Archive 2009 · New DPP did Canon put better noise reduction in ?
Rich Swanner
p.1 #1 · New DPP did Canon put better noise reduction in ?
I just put it in(new DPP) and new pics that I have taken look like they have lower noise? Has anyone seen a difference?
Oct 21, 2009 at 07:58 PM
omarlyn
p.1 #2 · New DPP did Canon put better noise reduction in ?
I've been wondering this myself. After installing v.3.7, it seemed to me that the noise was very slightly better but since no mention of improved noise was in the release notes, I figured it was just my imagination.
Omar
Oct 21, 2009 at 10:38 PM
garyvot
p.1 #3 · New DPP did Canon put better noise reduction in ?
Could ot be that the defaults were simply reset?
Oct 21, 2009 at 10:55 PM
RobertLynn
p.1 #4 · New DPP did Canon put better noise reduction in ?
Where is dpp 3.7?
Oct 22, 2009 at 12:06 AM
capt3450
p.1 #5 · New DPP did Canon put better noise reduction in ?
Try this one:
http://support-sg.canon-asia.com/
Oct 22, 2009 at 12:13 AM
Rich Swanner
p.1 #6 · New DPP did Canon put better noise reduction in ?
It doesn't say it, but I think it works better. I have a 2 down to 1 on some of the luminance settings. The backgrounds seem smoother... I usually run 2 and 12 on the 2 sliders..
Edited on Nov 05, 2009 at 02:15 AM · View previous versions
Oct 22, 2009 at 12:24 AM
omarlyn
p.1 #7 · New DPP did Canon put better noise reduction in ?
capt3450 wrote:
Try this one:
You don't have to go to Canon-Singapore, it's available right on the Canon-USA site.
Canon USA
Omar
dhphoto
p.1 #8 · New DPP did Canon put better noise reduction in ?
I've had to uninstall it from my pc, it kept crashing incessantly whenever I used the eyedropper to select a white balance. Shame as it looked good and rendered faster
David
Oct 22, 2009 at 01:30 AM
Rich Swanner
p.1 #9 · New DPP did Canon put better noise reduction in ?
Did you put in the Canon U.S.A. one or the China one? javascript:wssPopupWindow('http://gdlp01.c-wss.com/gds/8/0300002588/01/dpp3.7-w-en.pdf', 'dpp3.7-w-en.pdf') US version........Rich
Oct 22, 2009 at 02:04 AM
dhphoto
p.1 #10 · New DPP did Canon put better noise reduction in ?
Both I think
Started with the 3.7.1 that was put up on the web by some kind soul then migrated to the 3.7.2 one on the USA 1Ds3 site.
Utterly unusable, which is very odd as for me DPP has always been v stable
David
Oct 22, 2009 at 02:15 AM
jeremy_clay
p.1 #11 · New DPP did Canon put better noise reduction in ?
New LR 3 noise reduc is awesome, and the Beta only has Color useable at this point.
Oct 22, 2009 at 02:49 AM
WebDog
p.1 #12 · New DPP did Canon put better noise reduction in ?
Tried DPP 372 and had no problems....
XP sp3 4 GB RAM
Still prefere C1 but DPP grows on me
Oct 22, 2009 at 03:04 AM
Ian.Dobinson
p.1 #13 · New DPP did Canon put better noise reduction in ?
XP sp3 4 GB RAM
You can get a cream for that
Oct 22, 2009 at 03:43 AM
dhphoto
p.1 #14 · New DPP did Canon put better noise reduction in ?
XP sp3 4 GB RAM
Same as my setup.
Odd.
Oct 22, 2009 at 03:48 AM
mttran
p.1 #15 · New DPP did Canon put better noise reduction in ?
dhphoto wrote:
Same as my setup.
Odd.
Same here, XP sp3 no issue w/ DPP 372 - NR is much better than older version
Oct 22, 2009 at 05:02 AM
dhphoto
p.1 #16 · New DPP did Canon put better noise reduction in ?
I am investigating, have un-installed the whole caboodle and am starting from my 50D disk and updating from there, with a a fresh download of 3.7.2
David
Oct 22, 2009 at 05:04 AM
Tom_W
p.1 #17 · New DPP did Canon put better noise reduction in ?
No problems on Vista with DPP 3.7.x (I'm not at home so I don't know if it's ".1" or ".0"). I had an odd problem getting the program installed, but that turned out to be a software issue not related to Canon or Microsoft. Basically, the 'setup.exe' file was completely invisible on my computer, even when I searched using the dos prompt.
Turns out that I had some freeware junk on my computer that I installed to facilitate moving music from my IPod to my IPhone, which I later found out that I did not need. Anyway, when I uninstalled the freeware, I was then able to install the Canon software with no problem.
Oct 22, 2009 at 06:16 AM
jchin
p.1 #18 · New DPP did Canon put better noise reduction in ?
http://gdlp01.c-wss.com/gds/0/0200000900/01/dpp372en.exe
Nov 04, 2009 at 05:26 PM
RobDickinson
p.1 #19 · New DPP did Canon put better noise reduction in ?
I guess noise reduction will keep improving so long as you have more detail before/after.
Nov 04, 2009 at 05:29 PM
njjuliano
p.1 #20 · New DPP did Canon put better noise reduction in ?
David
Similar situation here. Had to start over, and did a new copy, but alas, still a problem. I'm on an oc'ed rig, so I lowered the settings a bit, and seemed to work fine, so far. By chance you overclocked?
Nov 04, 2009 at 06:03 PM
