Opposites WA - If only....
GeorgieGirl
p.1 #1 · Opposites WA - If only....
I reviewed the rules and only photos taken during the assignment can be entered. My timing is way off...*sigh*.
Nov 07, 2012 at 12:06 AM
sbeme
p.1 #2 · Opposites WA - If only....
Welcome to FM.
Very interesting image. I am not sure it clearly says "Opposites" and its a complex image, but certainly a keeper, WA or no.
I would simplify this somewhat disorienting image (part of its strength) by cropping from the top. I am torn between a crop at the bottom of exterior wall/ceiling and taking off a bit more to crop to eliminate the thin panes of glass at the top. I suspect the second is a more powerful version.
Then I have the disorienting sense of looking at a vivid large screen TV where the bright daylight colors of the rocks come through.
Where is this BTW?
Scott
Nov 07, 2012 at 12:49 AM
GeorgieGirl
p.1 #3 · Opposites WA - If only....
Scott -
This is from the inside of an enclosure that is the structure that makes up an indoor/outdoor pool that can be a solarium pool all year round or an outdoor pool portion, seasonally.
The 'opposites' I saw were the reflections in the pool of the building's inverse structures for a top and bottom Opposite. The Opposite tinted window panes on the left and right with the 'clear' view straight through with the glass wide open. The tiled decks mid-stream Opposite one another mid frame. The hand-rails and hand-rails, the fence and fence, and the shrub and the shrub in the landscape beyond.
Many Opposites.
Thanks for your comments!
I will contemplate your crop suggestions and see what can be bettered by a clean up.
Nov 07, 2012 at 01:35 AM
