molson Online Image Upload: On
p.1 #2 · Filter or lense issue (17-55dx)? | |
GunnarIngvi wrote:
Hi there,
I just got the 17-55dx and after testing it last night I noticed something strange. If you look at the picture on this URL http://www.gunni.is/lense/ you can see that right over the windscreen the license plate is refected upside down. Two green dots are on each side, probably reflection of the car light.
The question is, what is causing this? Is it possibly the Skylight 1A filter 77mm from ROWI I am using? Is it a lense defect, it does not look like a flaire does it?
Another question, maybe I should not be using a Skylight filter on it? Where can I find top-of-the-line filters, that for sure do not degrade the lense performance? Should I be using a clear filter from Nikon?
Thanks and best regards,
Gunnar Ingvi
I would expect it is your filter causing the problem. All filters degrade lens performance to some degree; If you really feel you need a filter, I would buy a good multi-coated version, although even that may not help with a DSLR.
Edited on Sep 30, 2005 at 01:14 AM
