p.1 #1Need Laptop Recommendation for Photo Processing
My current 14-inch MacBook Pro (M1 Pro) just died, so I'm in the market for a replacement. This time, I'm leaning toward a 15-inch MacBook Air. I use Lightroom Classic for all of my photo editing work, so performance is an important consideration.
With laptop prices being what they are these days, I'm planning to buy from Apple's refurbished store. In my experience, Apple's refurbished products are virtually indistinguishable from new.
Given a budget of around $2,000, which model (Air or Pro) would you recommend?
p.1 #2Need Laptop Recommendation for Photo Processing
My main machine is a Studio, portable is a 14" Pro -- I upgraded both about 18 months ago to M4's at the time. Anyway, at that time I stuck with the 14" Pro when I last upgraded mainly due to the extra connectivity and balance between 13" Air and 14" Pro display for portability and chose the Pro. End of day, I haven't really ever needed more than 2@ TB ports at the same time, so looking at it now the 15" Air could make a lot of sense. OTOH, I haven't minded the thickness or weight of my Pro and the performance has been great, so there is that too. I haven't compared battery life or build-out specs between the current Pro and Air, but assuming the Air specs can suit your needs, I think it's hard to go wrong. Actually I think it's hard to go wrong with an Air or Pro depending.
My only however, is if the laptop is your only machine, I'd probably suggest opting for the more robust and connectable Pro body...
p.1 #3Need Laptop Recommendation for Photo Processing
Do you use AI tools during editing, such as AI noise reduction and do you edit for hours at a time? If so, you are probably better off with a pro body for better thermal management, and even better if you can get a pro chip for the extra GPU cores.
As a side note, while the screen and speakers on the Air are nice, the ones on the Pros are better. So you might find it a bit of a downgrade from your current laptop. Also, from a performance perspective, it really depends on the exact model chip you're looking to get. Overall, all the Air is meant for portability and battery life, while the Pro model and chip you currently have are meant for performance. So for example, going from an m1 pro to a m4 in an Air might not gain you much on the performance side.
p.1 #8Need Laptop Recommendation for Photo Processing
There’s a general forum and a post-processing forum that might be more appropriate for this post… and where you might get advice from a range of users who don’t shoot Sony. :-)
p.1 #9Need Laptop Recommendation for Photo Processing
gdanmitchell wrote: ramesesthe2nd wroteMy current 14-inch MacBook Pro (M1 Pro) just died, so I'm in the market for a replacement. This time, I'm leaning toward a 15-inch MacBook Air. I use Lightroom Classic for all of my photo editing work, so performance is an important consideration.
Given a budget of around $2,000, which model (Air or Pro) would you recommend?There’s a general forum and a post-processing forum that might be more appropriate for this post… and where you might get advice from a range of users who don’t shoot Sony. :-)
Yeah. Sorry about that. I don't see a way to move this now.
Apple's site is really designed to make you spend more. I have a work Macbook Pro 16 M4 Pro with 24 GB RAM and I find it too big and bulk to carry around so I was really thinking about getting AIR but everyone seems to think Pro is better, so I am not so sure anymore.
p.1 #13Need Laptop Recommendation for Photo Processing
I've got an M1 - 16". How did you kill yours? Not repairable? Also, OWC has good refurbished units and my wife's m1 air looked new from them.
p.1 #14Need Laptop Recommendation for Photo Processing
I dropped the laptop and cracked the screen. Apple quoted eight hundred and fifty dollars for the repair, which is more than the machine is even worth at this point. It gave me five solid years, so I really can’t complain. For now I’m using a cheap laptop that I wiped and installed Ubuntu on. It works fine for basic web browsing, but it’s nowhere near powerful enough for any real work.
p.1 #15Need Laptop Recommendation for Photo Processing
Pro + 32GB ... that's my minimum threshold. You can get more / Max / 64GB / etc. ... but, I always recommend Pro + 32GB (shared memory).
Granted, that'll push $2K a bit, but it will be worth it. I bought / returned multiple MBP units, Base, Air, Pro, Max with configs of 24, 32 and 64 (been a few years). The bump from Pro > Max wasn't readily noticeble. The bump from 32 to 64 wasn't readily noticeable. BUT the DROP from Pro > AIR / Base was. The drop from 32 to 24 was. Thus, my recommendation for folks trying to find that line of bang / buck ... Pro + 32GB is my minimum recommendation.
That said, if you like ... buy it, try and return it, buy a different one, try it return it. Rinse, repeat for yourself. Over an extended period of roughly 6 months I went throught 5 or 6 different configurations. Apple was ALWAYS super receptive to my return (which likely fed the refurb inventory).
I talked with the store folks about it and we got to a place where we'd laugh when I came back to return another unit. BTW, that also included 14 and 16 inch variants, and the 15 inch Air. BUT, they were entirely SINCERE when they said they just want me to be sure and get the one I want ... i.e. NO BUYER's REMORSE ... and, while it took me (newbie to Mac) a while to work my way through so many rigs, they were cool with it.
So ... don't be afraid to harness their return policy (including refurbs, that I mostly bought). I ended up with an 16" M2 Max, 64GB, for my personal decision, but from all that I learned about the pipeline performance of multilple memory modules bandwidth ... 32GB is the minimum I'd recommend. Dropping down to 24 became "laggy" compared to 32 ... especially when doing things like heavy brush work.
Personally, if I had the choice between an M5 with 24GB and an M4 with 32GB ... no brainer for me, 32GB minimum, in a Pro Variant. If the M5 was a few $$$ more, and you wanted the M5 power vs. the 4 Power, sure pony up the $$$. But, for anything photo editing oriented, I would NOT recommend 24GB. General use folks (i.e. not doing brush work, etc.), sure 24GB is a bargain. Actually, that was the bang / buck point I thought I would be "smart" and get ... until I used 24GB after having used 32GB. 24GB, not so smart, after all (imo).
p.1 #16Need Laptop Recommendation for Photo Processing
If performance is important then you should be looking at the MBP not the Air. M5 Max w/minimum 32GB ram. A lot can change in five years so IMO it's best to put the $$ in up front. I just moved from an M1 Max 32gb to the M5 Max 64gb. Major improvement in processing speed via LR using its AI Denoise.
p.1 #17Need Laptop Recommendation for Photo Processing
I am leaning more towards MBP with M5 Pro chip and 48 GB RAM (32 GB is not available in Pro variant).
I really was hoping that MBA would be enough. I really like the form factor of AIR over Pro.
How do you feel about Nano Crystal Screen (reduced reflection). I have been looking reviews and some people say they cannot go back to a normal screen and others say that black are not as black on it. This is going to become a $3,000 purchase for me, but I guess buy once cry once.
p.1 #18Need Laptop Recommendation for Photo Processing
I have the Nano on my Ipad and my Studio display in my office-
I love it on both-IT really makes a difference on both screens whenever there is any sort of refelction. On a Macbook its a no brainer since you are going to be outside/moving around using it. Well worth the cost.
Also I have the new Macbook M5 with 48GB of Ram-
You could automate your entire photo processing suite with a local LLM- Those machines are crazy powerful and will do literally anything you need. Probably way over spec'd for what you are after
p.1 #19Need Laptop Recommendation for Photo Processing
ramesesthe2nd wrote: gdanmitchell wroteramesesthe2nd wroteMy current 14-inch MacBook Pro (M1 Pro) just died, so I'm in the market for a replacement. This time, I'm leaning toward a 15-inch MacBook Air. I use Lightroom Classic for all of my photo editing work, so performance is an important consideration.
Given a budget of around $2,000, which model (Air or Pro) would you recommend?There’s a general forum and a post-processing forum that might be more appropriate for this post… and where you might get advice from a range of users who don’t shoot Sony. :-)Yeah. Sorry about that. I don't see a way to move this now.
Aside from asking the moderators to move it (always a possibility), I think you can still cross-post it to the other forum by editing your original post and looking at the lower part of the screen for a place to add that.
EDIT: Heh. Just visited that forum and see that you figured it out already! :-)
p.1 #20Need Laptop Recommendation for Photo Processing
It has been a while since I bought a new Apple laptop. (I’ve since moved to the iPad Pro for travel, using a two-monitor desktop system for my “serious” photo work.) That last laptops from Apple that I owned were Macbook Air models and, aside from mine eventually falling behind more recent technology, I like that format a lot.
If I were getting one of those now I might look at the 13” model with the maximum 32GB internal memory and the 1TB SSD, and the upgraded processor. (The latter is only $100 more.) Given the moves toward more AI features and so forth, I’d maximize the internal memory so as to be sure I’d have plenty to effectively run the OS and apps for as long as I might keep the thing, at 32GB is the current maximum they’ll include.
1TB SSDs provide plenty of place for the system, apps, and some files — though if you shoot raw and generate a lot of files you will eventually need to purchase additional external storage. (You could get more — and more expensive — SSD storage if you think it will be enough to eliminate the need for external storage beyond your backup system.)
I quickly spec’ed this system out and it is just barely under your $2000 threshold. You could save a little money without too much of a performance difference by not going for the $100 upgraded processor.
This option is viable if you are getting the laptop because you work remotely a lot and want the smallest, lightest possible system. But for off-the-road use you may well want an external keyboard and trackpad and monitor. If you intend to mostly work remotely or you are fine with a laptop sized monitor you could go with the 15” model… but it exceeds your price limit.
$2k is a tough limit for a Lightroom/Photoshop centric image processing machine, since you want/need plenty of storage and speed.
