Archive 2009 · Just supposing I wanted
john_edwards
p.1 #1 · Just supposing I wanted
Greetings to all of you alternative types. A question: If you wanted a macro lens in the 180mm range and didn't care about infinity (or auto) focusing what would you get? I'm a Canon user and just don't see the point of the Canon 180 pricing when I would only use it for macro work. Thanks, John
Apr 03, 2009 at 08:10 PM
mawz
p.1 #2 · Just supposing I wanted
Nikkor or Pentax 200mm f4 macro. The Pentax is a bit better, the Nikkor a LOT cheaper.
Apr 03, 2009 at 08:18 PM
john_edwards
p.1 #3 · Just supposing I wanted
Thanks Mawz, I'm assuming you mean the Pentax to be 35mm rather than med format. And what type of adapter would I want/need? I'll keep my eyes open on the B&S.
Apr 03, 2009 at 08:35 PM
mawz
p.1 #4 · Just supposing I wanted
Yes, I'm referring to the K mount A* 200 f4 Macro in the case of the Pentax.
For Pentax you'll need a K to EOS adaptor and if you're using a Canon body that isn't EF-S you'll also need to remove the stop-down lever and cut off the lever guard in order to prevent mirror interference.
The Nikon needs no modifications, just a good F-EOS adaptor.
Apr 03, 2009 at 08:43 PM
john_edwards
p.1 #5 · Just supposing I wanted
Thanks
Apr 03, 2009 at 08:47 PM
dmonterisi
p.1 #6 · Just supposing I wanted
i haven't tried it, but the Sigma 150mm is pretty well regarded around here.
http://www.fredmiranda.com/forum/topic/719491/0?keyword=sigma,150#6503485
not sure how important that 30mm difference is to you either.
there are other threads on the sigma if you search for it in this forum.
good luck
-damon
Apr 03, 2009 at 08:58 PM
pdmphoto
p.1 #7 · Just supposing I wanted
Sigma 150/2.8 APO macro is excellent for the money, and goes to 1:1. Also, consider the older Sigma 180/2.8 APO if 1:2 is good enough. They are not too hard to find in Nikon AF mount. The Canon mount ones will not stop down on the newer bodies. If you are lucky you might even find one in Nikon MF mount. I have one and it is superb.
Apr 03, 2009 at 10:48 PM
john_edwards
p.1 #8 · Just supposing I wanted
Yep I might go there (Sig 150), but I was thinking a little longer focal length as I'm ff. Thanks for everyone's ideas.
John
Apr 04, 2009 at 02:24 AM
helimat
p.1 #9 · Just supposing I wanted
Another vote for the Sigma 150. Sharp as heck even wide open, great colour. add a tube you have yourself over 1:1 and the longer focal length you desire.
Apr 04, 2009 at 02:38 AM
brucem48
p.1 #10 · Just supposing I wanted
Ditto the Sigma 150 Macro. Different type of lens almost to the point of being exotic. Full time manual and HSM to boot. Is just as effective as a portrait lens as it is a macro. Excellent tripod collar included and fine lens hood. Colors reproduce rich and saturated. No CA at all. If you hold one in your hand your a goner. Stellar IQ..Bruce
Apr 04, 2009 at 02:57 AM
pascal03
p.1 #11 · Just supposing I wanted
Actually... I would suggest the lens you are walking away from - the Canon 180mm f3.5 L is simply superb. I would choose it over just about alternative. Yes it is bigger, has slow AF, is expensive, etc. etc. But the results are very good.
Apr 04, 2009 at 03:21 AM
