FM Actions & Plugins support
Workflow Guidelines
Archive 2008 · calibrating 2 monitors?
torontonic
p.1 #1 · calibrating 2 monitors?
Hi,
I have 2 24inch dell monitors, one is the 2407 the other is the 2408. Identical monitors. I've had the 2407 for about a year, the 2408 is a few months.
im using a spyder2pro. just wondering if anyone has tips on getting both monitors right on. should i simply run the app on each, or should custom settings be involved?
May 09, 2008 at 06:34 PM
Mr Mouse
p.1 #2 · calibrating 2 monitors?
If you are running Windows XP you will need to download and install Microsoft's Color applet and change the Look Up Table loaded installed by your collaborator application with Microsoft's applet "wincolor.exe" and don't forget to include the "/L" parameter load the LUT using the tables from both of your displays ICC color profiles.
May 09, 2008 at 08:30 PM
himcheong
p.1 #3 · calibrating 2 monitors?
i have a similar question
i am using a imac 24"glossy and a cinema display
when i calibrate one of the monitor, it uses the same profile over my second display as well
and the colours just don't seem right to me...
anyone knows how to solve this...??
May 11, 2008 at 08:37 PM
Matt_3D
p.1 #4 · calibrating 2 monitors?
The Spyder2Pro allows you to calibrate 2 monitors so I'm assuming that the best way to go would be to run the once on each monitor. As for getting both monitors exact, goodluck At work we only have the Spyder2 non-pro version which doesn't allow for dual-screen so after calibrating the 1st monitor, I just replicate the rgb/brightness setting on the other. It's not perfect, but I've got in the habbit of doing all my image work on the left monitor and keeping all the other stuff on the right.
May 11, 2008 at 11:51 PM
torontonic
p.1 #5 · calibrating 2 monitors?
thanks Matt, much appreciated.
May 12, 2008 at 12:01 PM
SoundHound
p.1 #6 · calibrating 2 monitors?
I use the Basic Color Program and the x-rite Hocky Puck to calibrate my 5 monitors. I tried a cheap Spyder-useless! It does a really good job but you will want to trust only one monitor for exacting work.
May 14, 2008 at 02:15 AM
