bka20d Offline Image Upload: On
p.1 #3 · Please help with PW TT1 | |
tiznaki wrote:
I received my Pocket Wizard mini TT1 today. Of course, I immediately load the software and run through the motions of setting the high speed sync options. I go outside to shoot some test shots of my kids and nada. I am using it with my plus II's to fire my Quantum T5D. They will fire if the shutter speed, on my 5D2, is at or below 200. So I know they are transmitting a signal. I tried multiple different delay settings in the software and I still cannot get to high speed sync. Unless I received a bad unit, I think I am just missing something here. Anyone have any advice?
I find myself reminding people that the flex and mini, unlike other pw products are not plug in and play units...and advise reading and re-reading the manuals before changing settings. in fact sometimes you may have to refer to both the pw manual and the canon manual in order to understand how to operate the two products together. two observations: high speed sync is an ettl function, and your plus unit does not have ettl functionality ---it can hypersync......
not being able to get your camera to sync above 200 sounds like a camera issue, not a pw issue: assuming you are in av mode when you have not been able to get your flash to sync above 200, you may want to check your exposure custom functions to make sure that your flash sync speed is not on one of the settings which limits the max speed to 200...
