Sigma announced the Sigma 18-35mm F1.8 DC HSM Art lens, the market’s first zoom lens to break the f/2.0 barrier and achieve a maximum aperture F1.8 throughout the entire zoom range.
This wide aperture standard zoom lens is created for DSLR cameras with APS-C size sensors, which translates to a focal range of 28-55mm on a 35mm camera. With a minimum focusing distance of 11 inches, and a maximum magnification ratio of 1:4.3, the 18-35mm is ideal for landscapes, portraits, still-life, studio, close-up and casual photography.
Specifications:
Lens Construction: 17 Elements in 12 Groups
Angle of View (SD1): 176.5º-44.2º
Number of Diaphragm Blades: 19
Mininum Aperture: 1f16
Minimum Focusing Distance: 18 cm/ 11.0 in
Filter Size (mm): 172mm
Maximum Magnifications: 11:4.3
Dimensions (Diameter x Length): 18mm x 121.0mm/3.1in. x 4.8in.
Weight: 128.6oz
Corresponding Mounts: Sigma, Nikon and Canon
saneproduction wrote:
May be worth picking up an APS-C camera for!
For an effective 27-52.5mmm f2.6 lens? This gives crop users similar dof and light gathering as the 2.8 zooms on FF which is nice, still FF will have advantages in resolution etc.
RobDickinson wrote: For an effective 27-52.5mmm f2.6 lens? This gives crop users similar dof and light gathering as the 2.8 zooms on FF which is nice, still FF will have advantages in resolution etc.
Its hopefully a decent lens tho.
Light gathering would be 2 times bigger, even though DOF won't be related to that. The shutter thus would be 2 times faster, which is also nice. And until now, there just wasn't any crop equivalent (including DOF) of the f/2.8 FF zooms.
Yeah but you also have to factor in the camera performance . You get faster shutter speeds by 1 1/3 stops but a modern ff should be able to increase the iso by at least 1 1/3 stops to cover that .
And then add in the fact that you can many other ff 2.8 zooms and faster primes .
That said this looks a real good move on sigmas part . It will be interesting to see what sort of cost they get this out for and if they can get a crop 35-135 (ish) 1.8 or f2 zoom to go with it . I think I would seriously consider 18-35/1.8 35-130/2 & 120-300/2.8 as a full sigma lens set (I already have the 120-300) on my 7D or future 7D2
Damn, I have been praying for a 20-35 f/2 for FF, but this wouldn't be half bad for APS-C if I could make myself actually buy a crop lens, something I've never done.
