Are Sony A7R6 and Zeiss Loxia lenses compatible
BokehBeauty
p.1 #1Are Sony A7R6 and Zeiss Loxia lenses compatible
I remember many reports that some Zeiss Loxia lenses don’t work well with newer Sony cameras as Sony A7R5. I have the Loxia 25mm and 21mm and use them with the Sony A7R3 without issues. I would like to upgrade to the A7R6. Any experience, and guidance / help. Thanks a lot!
Jul 18, 2026 at 09:17 AM
dakel
Details
p.1 #2Are Sony A7R6 and Zeiss Loxia lenses compatible
I'm assuming you are talking about the issue where the camera randomly jumps into and out of focus magnify mode. If you are, then yes, for me the issue is present with my A7RVI and Loxia 21mm. I swapped the lens back to my A1 just to confirm the behaviour again and yes it was the same.I'm only a sample of one though!
Jul 18, 2026 at 01:03 PM
Ross Martin
Details
p.1 #3Are Sony A7R6 and Zeiss Loxia lenses compatible
This is good to know, Derrick. Does the issue go away if you turn off that focus magnification feature in the menu? I find with the high-res screen on A7RV & VI I can manually focus pretty easily without magnification.
Jul 18, 2026 at 01:15 PM
bwcolor
Details
p.1 #4Are Sony A7R6 and Zeiss Loxia lenses compatible
Zeiss claims that no firmware updates are needed for the Loxia lenses, but if there is a need then they will supply an update, so best contact Zeiss.
Loxia Firmware
Jul 18, 2026 at 01:26 PM
tsdevine
Details
p.1 #5Are Sony A7R6 and Zeiss Loxia lenses compatible
I heard rumors that the component that reads the aperture change, forget what it's called (encoder?), needs to be replaced. Some are faulty, something like that. With my latest a7R V firmware, my Loxias that have the issue seem a bit better. At least wide open they seem better.
From best to worst in terms of the problem for my Loxias...
85 > 21 > 25
It's still annoying, but I live with it.
Edited on Jul 18, 2026 at 03:53 PM · View previous versions
Jul 18, 2026 at 03:51 PM
8201
Details
p.1 #6Are Sony A7R6 and Zeiss Loxia lenses compatible
I have the Loxia 21mm & the R6, and it doesn't seem to have any problems with the focus magnify mode, with peaking on or off. It shows the lens firmware Version as " .01".
Jul 18, 2026 at 03:52 PM
dakel
Details
p.1 #7Are Sony A7R6 and Zeiss Loxia lenses compatible
Ross Martin wrote:
dakel wroteI'm assuming you are talking about the issue where the camera randomly jumps into and out of focus magnify mode. If you are, then yes, for me the issue is present with my A7RVI and Loxia 21mm. I swapped the lens back to my A1 just to confirm the behaviour again and yes it was the same.I'm only a sample of one though!
Hi Ross
The problem does not appear if I don't use focus magnification. I currently have auto-magnifier set to off but focus magnifier assigned to a custom button so I check my manual focus. When I hit that custom button to check and fine tune focus, it jumps out of magnified view to normal view, randomly. This makes it difficult to check my focus accuracy. For me it's worst at f/2.8 and every stop down it get's better. No idea why.
Cheers
Derrick
Switch to mobile view
