Archive 2012 · Removing ball head from tripod
Tri Tran
p.1 #1 · Removing ball head from tripod
Hi guys, I am having trouble removing Kirk BH-3 from my Gitzo GT2540. It is extremely tight. Help please.
Thanks
Feb 14, 2012 at 01:57 AM
trenchmonkey
p.1 #2 · Removing ball head from tripod
Make sure to loosen any hex head locking screws on the underside (if present)
I'll use a washcloth (don't tell wife) and channel locks for stubborn heads etc.
Haven't marred a finish yet....strap wrench may be the preferred choice, if worried. GL
Feb 14, 2012 at 07:08 AM
jhg photo
p.1 #3 · Removing ball head from tripod
Hard screws and bolts become easy to turn if you drop some pure alcohol into the gap. The alcohol easily flows into tight gaps and works like a grease for a short time.
Maybe you drop some alcohol into the gap between tripod and ball head base and try to unlock after ten seconds.
Good luck
Feb 14, 2012 at 07:19 AM
jhg photo
p.1 #4 · Removing ball head from tripod
Good luck
Glenn NK
p.1 #5 · Removing ball head from tripod
Good luck
But be sure the alcohol is potable - then if all this fails, you can drink it.
G
Feb 14, 2012 at 02:53 PM
EB-1
p.1 #6 · Removing ball head from tripod
Does the 2540 have the grub screw?
Feb 14, 2012 at 08:18 PM
Tri Tran
p.1 #7 · Removing ball head from tripod
I have no idea, since it's stuck.
Alcohol tricked didn't work
Feb 14, 2012 at 09:27 PM
peter_n
p.1 #8 · Removing ball head from tripod
The screws they're talking about are on the underside of the base the ballhead is screwed into. There can be 0 to three of them depending on brand. Actually it's not a particularly good idea to use them as they can warp the ballhead's base and make panning more difficult.
If you've determined that there or no screws or or the one or more screws there are loose, get yourself a small strap wrench and use it with a jerking motion on the panning base of the ballhead.
Feb 15, 2012 at 10:10 AM
bipock
p.1 #9 · Removing ball head from tripod
Not truly familiar with the 2540, but I know my Gitzo has no center column and a hook for hanging things on the underside of the plate. I have found, when changing heads, that this hook has to be loosened a little for the head to come off.
If all else fails, squirt some WD-40 between the plate and head, give it a couple minutes to move through, flip the tripod upside down for a second so the fluid runs onto the mounting screw and give it a go.
Feb 15, 2012 at 10:25 AM
surf monkey
p.1 #10 · Removing ball head from tripod
This not about lubricating the connection, just force.
Tighten the panning knob as much as possible.
Twist the head on the vertical axis.
Try untightening with a lot of upward pulling.
Feb 16, 2012 at 12:22 PM
15Bit
p.1 #11 · Removing ball head from tripod
I'm surprised no-one has suggested heating it up with a hot air gun or hairdryer. Thermal expansion can work wonders on stuck threads.
Feb 16, 2012 at 12:50 PM
GJR1
p.1 #12 · Removing ball head from tripod
I just had this issue on a head that had Locktite applied. No tools I had would budge the head. I had to heat the bolt with a torch for a few moments after disassembling the head so I could access the bolt. After heating, the bolt just unscrewed. Careful with heat though, for all the obvious reasons.
Feb 16, 2012 at 02:31 PM
GroovyGeek
p.1 #13 · Removing ball head from tripod
Proposal to loosen the mounting screw from below is a good one. If that fails an oil filter wrench is your best friend, one with a rubber strap. Works much better than the washcloth deal
https://www.google.com/webhp?sourceid=chrome-instant&ix=sea&ie=UTF-8&ion=1#q=oil+filter+wrench&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=wOM9T9STEuqkiQLU5cDKAQ&ved=0CHkQrQQ&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.,cf.osb&fp=da76f2281a5bc585&ix=sea&ion=1&biw=1380&bih=739
Feb 17, 2012 at 12:21 AM
Zichar
p.1 #14 · Removing ball head from tripod
Strap wrench in a pinch:
http://www.clubsnap.com/forums/general-tech-talk/678310-remove-stucked-uv-filter-lens-2.html#post6013838
Saved my hide a few times on the road
Feb 17, 2012 at 04:14 AM
jstephens62
p.1 #15 · Removing ball head from tripod
Try penetrating oil, and unscrew with a quick jerk. A few taps with a rubber mallet may also help.
Feb 17, 2012 at 04:21 PM
runamuck
p.1 #16 · Removing ball head from tripod
If all else fails, opposed 48 inch pipe wrenches will loosen just about anything.
Feb 17, 2012 at 08:01 PM
