p.1 #1 · Over exposed from flash bouquet toss, please help!!
I had accidentally over exposed the bouquet toss from a wedding I did a few weeks ago. Does anyone have any suggestions or ideas on adjusting this in Lightroom or cs6? I can upload the picture when I get home. Please help!!
p.1 #2 · Over exposed from flash bouquet toss, please help!!
If you have the raw file from the camera you have a better chance of getting a decent image from it than if all you have is the camera jpeg file. That is one of the primary advantages of working with raw files-more latitude to handle over or under exposed images.
Apr 08, 2013 at 02:46 PM
mshi Offline [X]
p.1 #3 · Over exposed from flash bouquet toss, please help!!
post your image first before anyone can help you with ideas. it doesn't need to be raw since jpeg is fine.
p.1 #7 · Over exposed from flash bouquet toss, please help!!
15Bit wrote:
When i over expose i tend to process in high key for an arty look.
Toss enough sugar in the mix and you can make some yummy lemonade from yucky lemons.
+1 @ sometimes this is much easier/faster than performing a good correction ... kinda depends on the image if you go for correction vs. something "creative".
p.1 #8 · Over exposed from flash bouquet toss, please help!!
WAYCOOL wrote:
Wow sight unseen your 100% sure there is information to be recovered in the raw, your good. Can you give me the powerball winning numbers?
Given the information provided by the OP, Allan has given good advice.
No, he doesn't know if there is information to be recovered in the RAW.
- if the adjustment brush works, great!
- if it doesn't work, perhaps the picture is beyond saving.
p.1 #9 · Over exposed from flash bouquet toss, please help!!
Do you have a better suggestion?
Just because the adjustment brush may not get the job done, doesn't mean that the image is beyond saving. CS6 offers more capability for contending with problems than LR. Until we see the image, we can't know whether it will fall into the realm of capability for LR, or will need the full realm of possibilities that CS6 offers. Also, while the adjustment brush may offer an improvement/solution, it may be possible to provide a more "refined" one via CS6.
A few tools that CS6 has that are beyond the capability of the adjustment brush in LR are:
LAB
Layers
Channels
Calculations
The solution(s) could range from the simplicity of the adjustment brush in LR, to a multi-step approach in CS6.
Suggestion(s) will depend on the image ... i.e. too early to tell what approach(es) are warranted as viable, even though the adjustment brush can probably cover 80%-90% of routine stuff.
Bring on the pic, and let's see what we've got to work with ... i.e. easy, challenging or disastrous.
p.1 #10 · Over exposed from flash bouquet toss, please help!!
The only way to find out if there is information, is to try it.
p.1 #11 · Over exposed from flash bouquet toss, please help!!
I think it was the "Done." aspect that was perceived as rather presumptuous ... although, I figure you meant it as referring to the expediency & simplicity of using the adjustment brush for the most typical scenarios/instances. 80%-90% of the time, it might be that simple, but that doesn't quite make it the foregone conclusion suggested by the emphatic of "Done." ... especially, sight unseen.
p.1 #14 · Over exposed from flash bouquet toss, please help!!
its the internet...anything is possible. Its another case of hit and run...he probably posted this on many sites and got the answer from the one he usually hangs on. only has 4 posts on FM
p.1 #15 · Over exposed from flash bouquet toss, please help!!
Thanks RustyBug, Couldn't have said it better myself.
The OP had a question about a specific file, a smart ass general answer may or may not be the solution. Being a wedding photographer it could be assumed that something as simple as a brushed on exposure adjustment was within his skill set. To give a truly useful answer one would need to see the raw file. The definitive "Done." is what gave the impression of a smart ass answer.
Probably dose not matter as Sonny said could be a drive by and we will never see the raw.
