fredmiranda.com Login
This topic is in the 2009 archive. You can read it and like its posts here. It is read only.
Archive 2009lens outresolving the sensor
ted snow
p.1 #1lens outresolving the sensor
morning,
can anyone tell me how this can be identified?
thanks.
Oct 07, 2009 at 01:15 AM
philber
Details
p.1 #2lens outresolving the sensor
Are you sure it is not the reverse which you are trying to identify? Because, if the lens outresolves the sensor, all is well, the picture will display the maximum quality the camera is capable of. Which sounds normal, on the face of it. Or am I missing something?
Oct 07, 2009 at 01:18 AM
ted snow
Details
p.1 #3lens outresolving the sensor
yes,it could well be the reverse.
my question isn't linked to a particular problem with any picture I've taken;It's just that I've heard this said a few times on this and other forums and wondered what was meant.
Oct 07, 2009 at 01:24 AM
philber
Details
p.1 #4lens outresolving the sensor
Then it is likely the reverse. The availability of very-high-density-sensor cams, such as the Canon 5D MkII and 7D, or the Sony A900 and A850 places increased requirements on lens resolution. More and smaller pixels show lens shortcomings to a greater degree than before. That is what is meant by the sensor out-resolving the lens, and the matter under discussion IMHO, Ted.
Oct 07, 2009 at 01:57 AM
AhamB
Details
p.1 #5lens outresolving the sensor
Maybe Ted was reading a lens review (such as photozone.de) where the measured resolution was (easily) reaching the theoretical resolution limit of the sensor, which likely implies that the lens is capable of resolving smaller details than than the sensor can capture ("it's outresolving the sensor").
Oct 07, 2009 at 02:06 AM
olyacme
Details
p.1 #6lens outresolving the sensor
An at-a-glance method is the appearance of moiré (and its ilk). If it's there (shoot a torture target), then the lens is outresolving the sensor to some degree. If it's never there then the camera might have a very strong AA filter.
Note that ability to produce moiré doesn't automatically mean it's a great lens. A whole host of aberrations could be present which are damaging to the image on wider scales, but don't eat up all the microcontrast. The classic example would be trading SA for CA.
Oct 07, 2009 at 03:58 AM
ted snow
Details
p.1 #7lens outresolving the sensor
thnk you all for your responses
Oct 14, 2009 at 01:14 AM
patrickphoto
Details
p.1 #8lens outresolving the sensor
you are referring to the Nyquist Frequency?
Oct 14, 2009 at 01:22 AM
hubsand
Details
p.1 #9lens outresolving the sensor
Most decent primes resolve the sensor in the very centre of the image circle. A tell tale of the sensor outresolving the lens is deteriorating sharpness across the frame.
Oct 14, 2009 at 03:15 AM
FM ForumsLeica & Alternative GearJoin Upload & Sell
