FM Actions & Plugins support
Workflow Guidelines
Archive 2006 · Vignetting
TJ Asher
p.1 #1 · Vignetting
Hi folks,
I've seen quite a few wedding photogs that seem to have a real handle on vignetting a photo in Photoshop and making it look natural and not too much nor too steep a transition.
Mine never seem to look right. Anybody got any suggestions?
Sep 17, 2006 at 03:57 AM
jobe
p.1 #2 · Vignetting
Hi Todd
One way I like to use is the dodge tool, use a large soft brush with about 20% opacity, select the hightlights and sweep around the edges, then change to the midtones to darken as to your liking.
Wayne
Sep 17, 2006 at 06:40 AM
pamorl
p.1 #3 · Vignetting
Here's how I do vignettes: This method gives a more subtle looking vignette.
- Using the marquee tool, make a selection. I usually do an oval or rectangle.
- Feather a good amount. Hit Ctrl+shift+i to invert the selection.
- Now, with the selection still active, open a curves adjustment layer. Your mask should be attached automatically. Pull the middle of the curve towards the bottom right corner. A little goes a long way. You might also try changing the blend mode of the curves layer to soft light for a slightly different look.
- If you want a lighter vignette, pull the middle of the curve up towards the upper left corner. Try setting the blend mode to screen.
If you want a more dramatic, heavier vignette, rather than opening a curves layer after inverting the selection, simply open a new layer and fill the inverted selection with black or white. Then adjust the opacity.
Pam
http://www.pbase.com/pam_r
'art is working on something 'til you like it...then leaving it that way'
Edited by pamorl on Sep 17, 2006 at 08:52 PM GMT
Sep 17, 2006 at 09:22 AM
centurion
p.1 #4 · Vignetting
Heres how I apply vignettes so that the user has the up most control over its strenght and placement
Make a new layer above your image and fill it with black.
Change the opacity until you get the strenght you need.
Add a layer mask to the black layer then choose a soft large brush to bring back the orginal image.
Using different opacitys and size brushes will give you more control too.
Gav
Sep 17, 2006 at 04:30 PM
coder
p.1 #5 · Vignetting
I've used this process..
Duplicate your layer
Use the gradient tool (choose the round one, check the reverse box)
"draw" your gradient on your picture (I start somwhere in the middle and just keep fidding with it until I get what I want)
Set your layer properties to something other then "Normal"... to something like "Darken" or "Soft light" and then set your opacity and fill to taste.
Sep 17, 2006 at 04:43 PM
jimdavies
p.1 #6 · Vignetting
try the lens corection tool in Photoshop. Filter>Distort>Lens correction
Go to vignette and darken it. Looks pretty good but there is more control with other ways.
Sep 17, 2006 at 10:06 PM
truthinlight
p.1 #7 · Vignetting
would you guys mind posting some pictures to go along with your workflow? If you could that would be awesome!
thanks,
Sep 18, 2006 at 12:42 AM
TJ Asher
p.1 #8 · Vignetting
Thanks for the tips folks. I'll definately be giving them a try on the set from this weekend.
Sep 18, 2006 at 01:06 AM
Arland
p.1 #9 · Vignetting
I 2nd jobe's technique. Been doing just that.
Sep 18, 2006 at 01:24 AM
Michael H
p.1 #10 · Vignetting
I just learned a really easy way to do this from Vincent Versace...
duplicate layer
change blend mode to overlay
use the selection tool in a shape you want the brighter area to be. Standard rectangle works just fine.
increase feather to somehwhere around 100. More if you want is smoother.
hit the delete key. This just deletes the selection with the feathered edge.
duplicate
blend to overlay
select
feather
delete
Sep 18, 2006 at 08:10 PM
