Archive 2011 · Gitzo Series Codes and what is a 1320?
wifi
p.1 #1 · Gitzo Series Codes and what is a 1320?
I have an opportunity to pick up a used Gitzo 1320 tripod, and was searching for some more information on this model.
I have the following simple question: is this a Series 3 or Series 1 tripod? Using Gitzo's coding system (links below), this appear to be a 1 Series, but most every reference I found to it on the web indicates that it is a 3 Series (and it seems too large to be a 1 series). Is this due to it being a Mk2 version of the G320 model, and Gitzo used to use a 3 digit coding scheme?
http://www.gitzo.com/service/Product+Code+System/Product+Coding+System/13114572
http://www.ronmartblog.com/2011/05/gitzo-primerunderstanding-gitzo-system.html
Thanks for any insight.
Edited on Dec 05, 2011 at 10:20 PM · View previous versions
Dec 05, 2011 at 03:26 PM
gardenvalley
p.1 #2 · Gitzo Series Codes and what is a 1320?
That code is part of the old naming system but it is a 3-series aluminium. I used to have one but didn`t like it, no ALR, head mounting plate which was far too big, rubber caps on the spiked feet which were very difficult to remove, too big when collapsed and too heavy.
Dec 05, 2011 at 03:35 PM
wifi
p.1 #3 · Gitzo Series Codes and what is a 1320?
Thanks for the response. I did not realize that Gitzo had not yet introduced the anti-leg rotation feature at the time these were made (at least not on this model), so that will definitely be cumbersome.
So how does one decode the old numbering scheme?
Edited on Dec 10, 2011 at 08:28 PM · View previous versions
Dec 05, 2011 at 10:24 PM
runamuck
p.1 #4 · Gitzo Series Codes and what is a 1320?
Send a pm to Lars Johnsson. IIRC, he had the codes all figured out.
Dec 10, 2011 at 06:44 PM
