2 end
Archive 2008 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
rockitman
p.1 #1 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
Has anyone tested/compared the new Zeiss canon mount 21mm ZE lense against the lengendary 21mm Contax/Zeiss version with Canon adapter ?
I am curious how much my contax/zeiss version will drop in price, especially if the new Zeiss is as good, if not better....TIA
Dec 03, 2008 at 01:48 PM
gasrocks
p.1 #2 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
I do not think they are out yet. But, something many want to know.
Dec 03, 2008 at 02:35 PM
cogitech
p.1 #3 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
The MTFs (which are typically very reliable from Zeiss) indicate that the new one will be significantly better.
Dec 03, 2008 at 02:42 PM
Brody LeBlanc
p.1 #4 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
woa, is that even possible? :|
Dec 03, 2008 at 03:39 PM
cogitech
p.1 #5 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
Yes.
New on top, old on bottom:
(Image courtesy of stevenpa)
Dec 03, 2008 at 03:43 PM
bluetsunami
p.1 #6 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
I'm wondering what Zeisss strategy is. They seem to be releasing revised lenses in some focal lengths and retaining the Contax designs in the others (50/1.4 85/1.4).
Dec 03, 2008 at 04:27 PM
asbalyan
p.1 #7 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
Can any improvement be done in 50mm and 85mm (and even 135mm too, to some extent) focal length... Easiest to design...
Below 40mm, its all retro focus designs... with new design techniques and material sciences, you will keep seeing improvement... but in rangefinder, (I havent used any yet) it may be peaking there already...
Dec 03, 2008 at 04:40 PM
cogitech
p.1 #8 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
asbalyan wrote:
Can any improvement be done in 50mm and 85mm ....
In my opinion, yes, there is plenty of room for improvement.
Dec 03, 2008 at 04:56 PM
rockitman
p.1 #9 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
What is the ZE 21mm supposed to cost when released ?
Dec 03, 2008 at 05:05 PM
cogitech
p.1 #10 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
$1700 or so, I think.
I'll give you $800 for your Contax, though, so no worries.
Dec 03, 2008 at 05:20 PM
wayne seltzer
p.1 #11 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
You might want to look at the original thread here on this comparison:
http://www.fredmiranda.com/forum/topic/711268
Dec 03, 2008 at 05:30 PM
rockitman
p.1 #12 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
cute !
Dec 03, 2008 at 05:59 PM
mawz
p.1 #13 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
I'd agree, with the caveat that said improvement will require either more complex designs or use of exotic elements (a la the Sigma 50/1.4, Canon 50L, Summilux Asph)
Dec 03, 2008 at 06:02 PM
cogitech
p.1 #14 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
cute !
So, no deal then? You might regret that in 6 months.
Dec 03, 2008 at 06:07 PM
rockitman
p.1 #15 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
cogitech wrote:
cute !
Nah, I doubt the quality improvement if any will be that decernible. If the new sells at $1700, well my copy, at least to me will be worth that much...even though I paid $2,900 2 years ago....
Dec 03, 2008 at 06:39 PM
dcmiller
p.1 #16 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
The Euro has dropped against the dollar, so it might be less expensive in the U.S.
Dec 03, 2008 at 06:42 PM
Andi Dietrich
Account Locked
p.1 #17 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
I wonder how much this one is going for... I never thought the Distagon 21 would go under 1000$ one day!
D21 on ebay
Dec 05, 2008 at 12:23 PM
DanPBrown
p.1 #18 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
Here are the mtfs equalized in scale. The new 21 is in red.
www.danbrownphotography.com
Dec 05, 2008 at 12:49 PM
Mike Hatam
p.1 #19 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
Anyone know when we'll see the new version hit the store shelves?
Dec 05, 2008 at 06:48 PM
Grant808
p.1 #20 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
Thanks for the overlay Dan...looks like significant improvement in most areas. But there may be more CA...
I wonder what the distortion will be like...
Dec 05, 2008 at 09:25 PM
Grant808
p.1 #21 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
D21 on ebay
haha...I know that guy...
Dec 05, 2008 at 09:29 PM
Andi Dietrich
Account Locked
p.1 #22 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
I am sceptical if the new lens is better overall. The Z18's biggest issue is that it does not improve beyond f5.6, well no, the biggest issue to me is actually the shading.
The point is that you dont see everything in the MTF and a wideangle should not be judged at f 5.6 IMO. Of course the eos mount is the step forward and not the performance itself
Dec 05, 2008 at 09:58 PM
Valorin
p.1 #23 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
Andi, what do you mean by shading with the ZF18? I'm waiting to see what the ZF21 will be like, and choose between that and the ZF18. I anticipate (as everyone does) that the ZF21 will be quite a bit better than the ZF18, but I would prefer 18mm focal length. If I can get sharp corners with the ZF18 at f/11, I might just pass up on the ZF21.
Dec 05, 2008 at 10:23 PM
cogitech
p.1 #24 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
The CZ21 is well-known to perform best at f5.6 as well. My copy sure did. The thing is, it has abundant DOF at f5.6, so it is hardly an issue.
Dec 05, 2008 at 11:27 PM
Andi Dietrich
Account Locked
p.1 #25 · Zeiss 21mm ZE vs Contax/Zeiss 21mm
Valorin, the 18mm has great corner sharpness, sharp at f 5.6 - f 11 depending on situation. Probably a DOF question. Corner sharpness is the only thing I see a real advantage compared to my 16-35ii.
I should have said Vignetting, corners just go black at f4, like many of the old classic wide angles, it starts to get better at 5.6 though, so this may be fine for you.
I know it sounds stupid but I dont see why Zeiss would design a lens which is so sharp wide open and forget to correct vignetting. IMO zoom lenses have set a new standard here and we use WA in a different way than years ago.
Cogitech, so which is your favorite now the old or the ZE?
Dec 06, 2008 at 12:13 AM
2 end
