.
-Randall
Sep 02, 2010 at 09:42 AM
RalphTomaccio
p.1 #3 · FS: Darkroom Stuff
The filters are mounted into a plastic frame that measures 2 1/2" square, with a small pull tab that has the filter strength labeled on it. The filters slide into a filter adapter that fits onto the lens itself, so the filter is between the lens and the paper, not between the lens and the light source.
I don't think one filter set is better than the other. But, I would recommend, just in case there is a difference, that you use the Kodak filters when using Kodak paper and the Ilford filters when using Ilford paper. If you use another brand of paper, either might work.
Sep 02, 2010 at 10:03 AM
