Moderated by: guardian
FM Forums | General Gear-talk | Join Image Upload
Justin Huffman
Image Upload: On
p.1 #1 · Lee filters and ultra wide lenses
friends - I switched from cokin P filter system to a Lee 100mm system and to my dissapointment, the 77mm ring still vignettes on a tokina 12-24. Does anyone know if the wide angle ring will correct this ? link
thanks
Justin
Edited on Nov 14, 2007 at 02:36 PM
Nov 12, 2007 at 08:27 PM
Jeffrey
Image Upload: On
p.1 #2 · Lee filters and ultra wide lenses
moved here.
Nov 12, 2007 at 09:53 PM
Justin Huffman
Image Upload: On
p.1 #3 · Lee filters and ultra wide lenses
anyone?
Nov 14, 2007 at 01:50 PM
sjms
Buy and Sell: On
p.1 #4 · Lee filters and ultra wide lenses
did you get the Lee SWM 77mm ring?
did you remove the holder notches down to only one?
even at FF which i usually shoot there are limitations at 16mm if rotated to about 30deg off vertical alignment it will vignette a little. its just one of those things i either avoid or touch up later,
Edited by sjms on Nov 14, 2007 at 09:42 AM GMT
Nov 14, 2007 at 02:32 PM
Justin Huffman
Image Upload: On
p.1 #5 · Lee filters and ultra wide lenses
sjms - not sure what swm is, super wide mount perhaps? i included a link in the OP, maybe thats the one your talking about.
Nov 14, 2007 at 02:34 PM
sjms
Buy and Sell: On
p.1 #6 · Lee filters and ultra wide lenses
yes it is the super wide mount. and it will help
using that mount as i do moves the whole filter assy as far back as it can go without making physical contact with the actual lens ring itself. it give you a degree or two more latitude
sorry didn't see the link
a 12mm lens on a 1.5 crop camera will result in a roughly 17mm FF effect
Lost password?
