  Pre-order Rokinon 16mm f/2 ED AS UMC
Centre column: Geared or Rapid? (Series 3)
S Dilworth
p.1 #1 · Centre column: Geared or Rapid? (Series 3)
On behalf of epphoto, but also because I have the same question, I’d like to solicit your advice on a centre column for a Gitzo Systematic Series 3 tripod, specifically the GT3531S.
I don’t know what epphoto wants it for, but I’d like to use it for fairly precise height adjustment in a makeshift studio environment.
Upon the centre column will be:
• a Manfrotto 410 Junior Geared Head (owners will know there’s nothing junior about it! It looks and feels like something you’d connect to a John Deere’s PTO shaft)
• a Hejnar Photo adaptor providing an Arca-Swiss-style clamp for the Manfrotto head
• a macro focusing rail of some sort, possibly a Novoflex Castel-XQ II
• an SLR and lens, sometimes of combined weight over 2 kg
I mention the above because I’ve noticed geared centre columns are sometimes recommended for heavy cameras. Does the above constitute ‘heavy’?
Roger Hicks, in his wide-ranging and highly readable Tripods e-book, recommends geared columns for convenience only for cameras over 5 kg. Any dissenting opinions? (In any case, my setup will be close to 5 kg.)
My questions are numerous:
1. Is a geared column strictly necessary for height adjustment with 1–2 mm precision? With my GT1541T and a light load, I find that by ‘rolling’ one thumb against the nail of another thumb placed as a clamp on the centre column, I can adjust the Rapid-style column with high precision, at the risk of the occasional nip. But I’m not sure how this technique would transfer to a larger and heavier setup (other than more nips, I’m sure!).
2. Do Gitzo’s Geared (or Rapid, for that matter) columns have distance scales on them?
3. Is a Gitzo Geared column as stable as a Rapid column, when locked down?
4. How much backlash is there in the gearbox of a Gitzo Geared column?
5. Are there any compatibility gotchas to worry about, or will any Series 3 centre column work with my 2008-era GT3531S?
Any other comments are more than welcome.
Oct 22, 2012 at 11:05 AM
S Dilworth
p.1 #2 · Centre column: Geared or Rapid? (Series 3)
Looking at this post again, I’m not surprised no-one’s answered. The question is longwinded and basically impenetrable, besides dealing with an obscure topic.
To get to the point, though, has anyone got a Geared or Rapid column on a Gitzo? Do you like it or wish you’d got an alternative?
Cheers!
Oct 23, 2012 at 11:05 PM
vsg28
p.1 #3 · Centre column: Geared or Rapid? (Series 3)
I am just not sure many Gitzo series 3 owners even bother with a center column, frankly. I am quite happy with the rapid column on my Induro if that's of any help.
Oct 23, 2012 at 11:33 PM
runamuck
p.1 #4 · Centre column: Geared or Rapid? (Series 3)
I had a geared column. I called it hemorrhoid because it was a pain in the azz.
A plain column is better because movement is much easier. Now I have a tripod with no column and don't miss it one little bit. Doing away with the column removes one more point where movement can occur.
After I reread your question a couple of times, I think you are asking the equivalent of whether your car's transmission should have 6 or 8 speeds.
Oct 25, 2012 at 10:41 PM
sjms
p.1 #5 · Centre column: Geared or Rapid? (Series 3)
Rapid if you choose to need/have one.
Ans:
1- on my larger tripod i don't even use a CP. it is either a leveling platform or a std flat platform
2- geared columns are primarily a preference they are not real precision devices
3- i do not believe so. what would your 0 reference be on uneven ground and varied leg adjustments?
4- the crank assy is a simple rack and pinion gear assy. not real precise all together. but since you are vertical the weight is from above so backlash is essentially nonexistant as there is load on it from above at any given time unless it is locked.
5- the new 2012 models were redesigned, improved against platform seperation/failure and optimized so they would not accept the RRS leveling head which was designed to fit both RRS TVC-33 and the 2011 and earlier systematic Gitzo legs. they don't like to play well with others. they're special
as was mentioned not too many use a geared CP due to its additional weight/bulk and the rapid has worked out just fine.
Edited on Oct 29, 2012 at 01:15 PM · View previous versions
Oct 25, 2012 at 11:40 PM
EB-1
p.1 #6 · Centre column: Geared or Rapid? (Series 3)
I would use a rapid column, unless you have a very heavy load that really should be on a beefier legset anyway.
I did not realize that Gitzo had destroyed the compatibility of the 2012+ "systematic" models. Boneheads. When/if my 3530LS is ever damaged or goes MIA I'd get a RRS. The Gitzo leveling base is a heavy beast compared to the RRS.
Oct 26, 2012 at 12:52 AM
sjms
p.1 #7 · Centre column: Geared or Rapid? (Series 3)
they did it before to their cousins (manfrotto) too
Oct 26, 2012 at 10:50 PM
S Dilworth
p.1 #8 · Centre column: Geared or Rapid? (Series 3)
Thanks very much, all. I think I’ll go for a Rapid column.
Oct 29, 2012 at 12:56 PM
