Archive 2008 · CS4 upgrade - Plugins worked?
DopamineHunter
p.1 #1 · CS4 upgrade - Plugins worked?
contemplating upgrading to CS4 but worried about slew of plugins that i use may not work. anyone who has done the upgrade, how did the plugins handle the upgrade, did they continue to work after the upgrade?
i use Nik software (silver, viveza, sharpner, dFine, colorefx)
OnOne (whole suite)
AlienSkin BlowUp
Neat image
Photokit
Thank you
Nov 01, 2008 at 06:20 PM
ohenry
p.1 #2 · CS4 upgrade - Plugins worked?
I have OnOne Suite 4 and Photokit Sharpener and Color, Photomatix, Noiseware, and PTLens all working flawlessly on CS4.
Nov 01, 2008 at 06:47 PM
Bifurcator
p.1 #3 · CS4 upgrade - Plugins worked?
The first 3 in your list worked for me. I'm on a Mac tho if it differs...
Nov 01, 2008 at 06:54 PM
Gil_W
p.1 #4 · CS4 upgrade - Plugins worked?
Go to Nik site, they adress the issue. You need to have Dfine installed. OnOne has a new versions, Neat Image and PK Sharpener works.
Best thing to do with these plugins is to just go to their web site and see if there are any issues or new releases or versions, which is exactly what I did.
Gil
Nov 01, 2008 at 08:20 PM
srudy
p.1 #5 · CS4 upgrade - Plugins worked?
If you upgrade, make sure you reinstall your plug-ins to CS4, rather than copying or moving them from the CS3 plugin folder. Also, make sure CS4 is looking in the right place for plugins. For some reason my CS4 defaulted to looking in the CS3 plug-in folder. I had a variety of odd error messages until I figured that out.
I have installed Nik Silver Efex and Imagenomic Noiseware and both work fine. The Nik Selective Tool requires the Dfine 2.0 download mentioned by Gil. Check their FAQ
Nov 02, 2008 at 07:24 PM
WAYCOOL
p.1 #6 · CS4 upgrade - Plugins worked?
Photokit may be the only one with a x64 version though. Your 32 bit plugins won't work under x64 Vista or XP.
Nov 02, 2008 at 08:10 PM
paulhodson
p.1 #7 · CS4 upgrade - Plugins worked?
Neat Image seems OK
Nov 13, 2008 at 09:15 AM
Alistair Watson
p.1 #8 · CS4 upgrade - Plugins worked?
NeatImage+ Pro and IntelliSharpen both work fine in CS4.
Nov 13, 2008 at 09:46 AM
Jeffrey
p.1 #9 · CS4 upgrade - Plugins worked?
What about Fred's plugins? WP Pro, SI Pro, VelviaVision, CS Pro. ?? I just ordered CS4.
Nov 13, 2008 at 05:00 PM
nburwell
p.1 #10 · CS4 upgrade - Plugins worked?
^ I wondered the same thing, Jeffrey. I asked the question a few weeks ago since I have VelviaVision for CS3 and will probably upgrade to CS4 around Christmas time. I would hope they would, but since you already ordered CS4, I'm sure you will know first hand before me.
-Nick
Nov 13, 2008 at 09:15 PM
Alistair Watson
p.1 #11 · CS4 upgrade - Plugins worked?
Fred's Intellisharpen plugin works just fine in CS4.
Nov 14, 2008 at 04:02 AM
bshamilton
p.1 #12 · CS4 upgrade - Plugins worked?
Velvia Vision from Fred does not work. He responded to my question about it and said he needs to adapt it for CS4. Another update coming soon, I hope.
NIK and Photomatix stuff is fine.
Nov 14, 2008 at 01:23 PM
nburwell
p.1 #13 · CS4 upgrade - Plugins worked?
Well now we know VV does not work with CS4. Thanks for the answer, Barry!
-Nick
Nov 14, 2008 at 07:31 PM
Mark Sisco
p.1 #14 · CS4 upgrade - Plugins worked?
Isn't the scoop that most of the plugins will work if CS4 is install/used as 32 bit, but 64 bit is an issue until plugins address this capability? Think I read this somewhere.
Nov 14, 2008 at 08:03 PM
Jeffrey
p.1 #15 · CS4 upgrade - Plugins worked?
There might also be differences in plugin compatibility with Macs or Windoze.
Nov 14, 2008 at 10:08 PM
DIS Ottawa
p.1 #16 · CS4 upgrade - Plugins worked?
I can attest that Nik Colour Efex 3.0 and Imagenomic's Noise Ware do not work in CS4 64 bit. Nik assured me that their products would work in 64 bit within two weeks of CS4's launch date and yet they still don't. Now they won't respond to my emails asking when they will work. I am not impressed.
Nov 14, 2008 at 10:16 PM
dan727
p.1 #17 · CS4 upgrade - Plugins worked?
Correct, the Mac version is still 32bit so all the 32 bit cs3 plugins will work. On windows x64 and using the 64 bit cs4, the plugins will need to be re-written.
Nov 14, 2008 at 11:07 PM
