fredmiranda.com Login
This topic is in the 2005 archive. You can read it and like its posts here. It is read only.
Archive 2005Zuiko Test: 21/3.5
Mike Hatam
p.1 #1Zuiko Test: 21/3.5
Olympus Zuiko 21mm f3.5
Here's my next Zuiko test report - the Oly Zuiko 21/3.5.
A few notes about the Zuiko 21/3.5:
The lens is extremely small and light. It is about one-thrid the length of the Zeiss 21, and about one-fifth the weight. You have to hold one of these in your hands to realize how incredibly small and light it is.
The lens has a "FOV button", but the adapter essentially holds it in the "stop-down" position, so it's less useful on the Canon body (using a cameraquest adapter). So you use the apeture ring to open up the lens, focus, and then stop back down.
The lens requires an adapter to be used with EOS bodies. I used the cameraquest adapter for my testing. It's an exceptional adapter, and the lens easily slides in-and-out of the adapter, so you can use a single adapter for multiple lenses.
OK, enough about the lens, now let's talk about the testing...
Testing Methodology
In order to accurately test these lenses, Jack and I spent three months acquiring as many copies as possible Overall, we ended up testing 12 copies of this lens, and I currently have 6 in my posession.
Next, we needed competition for this lens. We choose the "king" - the Zeiss 21/2.8 (we only had one copy, but it's an excellent copy), and Guy Mancuso's famous copy of the Sigma 20/1.8. Some of you will remember about 5 months ago Guy posted comparisions between his Sigma 20/1.8 and his Zeiss 21, and the Sigma was amazing. It fell slightly short, but really held it's own.
All shots were taken on my 1DsII at f8, tripod mounted, mirror lock-up, and timed release. All focusing was manually performed (except the Sigma 20, which was auto-focused) using an Angle-C finder. Multiple shots were taken of each image (re-focusing between each shot), and the best shot was used in the comparison. Basic processing was performed in RSE - white-balance and exposure were normalized, sharpening was set to 0, and "extract detail" was set to 20.
Notes about the test images:
The top image shows the whole scene. Then you will see 3 100% crops. Top-left is the Sigma 20/1.8, top right is the Zuiko 21/3.5, and bottom center is the Zeiss 21.
http://www.thehatams.com/Images/21mm-Test1.jpg
Commentary:
This is perhaps the sharpest copy of the Sigma on the planet, so for the Zuiko to beat it is quite a feat. And it does beat it.
Here's how I assess the various attributes:
Sharpness: The Zeiss is best, followed very closely by the Zuiko, and then a big drop-off to the famous Sigma.
CA: The Zeiss is best, followed closely by the Zuiko, and then the Sigma.
Distortion: The Zuiko wins here - it has significantly less distortion than the Size. The Sigma trails behind both.
Light fall-off: The Zeiss wins this one. The Zuiko has noticable light fall-off. The Sigma has the most fall-off.
So there are trades between the lenses. The Zeiss is the sharpest (by a narrow margin), has more distortion, and less light fall-off. The Zuiko is very close in sharpness, has slightly more CA, much less distortion, and more light fall-off.
Since light fall-off is easier to correct in photoshop than distortion, the trades that the Zuiko offers are very attractive.
Bottom line - the Zeiss is still the best, but the Zuiko is an incredible performer, especially when you consider cost, size and weight.
When we began acquiring the Zuiko 21/3.5, based on Jack's speculation that it might be a good performer on the Canon sensor, I was very skeptical. The Zeiss is such an awesome lens - how could anything so small and cheap come close? Well, I'm now convinced. The Zuiko is simply a tremendous performer in a tiny package - it will go everywhere with me.
Jun 16, 2005 at 09:51 AM
Mike Hatam
Details
p.1 #2Zuiko Test: 21/3.5
Here is another test...
http://www.thehatams.com/Images/21mm-Test2.jpg
Edited by Mike Hatam on Jun 16, 2005 at 07:52 AM GMT
stevei
Details
p.1 #3Zuiko Test: 21/3.5
Great work Mike! How much sample variation did you see in the 12 Zuiko copies?
Jun 16, 2005 at 09:59 AM
Mike Hatam
Details
p.1 #4Zuiko Test: 21/3.5
Thanks Steve - this is a surprising amount of work to get reliable/repeatable test results. Everything has to be done perfectly, and if there's any issues, I throw out the whole batch and start over.
There is some sample variation in the Zuiko 21/3.5 lenses, but not too much. Even the worst we tested was still able to beat Guy's famous Sigma 20.
Jun 16, 2005 at 10:01 AM
sapro
Details
p.1 #5Zuiko Test: 21/3.5
Mike, thanks for this great test! Have you compared the flare between Zuiko and Zeiss? Zeiss is known to be very sensitive to flare.
Jun 16, 2005 at 10:06 AM
glowrider
Details
p.1 #6Zuiko Test: 21/3.5
known? I will fully attest that the cz is sensitive to flare
Jun 16, 2005 at 10:07 AM
Mike Hatam
Details
p.1 #7Zuiko Test: 21/3.5
Thanks Sapro. No, I have not tested for flare. Jack and I still have much more testing to do, but I wanted to start getting our current findings out there, since so many people have been asking about the Zuikos.
Jun 16, 2005 at 10:09 AM
sapro
Details
p.1 #8Zuiko Test: 21/3.5
Jun 16, 2005 at 10:10 AM
Mike Hatam
Details
p.1 #9Zuiko Test: 21/3.5
I should add one more thing. The Zuiko 21/3.5 that I used in the comparison above is not even necessarily my best copy. I just grabbed one from my collection. Out of the six I have in my collection, the top 5 are all essentially equal.
Jun 16, 2005 at 10:12 AM
Lars Johnsson
Details
p.1 #10Zuiko Test: 21/3.5
If that's the sharpest Sigma on the planet, you need to focus better with it Mike.
Jun 16, 2005 at 10:14 AM
mark1958
Details
p.1 #11Zuiko Test: 21/3.5
HI Mike.. Great tests. I have been doing some shooting with the Olympus 21mm as well and I totally agree with your results. I was amazed at how well the corners did relative to the CZ 21mm. The weight and size of the lens are unbeatable. mark
Jun 16, 2005 at 10:19 AM
Mr Joe
Details
p.1 #12Zuiko Test: 21/3.5
Mike - you better get a Geiger counter with all those "rare earth elements" around the house.
Thanks so much for doing these tests, it's good to know there is a viable alternative to the CZ 21mm.
I wonder how the Zuiko 21mm f/2 compares? Too bad they're up to around $1400 on eBay lately. Argh.
Jun 16, 2005 at 10:25 AM
Lars Johnsson
Details
p.1 #13Zuiko Test: 21/3.5
Mike, are you serious when you say the sharpest copy of the Sigma on the planet. When I look at the first photo stopped down to f/8 with it, nothing is in focus ! I suppose the box should be in focus or?
Jun 16, 2005 at 10:26 AM
Roger_Salmon
Details
p.1 #14Zuiko Test: 21/3.5
Mike
Great work. As a former OM1/OM2 user, this lens was on the camera 90% of the time. Now I know why!! I'll have to get the adaptor now.
Roger
Mike Hatam
Details
p.1 #15Zuiko Test: 21/3.5
Lars - the Sigma is an auto-focus lens, so I did not mis-focus I took about 6 images with the Sigma, refocusing after each one, and that's the best image. Focus point was on the tree directly in the center (near the water's edge).
Jun 16, 2005 at 10:29 AM
Mike Hatam
Details
p.1 #16Zuiko Test: 21/3.5
Lars - are you talking about the "whole scene" on the first test image? That was one of "throw-away" images, but I just used it to show the whole scene.
Focus is not off on the actual test images. You are seeing the real deal.
Jun 16, 2005 at 10:32 AM
glowrider
Details
p.1 #17Zuiko Test: 21/3.5
i've heard of AF having mucho problems focusing exactly where we want it...in fact, that's half the reason I use manual focus lenses anyway...
Jun 16, 2005 at 10:34 AM
Lars Johnsson
Details
p.1 #18Zuiko Test: 21/3.5
A normal Sigma 20 will do better than this at f/8. And you say this copy is best on the planet. I would call that copy a lot below normal standard.
Jun 16, 2005 at 10:35 AM
Mike Hatam
Details
p.1 #19Zuiko Test: 21/3.5
Lars - maybe I am wrong, and this copy of the Sigma is a POS.
Here's a challenge for you... get a 1DsII, and shoot a similar subject (can of Quaker Oats) from a distance of about 30 feet, with the subject at the extreme edge of the frame. Process with zero sharpening, and post a 100% crop.
I think you are in for a surprise.
Jun 16, 2005 at 10:37 AM
Lars Johnsson
Details
p.1 #20Zuiko Test: 21/3.5
Actually I did it about 3 months ago. Well not the quaker box and 30 feet. But aThai friend sold his 1DmkII and bought the 1Ds II instead
Jun 16, 2005 at 10:42 AM
