Archive 2014 · Canon Releases EOS 6D Firmware Version 1.1.4
Admin
p.1 #1 · Canon Releases EOS 6D Firmware Version 1.1.4
Firmware Version 1.1.4 incorporates the following fixes:
  1. Fixes a phenomenon in which some images cannot be transferred to mobile devices running the EOS Remote app.
  2. Corrects an error in the German language Feature Guide.
  3. Corrects an error in the Korean language Feature Guide.
Firmware Version 1.1.4 is for cameras with firmware up to Version 1.1.3. If the camera's firmware is already Version 1.1.4, it is not necessary to update the firmware.
Please note: After the firmware update has been performed the following setting will be reset to default.
Menu > Custom Function> C.Fn II: Autofocus > AF Microadjustment> 1: All by same amount
When updating the firmware of the camera, please review the instructions thoroughly before you download the firmware.
Download Firmware Version 1.1.4 for the EOS 6D Camera
Canon EOS 6D at B&H Photo ($1,749)
Mar 18, 2014 at 08:52 PM
wtlloyd
p.1 #2 · Canon Releases EOS 6D Firmware Version 1.1.4
Doesn't seem to be up just yet, at that link.
Edit 5 min later: Whoops that was quick. Never mind.
Mar 18, 2014 at 09:16 PM
oceanliuhome
p.1 #3 · Canon Releases EOS 6D Firmware Version 1.1.4
updating! thanks
Mar 18, 2014 at 10:17 PM
johnctharp
p.1 #4 · Canon Releases EOS 6D Firmware Version 1.1.4
No exposure compensation in manual mode?
No AF at f/8?
Mar 18, 2014 at 10:29 PM
Pixel Perfect
p.1 #5 · Canon Releases EOS 6D Firmware Version 1.1.4
No AF at f/8?
Yup, should have read
"does not correct and error whereby the use of M mode and Auto ISO is crippled"
http://www.fordxr6turbo.com/forum/public/style_emoticons/default/furious.gif
Mar 18, 2014 at 11:22 PM
Gochugogi
p.1 #6 · Canon Releases EOS 6D Firmware Version 1.1.4
Haha! I didn't notice any errors in the Korean but the 6D menu gave me a warning after the update: "Irregular communication with battery. Do you still want to use it?" So looks like Canon has sniffed out my STK clone. My genuine LP-E6 is fine...
Mar 19, 2014 at 12:26 AM
johnctharp
p.1 #7 · Canon Releases EOS 6D Firmware Version 1.1.4
If they're killing more third-party batteries, they can keep this update- I have a pair that work very well, in addition to my OEM's.
Mar 19, 2014 at 02:59 AM
thw2
p.1 #8 · Canon Releases EOS 6D Firmware Version 1.1.4
Done. No problem for me.
Mar 19, 2014 at 08:21 AM
Cliff L.
p.1 #9 · Canon Releases EOS 6D Firmware Version 1.1.4
Should have read:
"Does not fix noobie misconception that they are somehow controlling exposure manually if Auto ISO is enabled"
Mar 19, 2014 at 10:01 AM
johnctharp
p.1 #10 · Canon Releases EOS 6D Firmware Version 1.1.4
molson wrote:
Should have read:
I'm not sure what you mean by that. I've run into this issue on every Canon camera I've shot- they really need to fix it. The functionality can't be replicated otherwise.
Mar 19, 2014 at 11:31 AM
Pandemic
p.1 #11 · Canon Releases EOS 6D Firmware Version 1.1.4
I took it to mean that, in MANUAL mode, your camera should not AUTO anything, least of all the ISO, Aperture, or Shutter speed.
Mar 19, 2014 at 11:37 AM
johnctharp
p.1 #12 · Canon Releases EOS 6D Firmware Version 1.1.4
Well, here's the thing- you have two dials, already dedicated to shutter speed and aperture. Assuming you want per-shot control of those two variables, and considering that cameras these days can handle higher-ISOs just fine, it seems reasonable to let the metering system figure out the 'correct' exposure.
Except when it doesn't; in this case, you'd want to be able to tell the camera to shoot brighter or darker than what's metered, and the way to do that is through exposure compensation in manual mode.
Mar 19, 2014 at 11:58 AM
form
p.1 #13 · Canon Releases EOS 6D Firmware Version 1.1.4
If they did a firmware update that allowed 1/8000 ss and 1/200 flash sync, I might buy one.
These things are almost definitely software limitations, not hardware. It's not like they were conserving space with the shutter mechanism by throwing a full frame REBEL-grade shutter in the camera. It still takes up the same amount of space.
I still think it's just wrong that they did that to a camera, then still charged almost $2k for it.
Edited on Mar 19, 2014 at 12:32 PM · View previous versions
Mar 19, 2014 at 12:25 PM
kylebarendrick
p.1 #14 · Canon Releases EOS 6D Firmware Version 1.1.4
All I wanted was AF at f/8. Oh well.
Mar 19, 2014 at 12:27 PM
abqnmusa
p.1 #15 · Canon Releases EOS 6D Firmware Version 1.1.4
people sure like to complain about Canon
my 6D has been a great camera.
Yes, I would like auto focus at F8 as an update.
Mar 19, 2014 at 12:33 PM
Eric Gottesman
p.1 #16 · Canon Releases EOS 6D Firmware Version 1.1.4
Are you including focus in that?
Auto focus is generally accepted, why not ISO with exposure compensation?
My workaround is Av with minimum shutter speed. I can get compensation while still having control over aperture and a workable shutter speed.
When using a flash I almost always use full manual including ISO.
Mar 19, 2014 at 12:47 PM
lighthawk
p.1 #17 · Canon Releases EOS 6D Firmware Version 1.1.4
EOS Remote wifi util doesn't work.
Phone disconnects because internet is 'slow'
I was hoping the new update would address this issue
Mar 20, 2014 at 01:00 AM
dhphoto
p.1 #18 · Canon Releases EOS 6D Firmware Version 1.1.4
Canon could bring out the finest camera ever made for $500 and you'd still complain that Nikon were better.
Your drivel really gets boring.
Mar 20, 2014 at 03:32 AM
CanonPhotog
p.1 #19 · Canon Releases EOS 6D Firmware Version 1.1.4
John, I'm slow this morning. You lost me there somehow. In Manual mode, adjusting shutter speed, aperture, or ISO is exposure compensation. That's how it works. What am I misunderstanding?
Mar 20, 2014 at 05:00 AM
dhphoto
p.1 #20 · Canon Releases EOS 6D Firmware Version 1.1.4
You probably know this but on some newer Canons if you leave the ISO on auto in M mode the camera will try and obtain a correct exposure by changing the ISO while leaving the SS and AP as you set them.
This is all very well and clever but if you don't like the exposure the camera has chosen you have no means of changing it - ie you can't use 'exposure compensation' in M mode, which would be quite useful (you could alter it so it didn't underexpose a white dress by trying to make it grey, but still have control over depth of field and shutter speed for example). You can do this with the new FW on the 1Dx (I think) and it would be good if the other cameras did this too.
Mar 20, 2014 at 05:47 AM
