Login · Register · Software · Image Upload · Buy & Sell · Hosting
FM Hosting
Rules: One new topic per day
FM Forums | People Photography | Join Image Upload
Pablo Vicente
Image Upload: Off
Vicky - speedlite + softbox
Here's Vicky with a speedlite through a portable softbox :
set-up pic :
http://www.digitalpixels.net/index.php/2008/03/photos-with-canon-580ex-speedlite-flash-on-slave-trigger-by-550ex-master-through-portable-softbox-iii
greetings,
Pablo
www.pablovicente.com
Mar 27, 2008 at 11:23 PM
SensorDust
Image Upload: Off
It is too much light for fill flash. Normally I dial flash exposure comp (FEC) -1 1/3 f-stops. If you wanted the flash to be main light then I would dial -1 to -2 f-stop underexposure from metered background. I just say this because the background looks properly exposed but the models features are too bright.
Mar 28, 2008 at 12:52 AM
Pablo Vicente
Image Upload: Off
I did the other way around and pushed it 1/3 to 1 up
"de gustibus" I guess
Mar 28, 2008 at 01:18 AM
Heatseeker99
Image Upload: Off
He never said he used this for "fill flash." He is creating a lighting pattern, not just filling in pockets. Good use of flash IMO.
Mar 28, 2008 at 05:56 PM
Pablo Vicente
Image Upload: Off
I tend to push the flash up indeed as I like the subejcts to stand out
the ambient was stopped down, the flash up
hairlight is the sun
saludos,
Pablo
Mar 28, 2008 at 06:38 PM
cgardner
Image Upload: Off
Not sure what mood you were going for with the WB but the trees are giving the model an overall green color cast, which is common for photos taken under / around foliage. Pink skin + green light = gray pallor. Because our eyes adapt its difficult to see the green bias when shooting, but if you are under trees it will always be there.
Setting custom WB off a gray card held by the model or just having her hold one as a reference is a good preventative measure. When shooting the WB setting shot outdoors I always first set my camera WB to "daylight". After setting the custom WB using that shot I'll shoot the card again with the Custom WB shot. Toggling back-and-forth between the before-after card shots provides a clue what the actual color temp is relative to daylight.
There's also a tree growing out of her head in the second shot
Mar 28, 2008 at 07:13 PM
Pablo Vicente
Image Upload: Off
thanks for the detailed remarks
good to see these pointers here
Mar 28, 2008 at 09:53 PM
lamonteith
Image Upload: Off
Color and exposure look perfect on my monitor. Good shot.
Mar 29, 2008 at 04:27 PM
prismshian
Image Upload: Off
Hi pablo,
What portable softbox are you using? Is it a self created/modified one? Or are you using lastolite?
Mar 29, 2008 at 05:00 PM
MagnusMan
Image Upload: Off
I like the balance of flash and natural light. Beware of the tree (or pole) coming out of here head in the 2nd pic.
Mar 29, 2008 at 07:54 PM
Pablo Vicente
Image Upload: Off
thanks
As for the softbox, you can see some photos here :
http://www.pablovicente.com/speedlite-flashes-umbrella-softbox-550ex-580ex-slave-master-flash.html
I have that question often so I'll be shooting the pieces apart and put them in hi-res
saludos,
Pablo
Apr 08, 2008 at 12:59 PM
  Username   Password   Lost password?
