Epson P9000 Administrator Password problem
gdanmitchell
p.1 #1Epson P9000 Administrator Password problem
Yes, two questions about issues with my Epson printer today...
I was going to do a firmware update on my P9000 today, but it the application (on MacOS) that installs firmware updates asked me to enter an Administrator Password for the printer before proceeding. The last time I updated printer firmware — over a year ago — I do not recall getting that question.
I tried the usual Epson-recommended options: entering the printer serial number, admin, dpeson. 000, and so forth. Nothing works.
I do not recall ever actually adding an administrator password for this printer, but now I'm locked out of these low level controls such as firmware updating.
I get the impression that there is some work around to resolve this. One site suggested some steps on the printer's front panel interface, but that did not work. Others suggested looking for the password on a panel on the printer, but that does not seem to exist.
Ideas anyone? Before I try to contact Epson support? (Which I am learning is not exactly easy.)
thanks.
Aug 14, 2026 at 03:36 PM
Jack Flesher
Details
p.1 #2Epson P9000 Administrator Password problem
Long shot: It may be a Mac thing -- did you try using your Mac PW?
That said, I had a similar issue with an older HP laser printer a few months back. Was a PITA. I eventually had to change the admin PW on the laser printer to get new software to install.
Aug 14, 2026 at 05:36 PM
John Wheeler
Details
p.1 #3Epson P9000 Administrator Password problem
...Show more →
First, make sure the Apple AirPrint driver is not installed and rather the Epson Printer Driver
If you already done that, don't assume that all the media has been installed. For my P900, in the Applications Folder under Epson Software, there is another folder named "Epson Media Installer", and the app you want to run is "Epson Media Installer.app"
That would be the first two steps I would take.
John Wheeler
Aug 14, 2026 at 10:03 PM
gdanmitchell
Details
p.1 #4Epson P9000 Administrator Password problem
Thanks for that information.
The biggest issue that I still have is resolving the administrator password issue. If the printer has one — and mine apparently acquired one somehow — you cannot do a firmware update. (I was able to do that update in the past — it looks like the current version was installed in 2023, which was long after I purchased the printer.)
So what I really need is a way to resolve the password problem.
Various sources suggest that Epson may use several default passwords: admin, epson, 0000, or even leave it blank. None of those work. There are also suggestions to use the 10-character printer serial number. That doesn’t work either.
I think I need to find some way to reset the password (and probably the entire printer) back to the factory state, but the one set of instructions I found for that online is a dead end because… you need to password to access the option!
Aug 15, 2026 at 08:48 AM
dhlewis
Details
p.1 #5Epson P9000 Administrator Password problem
long shot, look in the Apple password app and see it it was logged there? I do remember that when Epson firmware for the "no chip" cartridge version is when mine got assigned to my P7000.
Aug 15, 2026 at 12:59 PM
gdanmitchell
Details
p.1 #6Epson P9000 Administrator Password problem
Well, darn, that did not work. I have no passwords for Epson in my Passwords app.
The connection to that “no chip” firmware update is intriguing though. I did install that back then after it was announced (It shows up on my printout of printer info) and that did not require a password, as I recall.
Aug 15, 2026 at 01:41 PM
Alan4color
Details
p.1 #7Epson P9000 Administrator Password problem
I read the default administrator password for the Epson SureColor P9000 is the product's serial number printed on the physical label
Aug 15, 2026 at 04:44 PM
mgmonster
Details
p.1 #8Epson P9000 Administrator Password problem
I also think the password is the printer serial number. That was the password for my ET-8550. Hope this works.
Aug 15, 2026 at 06:46 PM
dvoss
Details
p.1 #9Epson P9000 Administrator Password problem
You might need to force the printer into recovery or firmware update mode and then reinstall the firmware. It could involve some finger yoga on the keypad, but I'm not sure about the P9000.
When I had chipless firmware on my P800, I read there was a way to force recovery mode through a fairly scary procedure involving pulling the plug mid-operation. Not for the faint of heart. But I went back to OEM firmware because I don't print enough to justify third-party inks.
As I recall, you need to use a Windows PC and connect to the printer directly with a USB cable.
This Epson Wide Format printer group has a lot of experienced members who could probably help out and the files section has a field repair guide and service manual for the P9000 series:
https://groups.io/g/EpsonWideFormat
Good luck.
Aug 15, 2026 at 07:05 PM
gdanmitchell
Details
p.1 #10Epson P9000 Administrator Password problem
Yeah, that's what I've read. But it doesn't work. (And I had to get it from a machine info printout since for the life of me I cannot find that label.)
...Show more →
Thanks. I'll give that group a try. Now I wait for my application to be approved.
Aug 15, 2026 at 08:36 PM
Switch to mobile view
