Eldor Offline Image Upload: On
p.1 #5 · Pocket wizard and Sekonic help | |
repdomman, have you solved the problem yet?
In case you haven't, let me tell you a couple of things which might help...
First of all, if your intent is to use ETTL flash mode (with a MiniTT1 or FlexTT5 on the camera and a FlexTT5 on the flash(es)) then the receiving FlexTT5 MUST be using one of the new ControlTL Rx channels. Your older PW's and the module in the Sekonic meter does NOT have these channels.
And if you ARE using ETTL, then you really don't need to use your flash meter anyway, as the flash output will be controlled (and will vary) by the ETTL system.
If you are NOT trying to shoot in ETTL mode but rather in manual mode, that is when a flash meter is useful (I would say needed). That means you MUST set the FlexTT5 to use a "standard" Rx channel (NOT a ControlTL channel) and it must be the same channel as your meter PW module is set to.
If you use a MiniTT1 on the camera, it can be set to send BOTH a standard and a ControlTL channel at the same time, but the FlexTT5 can only RECEIVE one of those at a time.
The way I handle this is to set my C1 configuration for ETTL using a ControlTL Rx channel on the FlexTT5 and my C2 configuration for manual flash use, using a standard Rx channel on the FlexTT5.
I hope this is of help to you...
Eldor
