Tethered shooting USB cable support
Mike Mahoney
p.1 #1 · Tethered shooting USB cable support
Anyone know of a device to secure the camera end of the USB cable? .. I seem to recall a product that screws into the tripod mount and then attaches to the base of the cable and secures it to the camera.
Dec 19, 2012 at 11:32 PM
sjms
p.1 #2 · Tethered shooting USB cable support
depending on your mounting method there is a lot you can do with Velcro.
Dec 20, 2012 at 12:29 AM
Roland W
p.1 #3 · Tethered shooting USB cable support
Really Right Stuff sells an accessory that works with an L bracket to secure cables in the camera side ports. It is a little expensive, but likely works well. Check it out here: http://reallyrightstuff.com/ProductDesc.aspx?code=CRS&type=0&eq=&desc=CRS%3a-Cable-Relief-Spacer&key=it
Another thing to look in to is to order a right angle USB cable, that allows the USB cable to turn 90 degrees right at the camera connector. They are available to turn either "up" or "down" so be sure to order what you want. A "down" one would not easily be pulled out for normal camera orientation. And remember if you want to use another cable next to a right angle USB cable, you could be out of luck depending on the particular combination of things, so keep that in mind when selecting a cable.
Dec 20, 2012 at 03:32 AM
andyz
p.1 #4 · Tethered shooting USB cable support
Not what you describe, but effective, Jerkstopper.
http://www.shop.tethertools.com/JerkStopper-Camera-Support-JS020.htm
They make some variations as well.
Dec 20, 2012 at 05:53 AM
BruceF99
p.1 #5 · Tethered shooting USB cable support
Check out the JerkStopper from http://www.tethertools.com/
Dec 20, 2012 at 05:54 AM
Mike Mahoney
p.1 #6 · Tethered shooting USB cable support
Thank you everyone .. looks like the Jerkstopper is it!
Dec 20, 2012 at 08:25 AM
sjms
p.1 #7 · Tethered shooting USB cable support
http://www.homedepot.com/h_d1/N-5yc1v/R-202261928/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=velcro&storeId=10051
US $3 for eight of them with a multitude of uses. $17 gets you a whole lot of them too vs a one trick pony sorta thing.
view2 for non L use. they can be double or more in length to just about wrap around anywhere you need.
velcro
view 1
view 2
Edited on Dec 30, 2012 at 11:37 AM · View previous versions
Dec 20, 2012 at 11:35 AM
Mike Mahoney
p.1 #8 · Tethered shooting USB cable support
Roland W wrote:
Another thing to look in to is to order a right angle USB cable, that allows the USB cable to turn 90 degrees right at the camera connector. .
I didn't know they made angled USB's .. worth checking into.
Dec 21, 2012 at 03:38 AM
Mike Mahoney
p.1 #9 · Tethered shooting USB cable support
Thanks!
Dec 21, 2012 at 03:40 AM
sjms
p.1 #10 · Tethered shooting USB cable support
http://www.amazon.ca/Startech-USB2HABM3RA-Cable-A-Right-3-Feet/dp/B004W8EIMW/ref=sr_1_fkmr0_1?ie=UTF8&qid=1356093137&sr=8-1-fkmr0
Dec 21, 2012 at 12:32 PM
