The octa is a great modifier, but I'd rather save $900 and get something like an 86" PLM instead. Now, I'm not saying a PLM is exactly the same, but a white one with the diffusion panel should provide the soft light you're looking for!
+1, I have PCB 60" sliver PLM with white diffuser, I love it.
I've had one and they are great. Really great, but I don't know if it's that much greater than the PLM. It's like buying a mola beauty dish. They're great, but are they that much greater than a regular one? It's a lot of extra cash for 5-10% better. Or maybe just 5-10% different.
A question I've wrestled with. I have an Octa and love it, but I also have a $99 Photek that I love. The light from both is wonderful and while the Octa has some light light modification features that the Photek lacks, there isn't much difference in the overall quality of light.
I have it and love it, it opens quickly and sets up in under 2 minutes. I also have Mola dishes, so i guess i'm one of those that - "pays for 5-10% difference in light".
Have it and love it, it's my go to modifier for most of my shots.
If I lack space, I usually switch to the 39" deep octa.
Light is great, diffused evenly, and it gets quickly set up. It can be a bit heavy for your stand and even heavier if it's windy, so you'll always need to have someone next to it unless you're shooting inside. I tend to put it high a lot so my assistant always holds the stand out of safety. It's an expensive modifier, after all.
The real question is the size of the light source and the distance from the subject. Then there is the matter of spill. A Softlighter is very inexpensive but is invaluable in its ability to deliver soft light to the subject while still being a very light weight modifier.
Do you want a round light or is a rectangle OK? Given similar sizes the quality of light will be the same. The next question is how deep will the modifier be? In a small studio a deep modifier will eat up valuable space. The downside is that a shallow box loses output due to the diffusion necessary to minimize hot spots.
Do you want the ability to attach grids? Very useful to minimize spill.
Many great photographers use Octas but just as many use PLMs, Softlighters, Umbrellas and sundry boxes and BDs.
I would rent an Octa before buying and also check out other modifiers via renting to see how similar they can be and how size and distance makes the real difference. This also goes for using BDs and small softboxes and Softlighters.
Experiment and judge honestly. The raves you see from a guy who just spent $1000 are not going to give you a real balanced view of the product.
I've used a soft lighter and it wasn't too bad, also picked up the 39" deep octa. Have a ton of rectangle boxes, I think I'll use what I have for now or maybe pick up a PLM
I bought the 60" Softlighter when I started my career, moved up to the Octa when I could and love the quality of light. I know that variety is good, so I also like the Profoto beauty dish as an alternative and a 4 bulb Kino Flo from time to time. I'd suggest renting a couple modifiers including the newer mid size Elinchrom boxes and see which one you prefer.
The Octa has a beautiful SOFT light. It's almost luminescent. I've started to take the front diffuser off and it really snaps up the image. It sets up in no time. I really like it!
NO, all the Elinchrom Octas have issues with the silver foil peeling off. My 74" is a little, but it's 10 years old and my 39" Octa(non DO) is the worst, but it is also 10 years old. My 39" Deep Octa is fine and seems to be made with a sturdier version of foil than the older ones were. I'm considering getting the replacement shell for my 74" since it's only $400+ compared to buying an entirely new one.
I've had peeling issues with the Octa but haven't seen any issues with the light it produces. It is disconcerting to spend that kind of money and see the peeling. My Deep Octa was the worst and got it replaced. Replacement has been fine.
I should have mentioned that even with the foil peeling the light quality is fine. My DO is only a few months old, so I'm not sure how it'll hold up. I wish they used the silver lining that Chimera uses though.
I have two Eli Octas, both have the same material and will de-laminate right away if stretched too hard (eg. apply excessive force when mounting it onto the speedring). Chimera softboxes don't have this issue.
The light from mine is still great but it looks like crap and it's getting worse. Somewhere I read a tip that you should pack it with the diffuser wrapped around the rods and speedring so that they don't scraped the inside. I've also altered the mount so that it's more robust. Mine is an older model and I think that they've updated the material. It's pretty discouraging if they're still having issues with a $1k light modifier.
