fredmiranda.com Login
This topic is in the 2010 archive. You can read it and like its posts here. It is read only.
Archive 2010Sony goes pellicle!
Tariq Gibran
p.1 #1Sony goes pellicle!
Interesting. I wonder if this will give them an advantage with video. Obviously, it does for FPS still shooting.
http://gizmodo.com/5615806/the-first-look-at-sonys-a33-and-a55-pellix-dslrs
Aug 18, 2010 at 09:17 AM
helimat
Details
p.1 #2Sony goes pellicle!
Hmmmmmmmmmmmmmmmmm......
Aug 18, 2010 at 09:45 AM
Empire
Details
p.1 #3Sony goes pellicle!
Takes me back to the EOS 1n RS
certainly an attractive idea
Aug 18, 2010 at 09:50 AM
Ed Sawyer
Details
p.1 #4Sony goes pellicle!
about time someone embraced this concept in the digital world. opens a lot of doors for alt lenses since mirror clearance is much less of an issue.
Aug 18, 2010 at 10:05 AM
helimat
Details
p.1 #5Sony goes pellicle!
What is the sensor size on these? Crop I am assuming?
Aug 18, 2010 at 10:09 AM
AhamB
Details
p.1 #6Sony goes pellicle!
Did you or anyone else here experience how much darker the viewfinder is in the EOS RT/RS camera's? There have been members here saying they'd prefer a fully silvered mirror that doesn't lose light to the AF-system, which I must say appeals to me more than a darker VF and sensor with half the light gathering ability.
Aug 18, 2010 at 10:17 AM
edwardkaraa
Details
p.1 #7Sony goes pellicle!
I think that must be the reason why it has an EVF.
Aug 18, 2010 at 10:22 AM
Tariq Gibran
Details
p.1 #8Sony goes pellicle!
If I remember correctly, the Canon RT had a silent mode. I really hope Sony has thought of this as it would really open up a few markets not available for traditional SLR's. I know I would use such a feature. Waist level shooting with a quite camera and the use of the full range of Sony/Minolta lens availability would be great.
Aug 18, 2010 at 10:37 AM
Bifurcator
Details
p.1 #9Sony goes pellicle!
Why is it a good idea? I've watched other optic design(er)s try as hard as they can to avoid pellicle mirrors in the light path.
    Wiki:
    A pellicle mirror (diminutive of "pellis" - skin or film) is a semi-transparent mirror employed in the light path of an optical instrument, splitting the light beam into two separate beams, both of reduced light intensity.
- Just wondering.... I know it's better than a glass beam splitter but why would they want reduced light intensity when I thought the whole idea of good noisless images depended on the opposite. (?)
Aug 18, 2010 at 10:46 AM
EOS20
Details
p.1 #10Sony goes pellicle!
Great to see the return of the pellicle!
I owned a EOS RT, you do loose a bit of light through the viewfinder and exposure time (I think it's 1/3 of a f stop) but it wasn't really a noticeable difference when shooting with the camera (the viewfinder was allot better then my 20D's viewfinder when I had the RT).
Aug 18, 2010 at 10:51 AM
curious80
Details
p.1 #11Sony goes pellicle!
Whenever you split a light beam into two, each of the two rays will necessarily have a reduced intensity regardless of the method used.
They need to feed one beam to the AF module and one to the sensor so that they can do phase-detect AF during movie mode and live view mode. They are willing to live with a little less light to the sensor to gain supposedly much superior autofocus during movies.
Honestly for movies the output should still be much cleaner than the typical camcorders with tiny sensors - specially considering the excellent high-iso performance of recent sony APS-C sensors. And there are some indications that you can move the pellicle mirror out of the way for still shots to gain back full sensitivity.
    Wiki:
Aug 18, 2010 at 11:04 AM
Ed Sawyer
Details
p.1 #12Sony goes pellicle!
the light loss is only 1/3 stop in the EOS versions of this. Not noticable and offset in those cases by a brighter screen. The pellicle concept has many advantages. It would be too bad if they crippled it with an EVF though.
Aug 18, 2010 at 11:20 AM
Tariq Gibran
Details
p.1 #13Sony goes pellicle!
Perhaps they will follow these mid range models with a FF 1080P professional version without EVF.
Aug 18, 2010 at 11:23 AM
Bifurcator
Details
p.1 #14Sony goes pellicle!
As a wise man once said,
Aug 18, 2010 at 11:31 AM
theSuede
Details
p.1 #15Sony goes pellicle!
The good:
You get TOTALLY AWESOME phase detection focus ability in "C"-mode (follow-focus)
You get zero shutterlag from mirror-actuation in good light
The bad:
You loose 1/3Ev of light (the same as going from 1/100s to 1/125s shutter)
You are limited to the use of an EVF, that stutters really badly when you're in burst-mode
All the good stuff goes away at higer ISO's, where the camera swings the mirror out of the way to maximize light to the sensor - OR you have to rely on contrast AF, as in all the other mirrorless cameras.
It isn't a fixed pellicle, the patent (and some information leaks) clearly say that the mirror is constructed just like a "normal mirror" - except for the lack of a sub-mirror assembly needed in a normal camera to reflect light downwards towards the AF-module. Here the mirror in it's entirety is there to reflect light to the AF module that's ABOVE the mirrorbox, where the pentaprism(pentamirror) used to be.
This is also the reason why they could make the camera lower and more compact - no bulky AF module has to sit beneath the mirror-box. The A33 and A55 are more like the old D40/D60 Nikon cameras (that I really liked!) in scale than the much larger contemporary siblings. Much smaller than the D90 and A550 - another reason for me to switch sides (even if I will hang on to the D90 and some Nikon lenses for a while...).
I wanted a set of cameras - one larger FF/FX, one really compact crop/DX, and one REALLY small mirrorless camera. And Sony seemed to be the company closest to that setup right now. I actually like the idea - this and the up-coming NEX7 is the reason I sold the D700 and bought an A850 Sony FF.
Aug 18, 2010 at 07:26 PM
phidong
Details
p.1 #16Sony goes pellicle!
Sony already has really good mirror clearance on their other bodies though, right?
Aug 18, 2010 at 07:48 PM
phidong
Details
p.1 #17Sony goes pellicle!
I'm assuming shooting at 10fps with the EVF will be near seizure inducing
Sonyalpharumors made a comparison of the a33 next to NEX
http://sonyalpharumors.com/wp-content/uploads/2010/08/a33_nex.jpg
it looks tiny very interested in seeing one in person now
http://ww2.sonyalpharumors.com/wp-content/uploads/2010/08/a33_a551.jpg
and next to a290
Edited on Aug 18, 2010 at 07:53 PM · View previous versions
Aug 18, 2010 at 07:49 PM
CKrueger
Details
p.1 #18Sony goes pellicle!
* No mirror sounds; the shutter is the only sound of operation, which can make the camera quieter.
* No vibration from mirror movement. I can shoot my M43 cameras at slower shutter speeds than my DSLRs... sometimes a nice benefit, especially with long lenses.
* No mirror blackout. High-end DSLRs aren't horrible, but imagine the view you get from a video camera; it's easier to track motion when the view isn't flickering.
* Full-time AF. Traditional DSLRs can't focus while the mirror is moving or up. Theoretically at least, full-time AF can be quite a bit better at tracking motion. (Although I'd still take Canon's DSLRs over Sony's pellicle... I'd love to see Canon's implementation in a 1D or 7D!)
* You can shoot video while using an TTL OVF. I can see this being hugely useful for videographers.
* Fewer moving parts to break.
* If Canon does it, they will FINALLY stop getting yelled at about not having a MLU button.
IIRC, the 1D implementation split light in a 66%/33% split. You lost a stop on film, and two stops in the eyepiece. To see what the effect is with your camera, stop your lens down two stops from wide open and press the DOF Preview button.
Personally, I'd happily give this up on a camera with a good viewfinder like the 1D/5D/7D; two stops is a lot of light, but not bad with fast lenses, and still usable with slow lenses. With smaller/darker viewfinders, however (40D/Rebels) I'd be much more hesitant. I suspect Sony will put quite a bright viewfinder in these cameras (even at a cost to profit) so this killer feature doesn't look awful.
Aug 18, 2010 at 07:52 PM
shogo73
Details
p.1 #19Sony goes pellicle!
Not sure about this. The NEX, GF1 and GH1 appear to have some delay in refreshing the images in EVF in consecutive shooting (hight frame rate). The EVF does not blackout like the canon in liveview after the first shot, but I don't think they can continuously track images like Canon 1N-RS or RT, or current canon mirror cameras.
Edit: how do I make the quote in yellow?
Aug 18, 2010 at 09:24 PM
theSuede
Details
p.1 #20Sony goes pellicle!
The "no blackout" viewfinder is not what the Sony cameras are after though - they HAVE no ordinary viewfinder, no pentamirror. It's EVF/LV all the way.
The only view you have of what's coming in through the lens is the main picture sensor output. The mirror is there to direct light to the AF-module, and NOTHING else. There isn't any smaller LV-sensor like in the "Fast LV" Sony cameras - so when the sensor is busy (a full picture readout takes 10x longer than a video frame readout!) you get total blackout.
Well, not "blackout" - In burst mode you're staring at a 10FPS stop-motion movie of what the camera captured, with at least a 120ms picture lag. Unfortunately this kind of negates the positive effects of the AF-C continuity, as it is hard to keep the AF-sensor points where you want them to be...
Regarding light-loss: 66% and 33% means that you loose one third of the light to the sensor. 1.00 > 0.667 is almost exactly -0.58Ev, and 1.00 > 0.33 is -1.59Ev. And according to the patent, the split is meant to be a bit more to the sensor, maybe like a 75/25 split. -0.41Ev to the sensor and -2Ev for the AF module - continuously. -2Ev is actually not that much worse than the AF-module has to make do with today, with the triple beam redirection.
Aug 18, 2010 at 09:41 PM
