Archive 2012 · Dread portal
MattWeth
p.1 #1 · Dread portal
Chance encounter with a good looking bridge when I was far too early for a meeting.
C&C very welcome as ever.
Jan 26, 2012 at 10:47 AM
T-bone1
p.1 #2 · Dread portal
Sweet shot.
Would look cool, too, as a setting for shooting some portraits. A lot of possibilities here.
-Tim
Jan 26, 2012 at 04:25 PM
MattWeth
p.1 #3 · Dread portal
Thanks Tim,
You're right - it has great possibilities as a setting for working with models. The only problem would be finding a quiet time! The shot above was taken at about 7:15am just as the sun was rising - even then there was a steady trickle of people walking to their offices. Later in the day, it gets very busy
Jan 26, 2012 at 05:20 PM
sbeme
p.1 #4 · Dread portal
Most very cool!
Nice perspective, careful work with symmetry.
I think it needs some sharpening. I'd be aggressive on masked (edge) sharpening.
Where is this and what it the name of the bridge?
EXIF?
Scott
Jan 26, 2012 at 05:23 PM
MattWeth
p.1 #5 · Dread portal
Thanks Scott,
Good point about the sharpening - I have a tendency to overcook sharpening sometimes so I sometimes err on the side of caution - I'll do some work on it.
The shot was taken at Salford Quays in NW England, UK - a redeveloped industrial dockland area which now has swanky apartments, offices and a theatre:
http://maps.google.co.uk/maps?q=salford+quays&hl=en&ll=53.46981,-2.289877&spn=0.048229,0.111666&sll=53.39706,-2.560411&sspn=0.012078,0.027916&hq=salford+quays&radius=15000&t=m&z=14
I'm not sure of the bridge's name - it's a lift bridge that jacks itself up on four pylons to let ships pass underneath. There are a couple more shots of it in my flickr.
With regards to the EXIF, I guess I should own up and admit that it was just taken with my compact (always with me, unlike my 5D) - a Panasonic DMC-LX3. It's got a good, fast, Leica lens and shoots raw - punches well above its weight. For what it's worth, the basic exif is below
ExifTool Version Number : 7.32
File Name : P1020328-2.jpg
Directory : **********
File Size : 3 MB
File Modification Date/Time : 2012:01:26 09:10:02
File Type : JPEG
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Make : Panasonic
Camera Model Name : DMC-LX3
X Resolution : 240
Y Resolution : 240
Resolution Unit : inches
Software : Adobe Photoshop Lightroom 3.6 (Windows)
Artist : Matt Wetherill
Copyright : Matt Wetherill
Exposure Time : 1/10
F Number : 2.0
Exposure Program : Program AE
ISO : 200
Exif Version : 0230
Date/Time Original : 2012:01:25 07:47:30
Shutter Speed Value : 1/10
Aperture Value : 2.0
Exposure Compensation : 0
Max Aperture Value : 2.0
Metering Mode : Multi-segment
Flash : Off
Focal Length : 5.1 mm
File Source : Digital Camera
Compression : JPEG (old-style)
Thumbnail Offset : 648
Thumbnail Length : 11088
Displayed Units X : inches
Displayed Units Y : inches
Coded Character Set : UTF8
Application Record Version : 4
Keywords : copyright matt wetherill
Time Created : 07:47:30
Digital Creation Date : 2012:01:25
Digital Creation Time : 07:47:30
By-line : Matt Wetherill
Light Value : 4.3
Edited on Jan 26, 2012 at 06:01 PM · View previous versions
Jan 26, 2012 at 05:40 PM
sbeme
p.1 #6 · Dread portal
Thanks.
Nice to have a compact camera. Cant take a picture without a camera, so more opportunities this way!
I guess my question is could you have bumped the ISO for a faster shutter speed and still get a clean enough shot? Not that an image like this cant tolerate some noise or added grain to cover some noise.
Scott
Jan 26, 2012 at 05:48 PM
MattWeth
p.1 #7 · Dread portal
Good points again Scott - I've got a couple of custom AE settings on the LX3 which pin the ISO to certain ranges. Looking at this shot, I had it on my 'up to 200' setting. If I'd thought more about it, I should have shot manual and set the ISO a little higher (it's fairly clean up to 800 but as you say, a little grain on this shot wouldn't necessarily be detrimental).
I was too focussed on grabbing a shot when the bridge was empty - should have put more thought into the exposure
Jan 26, 2012 at 05:58 PM
lazlo369
p.1 #8 · Dread portal
That is quite a shot of that bridge. makes you feel like you will be squashed together when you get to the middle.
Very good photography
Jan 26, 2012 at 07:42 PM
MattWeth
p.1 #9 · Dread portal
Thanks Lazlo
Jan 26, 2012 at 08:27 PM
Dougo
p.1 #10 · Dread portal
Great composition of the bridge, a lower angle could have been interesting as well. The dark sky works well with this. adds that drama.
Cheers Ray
Jan 26, 2012 at 11:55 PM
MrBaz
p.1 #11 · Dread portal
Perfect setting. The sky looks ominous, and that bridge has wonderful architecture.
Jan 27, 2012 at 12:47 AM
MattWeth
p.1 #12 · Dread portal
Thanks Guys.
Jan 27, 2012 at 08:37 AM
MattWeth
p.1 #13 · Dread portal
As suggested I've tweaked the sharpening and added a touch of NR to bring down some of the noise in the sky (the LX3 tends to blow the blue channel and before conversion, the sky in this shot had a very blue tinge to it).
cheers
Matt
Jan 27, 2012 at 09:31 AM
