Archive 2013 · Softbox mounting ring help.
gilead
p.1 #1 · Softbox mounting ring help.
I just purchased an Aurora UNI-LEVER PRO U-600 STUDIO FLASH and would like to pick up a soft box to use with it.
Been searching for the last few days for info regarding softboxes and Mounting rings but still can wrap my brain around it. Do I need a specific ring for the flash ? Anyone know of any compatible rings for this combo?
Appreciate any help and guidance.
Jan 24, 2013 at 12:01 AM
Wobble
p.1 #2 · Softbox mounting ring help.
Is this similar to your needs: Aurora Mini / Max Z-Bracket for Shoe Mounted Flashes
Adorama Link
Jan 24, 2013 at 01:04 AM
SweetMk
p.1 #3 · Softbox mounting ring help.
I am not familiar with your equipment, but, many times a little creativity goes a long way.
The link below details what I did to mount to a soft box, maybe for $9 you can do something similar?
http://www.sweetmk.com/2012/12/diy-how-to-mount-speedlight-to-a-softbox/
Jan 24, 2013 at 09:26 AM
cgardner
p.1 #4 · Softbox mounting ring help.
It would be helpful if you photograph and post a shot of the front of your light showing the attachment mechanism the ring will attach to and the base of the standard reflector. Also look on the maker's web site for information if you haven't already.
The back part of the speedring for a studio light will usually look similar to the base of the standard metal reflector and attach the same way. If the reflector clips on using spring-loaded fingers (Buff / Balcar) the back of the speedring will be similar. If the reflector attaches via twisting and locking the speedring with have a similar twist-lock base.
The ring linked above is designed for speedlights with don't have attachment points for modifiers.
Jan 24, 2013 at 01:08 PM
henryp
p.1 #5 · Softbox mounting ring help.
Westcott Apollo softboxes attach like umbrellas and do not require a speedring. They're here.
Henry Posner
[email protected]
B&H Photo-Video
Jan 24, 2013 at 02:56 PM
cmyb
p.1 #6 · Softbox mounting ring help.
You may need something like this.
http://www.henrys.com/60589-AURORA-SRUN-UNI-LEVER-TYPE-ADAPTER-RING.aspx
Jan 24, 2013 at 03:37 PM
gilead
p.1 #7 · Softbox mounting ring help.
Really appreciate all the info, thanks a bunch.
Jan 25, 2013 at 08:08 AM
