panos.v wrote:
Pixelpuffin wrote
panos.v wrote
Not 300X, I briefly had a 300V but the rear door latch broke. I sitll have the 300 (aka Rebel 2000) from 2001 which was my first "proper" camera. These are great cameras, mine has had hundreds of rolls through it, mainly with the 50/1.8II and later the 40/2.8. With the 40 it makes a very compact and light body that will perform just as well as anything bigger, heavier and more expensive. Great little cameras. Great to hear 👍🏻
Originally I was going to fit my 40stm for the reasons you’ve given. But stuck with a single iso speed film I figured the 1.8 aperture on the fifty might be a life saver at some point. Yup, that certainly helps, plus it gives you a few more options on depth of field control. If you want to splurge out I'd highly recommend getting the 50/1.8 STM over the II. Still plastic but feels much more solid, quiet AF, sharper and overall a much better lens for very little money.
The other lens I really liked with it was the 35/2 IS. Bigger, heavier and pricier but the IS, AF and optical qualities are excellent.
I have the lenses you mention. I might swap out for the later stm version.
I also picked up the old ef Tamron 17mm 3.5 a while back
That might actually find itself paired with the little canon at some point🤣👍🏻
