Archive 2008 · Tripod mount for flash + umbrella
folivier
p.1 #1 · Tripod mount for flash + umbrella
I'm looking for an adapter that holds a hot shoe flash and an umbrella that mounts to a tripod. Any ideas where to find this?
Thanks,
Forest
Dec 07, 2008 at 09:58 AM
k7xd
p.1 #2 · Tripod mount for flash + umbrella
Be easy to make with 3/8 to 5/8 rod coupling and a short piece of 5/8 all thread.
Your local hardware store should have the parts.
Dec 07, 2008 at 10:23 AM
alanwarp
p.1 #3 · Tripod mount for flash + umbrella
The Bogen umbrella adapter has a threaded female stud (the brass thing) that will screw on your tripod, then you just need the shoe mount...If you get the metal one put some electrical tape on the bottom to protect you flash pins.
Bogen / Manfrotto 026 Swivel Umbrella Adapter
http://www.bhphotovideo.com/c/product/546375-REG/Bogen_Manfrotto_026_026_Swivel_Umbrella_Adapter.html
http://www.bhphotovideo.com/c/product/250400-REG/Smith_Victor_701955_Adapter_1_4_20_to_Standard.html
Alan
Dec 07, 2008 at 10:49 AM
cgardner
p.1 #4 · Tripod mount for flash + umbrella
Before going that route you should be aware that a tripod puts the light too low for most situations. Part of what makes lighting look natural or not is the direction of the light and the shadows it creates. Natural light, and most artificial light, comes from above the head. As a consequence if you put your flash and umbrella on a tripod at eye level or below the shadows go sideways and the pattern of highlight and shadow is less flattering. From the standpoint of logistics its a tripod is also far more cumbersome to transport, set-up and move around than a light stand.
So save yourself a good bit of frustration with logistics and results and buy yourself a real light stand in the 7-8ft. range. You can find them for as little as $20, but if you spend about $60 you will be making a lifetime investment in professional level gear. Here's a good stand for general use with hot shoe flash: LINK
Chuck
Dec 07, 2008 at 11:05 AM
