Archive 2009 · 5D2 and the ST-E2
Subytuner
p.1 #1 · 5D2 and the ST-E2
Has anyone experienced A/B ratio problems with the ST-E2 flash transmitter on a 5D2 ?
Seems like mine does not change power between a-b ratio, maybe its just me though ? I am using 2 580EX II . Thanks
Heath
Nov 03, 2009 at 02:47 AM
rji2goleez
p.1 #2 · 5D2 and the ST-E2
I'm using it with a 550EX and a 580EX and haven't noticed a problem.
Nov 03, 2009 at 03:24 AM
Gochugogi
p.1 #3 · 5D2 and the ST-E2
I've used the ST-E2 with 430EX, 420EX and 5DII and it worked great. Clean contacts? Line of sight? Slave mode set on 580EX?
Nov 03, 2009 at 03:48 AM
Subytuner
p.1 #4 · 5D2 and the ST-E2
Hmmm.. I will give it a try again, maybe the batt is low ? One strobe set to slave A , another set to slave B, right?
Thanks
Heath
Nov 03, 2009 at 03:59 AM
Navyblue
p.1 #5 · 5D2 and the ST-E2
No problem here too.
Nov 03, 2009 at 03:06 PM
Navyblue
p.1 #6 · 5D2 and the ST-E2
cgardner
p.1 #7 · 5D2 and the ST-E2
Are you new to Canon flash?
If you put the 580exII flashes in slave mode on the same channel as the ST-E2, with one in Group A and the other in Group B, it should follow the lead of the ST-E2 master.
You might also try using one of the 580exII as Master and the other as slave. That's how I use mine. It provides needed fill and overcomes the inherent range problems of the ST-E2. See this tutorial for step-by-step instructions:
LINK
Note if using the 580exII as Master it defaults to Group A and the Slave must be set to Group B via the zoom button.
Chuck
Nov 03, 2009 at 03:57 PM
Subytuner
p.1 #8 · 5D2 and the ST-E2
LINK
Chuck
Thanks Chuck,
Ive used this set up on my 1DMarkIII many times with better results.
Nov 03, 2009 at 06:08 PM
garyvot
p.1 #9 · 5D2 and the ST-E2
Works well here too.
Nov 03, 2009 at 07:13 PM
cgardner
p.1 #10 · 5D2 and the ST-E2
Try a new battery in the ST-E2
Nov 03, 2009 at 09:26 PM
