Archive 2009 · Contax on Nikon
RustyBug
p.1 #1 · Contax on Nikon
Can Contax C/Y mounts be adapted to Nikon?
I anticipate that you would lose infinity focus, but what working distance might be expected using the 35-70 3.4 (or other lenses)?
Nov 24, 2009 at 09:59 PM
mawz
p.1 #2 · Contax on Nikon
Adapted - no.
Converted - yes.
Leitax does conversion kits for Nikon bodies.
Nov 24, 2009 at 10:24 PM
Steve Park
p.1 #3 · Contax on Nikon
As far as I know, only "some" of the Contax MM mount can be converted with Leitax kit, C/Y mount lenses can't be converted to Nikon F mount. Also there is no adapter solution either.
Contact David Lladó -Leitax- [info@leitax.com], for more info. He usually answers email questions fairly quickly.
If interested, check Leitax.com for other possibilities.
Nov 25, 2009 at 06:22 AM
RustyBug
p.1 #4 · Contax on Nikon
Okay, thanks.
I have a C/Y 35-70 3.4 that I was wondering if I could use it for 'double duty' with an adapter on Nikon to do some midrange / close / macro work on a Nikon or Fuji.
What about on a Sigma SD14? Are Oly's and C/Y's able to be used with adapters ... or can the mount in the SD 14 be converted to Canon ( I seem to remember something, just not sure what)?
Nov 25, 2009 at 03:04 PM
europanorama
p.1 #5 · Contax on Nikon
sigmacumlaude.com (guevara) or discussions on dpreview/sigma.
leitax has a converter-solution. losing quality and aperture.
i am thinking about using a yashica 1.6x converter. still unsure what mount at one end. maybe nikon. i dont own a dslr yet.i will send david this adapter to check it out. lens-position can be changed to change ratio. but special level is needed. i have no skills to do the conversion. just prepared it for final conversion.
if i were you i would wait for samsung nx10 or use your zeiss on canon eos. 500d or 7d or 5d mkII, latter has the same mirror-position like old 5d said canon- can someone confirm?
Nov 26, 2009 at 01:30 AM
Anden
p.1 #6 · Contax on Nikon
I have the same mirror issues with the 5DII as the 5D.
A
Feb 24, 2010 at 09:06 AM
