Gbee,
The second full length image is front focused by a long way - see the floor detail. Do you have another Canon camera body, any model, that you are happy with, to test the MKIII against? Also do you have a lens with a tripod mount on the lens for example 70-200mm F2.8 or super telephoto lens?
If so tripod mount the lens with your known good camera body and AF, one shot, single AF (no Af expansion), on parallel target (planty of detail across the frame - magazine text will do), Very carefully remove the camera. Slide the AF lens selector (on the lens barrel) to manual.
Very carefully attach the MKIII, using the AF back button, central AF sensor (no AF expansion), in one shot, does the MKIII's green Af confirmation light glow - if your first camera body is accurate it should do? If the AF confirmation light does not come on, or flickers, then there is a good chance that the MKIII is out of calibration. Does the image look as sharp as the first camera. Now turn the lens AF selector back to AF and activate the MKIII's AF system, does the AF shift and does the image snap into focus.
Repeat the test but this this time look at the lens barrel focus scale to see which direction the Af moves towards to see if it is front or rear focusing. If I suspect an AF problem I use this test and it has always born out my findings when the technicians adjust the camera and report back. It also helps them pin point the error if you can say with confidence that your camera is front or rear focusing.
