p.1 #1 · Samyang to show a 10mm f/2.8 prototype at Photokina
The Samyang 10mm 1:2.8 ED AS UMC CS is a prototype of the ultra wide-angle prime lens designed for use with cameras fitted with APS-C/DX sensors. Its extremely short focus length and rectilinear imaging system ensure extra wide angle of view amounting to 110 degrees (~107 degree for Canon version).
As a result the lens is a comprehensive tool for architecture and landscape shooting. New Samyang 10mm 1:2.8 ED AS UMC CS is similar to the 35mm system lens with 15mm or 16mm focal length in the case of Canon APS-C cameras.
All details concerning the optical construction of the lens and available mounts will be published at a later date. The lens will be introduced for sale either at the end of 2012 or in the first days of 2013.
p.1 #3 · Samyang to show a 10mm f/2.8 prototype at Photokina
I hope Samyang develops some type of 12mm rectilinear lens for FF one day... If Sigma can reach that in a zoom lens, I think somebody can do it with a prime! It does not need to be f/2.8 either. I would just love a 12mm rectilinear
p.1 #8 · Samyang to show a 10mm f/2.8 prototype at Photokina
Wahoowa wrote:
The rear element doesn't look intruding. So, might this be useable on a full frame camera? I'm not saying it's a good idea, but probably useable.
It's only canon with the EFs that have the intruding rear element (and even then some EFs won't foul the mirror at slightly less than full wide) . That's why with Nikon for instance you can mount a DX lens on aFX body.
All the 3rd party APS-c lenses are EF and will mount to a FF without issue . They would normally design the lens around the 1.5 crop of the Nikon/Pentax systems . And then change the mount/register distance for canon
. That's not to say that they ALL can fill the image circle though. If this 10mm is designed for crop sensors then you can bet it won't fill the image circle . Otherwise I'm sure samyang would have gone for FF compatibility.
