sutegrat Offline Upload & Sell: Off
p.1 #6 · Team Sweden U20 National Team vs. Carleton Ravens | |
I've been struggling a bit to nail the WB at this rink, lighting is pretty good for a Uni. barn (I usually shoot iso 1600, F4, 1/500, 2/3 overexposed) so there really is no reason I shouldn't have the whites spot on. Typically I custom WB off an Expodisc but even still the shots come out very cold/blue/green.
I'm wondering if you're not using the Expodisc properlly. When using an Expodisc, make sure you're pointing your lens at the lights ource. In your case, through the glass up at the lights in the ceiling. A little tip. Make sure the exposdisc exposure is in the middle of the histogram, for bang on WB's. I use Expodisc exclusively (for now) it it works charms if done right.
Also, you can try this, I just bought the Datacolor SpyderCube (http://spyder.datacolor.com/product-cb-spydercube.php) You would place this on the other side of the glass and take pictures of it to come up with a custom WB. Once you know your WB in Kelvin, you should be able to manually dial it in to test.
I'll post my results when I perform the same test at my rink, over the next few days.
-Paul
