Archive 2013 · Ringlight to Compliment Einsteins
brettpatrick
p.1 #1 · Ringlight to Compliment Einsteins
Hi guys. I'm thinking about adding a ringlight to my studio setup. I currently have 6 Einsteins which work very well for me. Unfortunately Paul C. Buff doesn't make an Einstein ringlight. I could opt for the ABR800, but haven't met too many people who are happy with it. In addition, adding a speedlight doesn't make sense to me.
With this in mind, what ringlight might you recommend?
Jan 30, 2013 at 06:19 PM
gpop
p.1 #2 · Ringlight to Compliment Einsteins
I like my abr800. the build may be a bit weak, but the moon unit attachments are a hoot.
what concerns do you have with the abr800?
do you need self contained or would the buff zeus unit work for you?
Jan 30, 2013 at 07:47 PM
basehorhonda
p.1 #3 · Ringlight to Compliment Einsteins
Like all of PCB stuff, its pretty good for the price. Ive borrowed one a few times and always had good results from it.
Jan 30, 2013 at 09:20 PM
kenyee
p.1 #4 · Ringlight to Compliment Einsteins
Anything else would be easily over $1K.
You can get a Profoto ringlight modified to work w/ Speedotron packs.
You can get a Dynalite ring light and plug it into a Zeus pack.
These are all easily around $2K w/ the pack...
Jan 30, 2013 at 10:13 PM
cgardner
p.1 #5 · Ringlight to Compliment Einsteins
Not sure I understand what you are saying here? Speedlight ring flash like the Canon MR-14?
What specific "ring light" look are you going for? Flat shadowless lighting or the funky ring catchlights?
FWIW - You can get a similar flat 2D look with a one of Buff's 22" dishes placed just over the lens with the model's nose on the axis of the light so it is shadowless on the face.
Jan 31, 2013 at 07:55 PM
brettpatrick
p.1 #6 · Ringlight to Compliment Einsteins
Thanks for the feedback, I appreciate it. My concerns with the the PCB unit are that I've read it is uneven in terms of color output, I've read the attachments are very difficult to use, and I've been told it feels cheap. All things considered, perhaps I'll give the ABR800 a chance so I can decide for myself.
As for the other questions:
I'm not interested in a speedlight attachment such as the Ray Flash or Orbis. Not quick or powerful enough for my use.
In terms of look, I don't consider the ringlight a flat look. Far from it actually. Catchlights are of no consideration to me.
I'm not interested in using a beauty dish as a replacement for a ring light. They are two completely different looks.
Jan 31, 2013 at 08:17 PM
cgardner
p.1 #7 · Ringlight to Compliment Einsteins
It's not the tool, but how it's used that produces the desired result.
As for "flat" I was referring to the lack of sideways shadow clues. In terms of cause and effect with a ring light the "cause" is the source being exactly on the lens axis. The "effect" is that the camera sees few 3D shadow clues except those created front>back on 3D object by fall inverse-square fall off. Light-subject distance controls the rate of the fall off and gradient front>back. 3D shape clues are also created by the specular highlights on the face and because they fall lower on cheeks and other parts of the face than the downward modeling highlight / shadow clues typically seen in natural light the overall impression of a ring light shot is for lack of a better description like a "deer in the headlights" vs. more typical downward vector key lighting which simulates the look of natural daylight.
Jan 31, 2013 at 08:50 PM
kenyee
p.1 #8 · Ringlight to Compliment Einsteins
$400 vs. $1-2K.
There's a reason for that...
Don't crank it under 1/4 power and you'll be fine w/ color output.
Jan 31, 2013 at 09:43 PM
brettpatrick
p.1 #9 · Ringlight to Compliment Einsteins
kenyee wrote:
$400 vs. $1-2K.
Good advice. Thanks.
Jan 31, 2013 at 10:43 PM
sleibrand
p.1 #10 · Ringlight to Compliment Einsteins
brettpatrick wrote:
...I've read it is uneven in terms of color output, I've read the attachments are very difficult to use, and I've been told it feels cheap.
There is some variability in the color of the light, primarily at low power settings. In my usage, it's very easily corrected since I typically use the ring flash as the only light source on the subject. A quick tweak to color in post takes care of it.
The other 2 comments are true. IMO, the camera mount is a real pain to use. I spent a good bit to get an additional RRS clamp/plate that are permanantly mounted to the ring flash. Even with that it's a hassle to use.
I've become spoiled by the PLM's and newer softbox's with their umbrella design and ease of use. It's a lot less fun to have to mess with the moon units. They're pretty similar to old-school softboxes. If you're used to setting up and breaking down those you probably won't have too much problem. They do seem to hold up pretty well but the plastic and fiberglass construction make them feel cheap.
Feb 04, 2013 at 11:17 AM
Waki
p.1 #11 · Ringlight to Compliment Einsteins
There is a 18" LED ring light by Stellar Systems getting some good press. It goes on a stand, you shoot thru it or use it above or below, or to the side if that floats your boat. I've seen some pretty cool results. The pics pop. I think it's $200 or so. It's not exactly an on camera ring light but depends on what you are looking for.
Elinchrom sells the ECO RX Quadra ring light kit for $1800 or there abouts. Portable. Adjustable power. With another RX head you have another light besides a ring light.
The AB800 is pretty reasonable for sure but it is heavy.
Feb 05, 2013 at 03:27 PM
John Skinner
p.1 #12 · Ringlight to Compliment Einsteins
I've seen and used the LED units. They have a LONG way to go for results.
It is too bad Paul C hasn't updated or incorporated the ring light over to a more up to date E640. But in as much as color cast. I'm having a hard time thinking that people are not using something like a 'ColorChecker Passport' in their workflows.
ProFoto 8a Airs or E640's.. The passport is the first, middle and last shot I make.
Feb 05, 2013 at 06:51 PM
jzucker
p.1 #13 · Ringlight to Compliment Einsteins
I'm using an 18" flo light and it works great. I shoot it at ISO 640 with 1/80 @ F5.6.
http://www.amazon.com/Stellar-Photo-Video-Compact-Fluorescent/dp/B003MC1QLK/ref=sr_1_2?ie=UTF8&qid=1360356138&sr=8-2&keywords=18%22+ringlight
In this shot, I have it as the mainlight and a 30x60 softbox providing rear illumination.
http://sphotos-b.xx.fbcdn.net/hphotos-ash4/313703_10151404650321418_619303477_n.jpg
Feb 08, 2013 at 03:43 PM
jzucker
p.1 #14 · Ringlight to Compliment Einsteins
does anyone know what kind of output you get out of the LED ringlight?
Feb 08, 2013 at 03:44 PM
